Have a Auto? Look inside.... - Mustang Evolution
Old 12-02-2004, 11:38 PM   #1
No you cant shift faster than your computer so leave it in Drive. Hold the brake and rev your car to just before your tires start spinning.. dont let them spin though. When the green lights come on lift off brake and hold on.
Ways to make your Auto beefier:
Get a transmission cooler. B&M sells one that works very well. Got it on my car
Get a shift kit. Works wonders
Get 4.10 gears and a traction lok
Get a P.I. Torque Convertor 2800-3000
and then you will need a chip for the gears so you can raise your speed limiter and firm up your shift points even more
With all that done you will have a very nice Automatic Mustang
Old 12-02-2004, 11:48 PM   #2
I liek gramer
WhiteStang99's Avatar
I get the feeling this thread will be referenced quite a bit...
Old 12-03-2004, 12:00 AM   #3
Seph's Avatar
sure does feel nice when you are stuck in traffic
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 12-03-2004, 11:16 AM   #4
Hahaha, I love power braking without spinning, the rear end sits up and then squats when you hit it..so awesome. But thanks Brent, I'm sick of saying and I"m sure other people are too lol
Old 12-03-2004, 12:49 PM   #5
evilweirdo42's Avatar
where from? and what type of kit?
Originally Posted by SpectorV
You forget a stock mustang has the same ground clearence as a 4x4 f150...
evilweirdo42 is offline   Reply With Quote
Old 12-03-2004, 01:05 PM   #6
I believe transgo has a decent shift kit, not completely sure on that however, haven't really looked into them.
Old 12-03-2004, 01:41 PM   #7
slvr2000stang's Avatar
Transgo has been ok in pre 99+.
Want to do the best go on tccoa and read about the J-mod.
A shift kit designed by one of the Ford Engineers that worked on the 4R70W.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 12-03-2004, 01:42 PM   #8
tccoa?
Old 12-03-2004, 01:47 PM   #9
Nvm, got ya
Old 12-10-2004, 08:39 AM   #10
get 4.10s...its a must for autos.
My car is pretty fun as is, but I need 4.10s.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 12-10-2004, 11:57 AM   #11
I liek gramer
good idea Stangin!
Old 12-10-2004, 04:54 PM   #12
I agree.
I have a set waiting to be installed. Hopefully over the Holidays.
2000 Vert 4R70W
Old 01-07-2005, 09:35 AM   #13
Send a message via MSN to RDS02Stang
410s are great unless you add in a power adder like a SC - then you top out
Also, be careful of shift kits for 2002+ models, the trannies were re-worked and most makers of shift kits are not yet supporting a setup for these tranny changes.
The retailers will sell you one that states 99+ but be WARNED that they may not work properly with your tranny if you have a 02+ Mustang (at least on the GTs).
I would recommend calling the manufacturer first - I did and saved my tranny, a friend did not and replaced his
:patriot: Robert :patriot:ATI Procharger StageIII, Ported Plenum, 75mm TB, Bassani X-Pipe, FlowMaster Cat-Backs, Kenny Brown Full blown extreme matrix subframe setup, Bilstein shocks & struts, and lot's more.
RDS02Stang is offline   Reply With Quote
Old 01-09-2005, 08:06 PM   #14
Send a message via AIM to mild2002gt Send a message via MSN to mild2002gt Send a message via Yahoo to mild2002gt
wow!
this is a great reference
i already have everything listed but I have 3.73's instead b/c i do a lot of highway driving(90%) and want to be able to setup well with a poweradder later on
mild2002gt is offline   Reply With Quote
Old 02-13-2005, 06:04 PM   #15
If you see green, you're too late. I agree with everything except, release the brake and hit the gas when you see the last yellow. The amount of time it takes for the car to move will give You a good reaction time.
'94 3.8 muffler removed, 16.993 @ 81.94.
'96 Gatway Int. Raceway Street ET champ
'98 & 00 runner up
dead-on is offline   Reply With Quote
Old 03-03-2005, 06:09 PM   #16
true, oh so true...after going to the tracks more often i can see the difference with lights and such
Old 12-20-2006, 04:13 PM   #17
jwyche's Avatar
Re: Have a Auto? Look inside....
My 2002 GT sees mostly freeway duty. I put 3.90:1 gears in it along with a Stallion torque converter. I bought an Xcalibrator II from Brenspeed and they raised the shift points and the firmness of the shift...without a shift kit. It feels really great when nailed off idle.
Most of my drag strip time goes to the 1992 GT so I'm not sure whether this is typical of other 2002 GT's with an automatic . I didn't brake and rev it. Just matted it on the last yellow. The plugs were over a year old, full tank of gas, and all my junk in the trunk it went 8.904 @ 77.49 in the eighth.
So, how does that compare? O.K. or pitiful? The car also has UDP's and CAI.
I'll attach the time sheet.
Name:	Jim's 2002 GT.jpg
ID:	15547   Click image for larger version
Name:	2002 GT Timeslip.jpg
Jim Wyche:Senior Citizen. 1992 Mustang GT with a few mods. See webpage http://web.mac.com/jwyche or my garage. 2002 Mustang GT with a few mods. Collegedale, Tennessee.
jwyche is offline   Reply With Quote
Old 01-22-2007, 07:31 AM   #18
Auto power. My auto is pretty beefy. Putfile - cars 009
mustang46mod is offline   Reply With Quote
Old 01-23-2007, 06:17 PM   #19
maximus's Avatar
def good ideas. too many ppl come in and ask wat they can do to an auto. on a side note, i put a cai, t-lok, 4.10's and a tune in my v6 auto. those couple things made my baby into a totally different car. those are the 4 first things that should be done to a v6 auto as soon as its bought and money is there. def would have like to have seen what the shift kit and cooler would have done. but just so happened that i traded her in for my new GT...:woo:
maximus is offline   Reply With Quote
Old 01-23-2007, 06:28 PM   #20
Yeah, this is some interesting info now that I have an auto in the carport. Need to look into the shift kit concept a little more...and the tranny cooler...
I think my plans are 3.73, trans cooler, shift kit, tuned shift points...
Old 05-20-2009, 08:57 PM   #21
rinfield2004's Avatar
Thank you!!!!!!!!!!!!!!!!! You just solved a world of problems for me!!!!!!!! Thank you!
rinfield2004 is offline   Reply With Quote
Old 05-21-2009, 12:52 PM   #22
SaleenFiend's Avatar
Thats a decent 60ft
Inside out... Drunken Ghost Pre-2005 V6 Mustang 5 07-19-2006 08:10 AM
pics inside 8.8 charkelly9 Pre-2005 V6 Mustang 13 10-11-2005 08:54 PM
What do you think of... (WW link inside) bluemustang The Bar 5 11-13-2004 04:01 PM
All MD,PA,DE,VA Guys inside v6stanger Pre-2005 V6 Mustang 2 09-21-2003 04:51 PM
05:52 AM
