Trunk dimensions - Mustang Evolution
Old 04-02-2009, 12:01 AM   #1
Trunk dimensions
anyone know them right off the top of their head? I've got a set of Alpine Type-R 12's and the box I have them in now is way too big to fit in the trunk, so I need to build me another box.
Not sure if the trunk is the same size on all year mustangs, but it's a 2000.
19Delta is offline   Reply With Quote
Old 04-02-2009, 01:09 AM   #2
upton7's Avatar
Re: Trunk dimensions
don't know the actual dimensions but i had a 13" box that barely fit when i took the seats out it was 13" high and 26" long
Old 04-02-2009, 08:50 AM   #3
well, the box I was using was 15" long and 16" tall, and it wouldn't even start in the trunk. I guess I'll just get out there with a tape measure and find out.
Old 04-02-2009, 11:22 AM   #4
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
just delete the rear seats, who sits in the back ofa mustang anyway? than you can just slide your box in from the passanger compartment
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 04-02-2009, 12:12 PM   #5
Ok, I bought a box at a local audio store that fits, now my problem is finding a good enough ground. I'm beginning to think I don't deserve subs in my car, lol.
Old 04-02-2009, 07:32 PM   #6
upton7's Avatar
either take the panel that covers the left side and pull it out and stick it between the two peices of metal or run it under the rear seat and loosen one of the upper rear seat bolts and tighten it there
Old 04-02-2009, 09:40 PM   #7
ah i just ran another wire from the battery.
Old 04-02-2009, 09:44 PM   #8
upton7's Avatar
not good man that ground needs to be short
Old 04-02-2009, 11:30 PM   #9
OsirisGuy's Avatar
10.7 Cubic Feet
EDIT: Did you check under the seat for any bolts to ground? What size gauge are you running?
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 04-02-2009, 11:33 PM   #10
I did, and I tried those, but it didn't seem to work. I'm running 4 gauge power and 2 guage ground. I just ran the power down the drivers side and the ground down the passenger side to the amp.
Old 04-02-2009, 11:34 PM   #11
upton7's Avatar
the bolt that holds the seats in is what i'm using for ground and i forgot what gauge i got i have like 3 sets so i get confused on what i got
Old 04-02-2009, 11:36 PM   #12
upton7's Avatar
thats some big ****in wire but **** man i don't know why that won't work did you tighten it all the way?
Old 04-02-2009, 11:38 PM   #13
Yes I did. Yeah the wire is pretty big, but, you pay for what you get. Stinger FTMFW!
Old 04-02-2009, 11:38 PM   #14
OsirisGuy's Avatar
Usually those ring terminals aren't big enough to fit through the belt's bolt. I'll usually cut them if they are close or round out the center with a unibit or something so the bolt will fit nicely.
OsirisGuy is right
2002 Mustang GT
Old 04-02-2009, 11:39 PM   #15
upton7's Avatar
ftmfw?
Old 04-02-2009, 11:40 PM   #16
for the mf'n win.
Old 04-02-2009, 11:44 PM   #17
OsirisGuy's Avatar
I've had problems with Stinger. RF FTMFW!
OsirisGuy is right
2002 Mustang GT
Old 04-02-2009, 11:46 PM   #18
Rockford is a great company. Matter of fact, I'm rockin' a T1500 mono amp.
trunk dimensions wkndpaintballer General Mustang Discussion 0 04-30-2009 12:53 PM
Looking for trunk 68dreamer Mustang Parts for Sale and Wanted 0 01-05-2007 07:37 PM
99 trunk dimensions question WhiteStang99 Mustang Audio & Video 5 05-08-2005 12:27 PM
Trunk dimensions NavyStang05 Mustang Audio & Video 1 02-20-2004 02:44 PM
Trunk Dimensions el cheapo Mustang Audio & Video 0 07-21-2003 11:43 AM
10:21 AM
