Check Engine Light - Help! - Mustang Evolution
Old 04-11-2009, 08:05 PM   #1
Ok, once again I need the knowledge of those much wiser than me. I took your advice and went to AutoZone to have the code read when the check engine light went on and it came up "EGR valve." I dutifully purchased a new valve and installed it and even put on a new EGR sensor, unhooked the battery to get rid of the code and then, when I drove it on the highway again, guess what? My "friendly" light came back on.
Now I am really confused. Again, all of this started after my last fill up of gas.
I hope you all are not laughing at my ignorance too much but do you have any other ideas as to what I should do? I am still trying to convince my wife that the car was a good deal. Any guesses at the looks I have been getting?
Thanks in advance for your help and patience with an old man!
Eeyore is offline   Reply With Quote
Old 04-11-2009, 08:08 PM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: CHECK %&*&&* ENGINE LIGHT
you should put up the actual code... such as p0151. Just because the code is labeled "EGR valve" doesn't mean THAT is the problem, just that is the sensor that caught the malfunction.
For instance, I was getting a front o2 sensors indicating lean (yes, both)... the problem wasn't with the sensors, and it wasn't an exhaust leak near the sensors... I had to clean the MAF. So that means your code is RELATED to the EGR system.
Old 04-11-2009, 08:11 PM   #3
Thanks Jimmy,
Now, one more dumb question. How/where can I get that actual code?
Old 04-11-2009, 08:34 PM   #4
Region: Iowa
Originally Posted by Eeyore View Post
Thanks Jimmy,
Ask Autozone to provide you the CODE not what their scanner says the code means. Oh, and the thanks button is ~~~> that way
Old 04-11-2009, 08:55 PM   #5
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
what year is your car? do newer mustangs have those gas cap sensors that give check engine lights when dropped? just curious.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 04-11-2009, 09:06 PM   #6
MonteCitan's Avatar
Re: Check Engine Light - Help!
Without having the actual code... Since it may have been improper flow detected, or even an EVAP code, etc (autozone/scan tool may misrepresent it)
I'm just going to throw out there.. when you replaced the EGR valve, did you happen to check the ports into the intake where the EGR goes in? In cars with carbon issues, that can block up pretty quickly (granted its usually the EGR valve that plugs first, but I've seen it go both ways)
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-12-2009, 07:53 AM   #7
I did a visual check but is there a way to clean those ports? I made it so that taking the EGR valve off is easier this time.
Thank you for your advice and help
Old 04-12-2009, 10:05 AM   #8
yea you have to be careful, its not always where the sensor is its there or before in the line of flow~
Old 04-12-2009, 10:16 AM   #9
Region: Iowa
get the code, and then we can run through more hypothetical situations
Old 04-12-2009, 03:11 PM   #10
it will more than probably be the dpfe sensor, relating the egr system. ive seen the late model fords go through this pretty often and the dpfe was 9 out of 10 the issue.
96 GT- Who knows what's in it.
Old 04-12-2009, 03:42 PM   #11
Region: Iowa
don't feel the need to give thanks to every post just the ones that actually HELP you
Old 04-13-2009, 07:09 AM   #12
ditto on the dpfe. usually the code is a p0401-egr insufficient flow.
a little bit to add on. the PID (perameter identification) for the dpfe is typically aroun 1 volt at idle. let us know what you find.
iamdat is offline   Reply With Quote
Old 04-13-2009, 07:12 AM   #13
also another tidbit, ive never seen 4.6 mustang egr ports gets clogged up. its usually on the truck 4.6's where the egr ports are real small and retricted. those are easy to clean though, just remove the intake elbow. ok, ive said too much. back on topic
Old 04-13-2009, 09:39 AM   #14
Region: Iowa
well he hasn't quite shared which vehicle he has yet
Old 04-13-2009, 10:03 AM   #15
haha, indeed. you know what they say when you assume
Old 04-23-2009, 07:26 AM   #16
SaleenFiend's Avatar
Correct and useful information guys!
check engine
Help!Check engine light on The Darkside Pre-2005 V6 Mustang 13 12-01-2008 02:28 PM
check engine light on! 1999Stang Pre-2005 V6 Mustang 2 08-09-2008 12:04 PM
Need Help with Check Engine light dch61407 1996-2004 Mustang GT 2 01-30-2008 07:01 PM
check engine light avery_y Pre-2005 V6 Mustang 9 01-13-2007 06:16 PM
Check engine light donnie Pre-2005 V6 Mustang 1 05-22-2006 02:53 PM
12:25 PM
