what coolant hose is this? - Mustang Evolution
Old 02-13-2009, 07:11 PM   #1
jimmy_beaner's Avatar
Region: Iowa
yeah, blew it out.
Old 02-13-2009, 07:16 PM   #2
hottcobra's Avatar
Re: what coolant hose is this?
damn that was fast. you get the car home?
Old 02-13-2009, 07:18 PM   #3
Region: Iowa
I walked home dude. I want that bastard below C... it's right above it now
I wanted to grab my camera and head back
Old 02-13-2009, 07:18 PM   #4
hottcobra's Avatar
are you pointing to the hose that runs along the fire wall?
Old 02-13-2009, 07:19 PM   #5
Region: Iowa
it goes through the firewall... and forms a C shape and then plunges into the back of the motor (pointing straight down)
Old 02-13-2009, 07:20 PM   #6
hottcobra's Avatar
take a pic of the busted hose
Old 02-13-2009, 07:21 PM   #7
Region: Iowa
that's where I'm getting to now... had to come home to get the camera When I go back, I think I will try to get her home... maybe latch the hood on "latch 1" so it can still breath some.
Old 02-13-2009, 08:02 PM   #8
Region: Iowa
blew that ****er sky high.. j/k haha
started it up... it was sitting in the snow. I couldn't gather enough speed to get up the hill... so I got stuck, backed down the hill and back into the gas station... but I backed into the dry concrete area.
I got up a large amount of speed the second time... and it spun out and I had to drive it back in to the gas station.
Third time... I flattened the turn out almost completely and just barely got up the hill... and then I had to climb the 2 degree incline into my parking lot.. which took forever. She's home though. Never got above C
Old 02-13-2009, 08:04 PM   #9
hottcobra's Avatar
get a pic of the hose
Old 02-13-2009, 08:07 PM   #10
Region: Iowa
uploading
Old 02-13-2009, 08:09 PM   #11
hottcobra's Avatar
cool
Old 02-13-2009, 08:15 PM   #12
Region: Iowa
prelim pic
Old 02-13-2009, 08:19 PM   #13
hottcobra's Avatar
the plastic fitting broke. not the hose. you need to replace the fitting that screws into the engine.
Old 02-13-2009, 08:20 PM   #14
Region: Iowa
VICTORY:
What do I "order" from the store? And how hard is this fitting going to be to replace?
Old 02-13-2009, 08:24 PM   #15
hottcobra's Avatar
just tell them you need the heater hose fitting that broke. does it screw into the head or block?
Old 02-13-2009, 08:26 PM   #16
Region: Iowa
I couldn't see. They can't be that expensive....
Old 02-13-2009, 08:28 PM   #17
hottcobra's Avatar
no it will be cheep.
Old 02-13-2009, 08:29 PM   #18
Region: Iowa
not this I'm assuming?
Heater hose fitting
I just typed that in for the search for the 2002 Mustang GT...
Old 02-13-2009, 08:34 PM   #19
hottcobra's Avatar
you need to get the old one out. that way you can match it up. if you can replace it with a metal one that would be great. if not just get an OE replacement
Old 02-13-2009, 08:36 PM   #20
Region: Iowa
does it literally screw out? As in... it's threaded (as opposed to held in by screws)? If so... how tightly is this bastard gonna be screwed in? Any recommended tool? I can pop that ****er out tomorrow
Old 02-13-2009, 08:37 PM   #21
Region: Iowa
I added thanks for the 14 useful posts
Old 02-13-2009, 08:39 PM   #22
At least its a cheap fix
Old 02-13-2009, 08:42 PM   #23
Region: Iowa
minus the irreparable damage I did to the motor I think the car was running for a total of 2 minutes after it blew... I think she'll be ok (considering it was completely cold when I started it)
Old 02-13-2009, 08:43 PM   #24
I'm sure it's fine.
Old 02-13-2009, 08:45 PM   #25
Region: Iowa
I'm sure it's fine.
if it isn't... I was planning on getting a new short block this fall if I can afford it.. and the new heads this summer hopefully... Thus, approaching a new motor
Old 02-13-2009, 08:51 PM   #26
hottcobra's Avatar
you didn't hurt your motor. don't worry about it.
who made your sig?
Old 02-13-2009, 08:52 PM   #27
Region: Iowa
who made your sig?
a guy on a different forum...
Is the fitting itself threaded? If so, how do I undo it (as in, how can I get a grip on it?)
Old 02-13-2009, 08:55 PM   #28
hottcobra's Avatar
I donno. if it is threaded in it should have a hex head below where the hose slips on. the only other way it would be is a bolt with a hold down ring
Old 02-13-2009, 08:58 PM   #29
Region: Iowa
I will have to take a look tomorrow when it's daylight. Thank God I put the hood shocks in... give me some extra room.
Old 02-13-2009, 09:01 PM   #30
hottcobra's Avatar
sweet
Old 02-13-2009, 09:02 PM   #31
hottcobra's Avatar
you need something else to drive in the winter.
once you start making big power it's gonna be even harder to drive in the winter
Old 02-13-2009, 09:05 PM   #32
Region: Iowa
yeah I know it. I have the bus a block away from my house... if I HAD to...
My dad is talking about building a smaller place up here for me... 3 car garage with an "house" sort of built around it ... you know you love your car when you design the house around the garage. And then I'll look at getting a FWD car... maybe an old Taurus or something.
Old 02-13-2009, 09:06 PM   #33
Get a 2006 Fusion. You can find those pretty cheap
Old 02-13-2009, 09:07 PM   #34
hottcobra's Avatar
4wd truck FTW
Old 02-13-2009, 09:10 PM   #35
Region: Iowa
4wd truck FTW
we'll have to see what happens... part of me sits here going... "new short block" or cheap second car... and the short block is winning...
busted hose Senorjizzy Pre-2005 V6 Mustang 10 08-09-2009 11:59 PM
Air hose upton7 1996-2004 Mustang GT 5 06-02-2009 10:31 PM
I need this hose Mustangfan2003 1996-2004 Mustang GT 9 05-28-2008 02:46 PM
Name that vacuum hose... A5295 1979-1995 Mustang GT 3 11-27-2007 07:17 PM
hose sleeves and elbows whipster24 Mustang Parts for Sale and Wanted 0 04-25-2006 01:04 PM
09:30 AM
