br/nola: i got some full length subframe connectors, and need help - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Regional Mustang Discussion
Old 06-07-2010, 06:25 PM   #1
DarkShadows's Avatar
i bought the J&M products connectors, and from what i can tell im not touching this install! so for that who would yall recommend?
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 06-07-2010, 06:49 PM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: br/nola: i got some full length subframe connectors, and need help
I would've recommended the MM full length connectors... and have them welded in.
Old 06-07-2010, 07:01 PM   #3
hottcobra's Avatar
First off the car needs to be on a 4 post lift, or if you do it at home it needs to be on 4 ramps. If you jack the car up and take the weight off the wheels it will twist the car and when you weld them in it will be twisting the car all the time.
With that said. any shop that is willing to do it, if they don't have a 4 post lift. Don't let them do it.
I know Stang-hi has a 4 post lift, and I think that Cody did Rob's subframe connectors.
Old 06-07-2010, 08:40 PM   #4
Cody did do mine. Took a couple hours due to welding next to the fuel lines and having to let it cool a little at times. Give him a call. Was about $250 to install mine, but that was a few years back when things were different, so it might be a bit more. Shouldn't be, but may be.
Old 06-07-2010, 11:12 PM   #5
I'll check em out
subframe connectors edross 1996-2004 Mustang GT 15 11-25-2009 04:14 PM
Subframe connectors Zim Pre-2005 V6 Mustang 15 07-14-2004 11:58 AM
Subframe connectors? 01mineralgrey6 Pre-2005 V6 Mustang 8 07-22-2003 12:06 AM
03:24 PM
