Auto shifting early, please help... - Mustang Evolution
Old 02-14-2009, 03:07 PM   #1
Hi folks, long time reader, first time writer here. My problem is this, I have a 2000 mustang gt automatic with 3.90 gears, some bolt ons and a predator tuner. Under wide open throttle, my car shifts way to early, at about 4900 rpm. From videos i have seen on youtube, i know automatic mustangs of my generation shift about 5600 to 5800 rpm, so i dont know what is wrong with my car. I have tried changing the shift points on the predator, but this doesnt change anything, which leads me to believe its not the computer but something mechanical causing the problems. Could my transmission be low on fluid or something? Any help would be appreciated.
whitestang00p is offline   Reply With Quote
Old 02-16-2009, 01:24 PM   #2
Re: Auto shifting early, please help...
I know my auto 00 use to shift at or around those points before I used a predator tuner to change it to 5950 WOT. I would defiantly check the fluid level while its running on the transmission.
2kslvrgt is offline   Reply With Quote
Old 02-21-2009, 01:18 PM   #3
I have also similar type of problem.
Mustang GT 1996 Mustang Accessories
carmania11 is offline   Reply With Quote
Old 02-21-2009, 01:39 PM   #4
With the vehicle running put it through all the gears with your foot on the brake, this should let fluid move everywhere it needs to be. While it is still running and in park get out and check the transmission fluid. Sounds to me like you may be slightly low, this would definitely cause the issue.
Old 02-22-2009, 06:38 PM   #5
+1 check the fluid and get back with us, a fresh fluid change can do wonders as you should technically do that every year to 20k miles
Old 02-23-2009, 09:40 AM   #6
Herbstang's Avatar
+ 2 change that filter while you at it
AODE shifting too early randyrobertson 1979-1995 Mustang GT 2 07-04-2010 12:30 AM
2001 Auto Tranny Hesitant Shifting OsirisGuy Pre-2005 V6 Mustang 17 11-14-2008 06:35 AM
The truth about manually shifting an auto Kyle Pre-2005 V6 Mustang 51 11-20-2005 08:59 PM
This is why you don't celebrate too early. WhiteStang99 The Bar 3 06-04-2005 07:16 PM
damn, i'm up early fast64 The Bar 9 10-04-2003 10:57 AM
02:25 PM
