something different - Mustang Evolution
Old 03-23-2009, 01:19 PM   #1
upton7's Avatar
something different
this is off the topic of mustangs sorry but someone said something about firewall and a hiss i was putting in some subs for my freind a few months ago i couldn't find a place to run the power wire through the firewall so i drilled a hole and luckily enough i think i hit something i hear a hiss that was kinda loud then faded away it kinda smelled wierd and there was a light white fog its a 1997 jeep grand cherokee i went low on the passenger side i drilled through the engine bay and can't see the hole in the cab the vehicle doesn't overheat the heat works and we think the a/c works but it was winter so it would be cold already what did i drill into oh and i found a place to run the wire so no discussion there any help would be aprreciated
Old 03-26-2009, 08:31 AM   #2
Cobra GT's Avatar
Re: something different
It sounds like you hit a vacuum line that operates the duct work, or the weird smell could have been Freon.
1996 GT (sold)
1997 Cobra
1993 Ranger GT (not broke)
Want an 03/04 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
Cobra GT is offline   Reply With Quote
Old 03-26-2009, 09:17 AM   #3
yea it should be very easy to find just look on the other side of the hole. There is a hole located on the drivers side its a little rubber thing you can pull it out and stick the wire through the hole it has.
Old 03-26-2009, 11:04 PM   #4
upton7's Avatar
this is on a jeep grand cherokee and i had to go outside the door and through the fender but i know what your talkin about on the mustangs but how much do you think its gonna cost to be fixed
Old 03-27-2009, 05:52 PM   #5
hottcobra's Avatar
that noise you heard was most likely the sound of freon escaping form the hole you made in the evaportor coil. NOT GOOD!!! that is not gonna be cheap to fix
Old 03-27-2009, 06:01 PM   #6
upton7's Avatar
dang it well thanks for the sad news lol
Old 03-27-2009, 06:17 PM   #7
hottcobra's Avatar
sorry to be the one to bring the bad news
Old 03-27-2009, 06:52 PM   #8
upton7's Avatar
lol well these things happen at least i learned something from it
07:56 AM
