Motorcraft FL-820s vs Ford Racing CM-6731-FL820 Oil Filters - Mustang Evolution
Old 04-14-2009, 08:37 AM   #1
SaleenFiend's Avatar
Post Motorcraft FL-820s vs Ford Racing CM-6731-FL820 Oil Filters
FYI.....picked this up on another site.
I thought you guys would be interested in reading this comparison study because so many people are under the impression that both of these filters are exactly the same just different labels. Look at the difference in total square inches of filtering media surface, Ford Racing is 250 square inches compared to 156 square inches for the Motorcraft, that's 94 square inches less! A larger filtering surface means more oil flow and greater filtering capacity. I get my Ford Racing filters from LateModel Restoration Supply OIL FILTER, FL820 - HIGH PERFORMANCE MISCFORD for $12.99. The Ford Racing filter is built using thicker metal (noticeably heavier) for the can material and the threaded base plate is real beefy with deep high quality machined threads. I was using the K&N HP-2010 until I read this article. The Motorcraft and Ford Racing Filters both utilize a base end mounted bypass valve instead of a top dome mounted bypass valve like the K&N and Purolator models. You can read about the importance of the bypass valve location in the oil filter comparison link I have attached for you below.
Read this link for the full comparison FL-820S Oil Filter Alternatives
Measurements
* Filter Weight - 19.75 oz
* Can OD - 3.68" / Seam OD - 3.76"
* Overall Height - 3.99"
* Can Material - 0.019" thick steel
* Filter Element OD - 3.44" (at element)
* Filter Element Height - 2.81"
* Media - Cellulose - Synthetic Mix? Oiled? (appears orange)
* Number of pleats - 63 + 1 joint
* Depth of pleats - 0.73"
* Media length (unrolled) - 100" (seam crimped)
* Media width (glue not included) - 2.50"
* Media thickness - 0.029"
* Total media surface area - 250 sq. in.
* Total media volume - 7.25 cu. in.
* Inner Filter Support Material - 0.010" Thick Perforated Steel
* Inner Filter Support OD - 1.71"
* Indentifying marks
Can - 810050516 / Made in USA
Bar Code - 7_56122_07567_8
Label - 6945234
Base - 22 / MM
* Gasket Retention - Multiple Crimps
* Thread - M22-1.5
* Relief Valve Location - base end
* ADBV Material - Silicon
Motorcraft FL-820S
Measurements
* Filter Weight - 13.1 oz
* Overall OD - 3.76" @ seam / 3.66 @ can
* Overall Height - 4.05"
* Can Material - 0.02" thick steel
* Filter Element OD - 3.25"
* Filter Element Height - 2.51"
* Media - Cellulose (appears pink/orange)
* Number of pleats - 43 + 1 joint
* Depth of pleats - 0.68"
* Media length (unrolled) - 65.5"
* Media width (glue not included) - 2.375"
* Media thickness - 0.035"
* Total media surface area - 156 sq. in.
* Total media volume - 5.4 cu. in.
* Inner Filter Support Material - 0.012" Thick Perforated Steel
* Inner Filter Support OD - 1.68"
Can - Made in USA
ADBV - 6944453 / AAX / 150
* Thread - M22-1.5
* ADBV Material - Silicone (orange)
K&N HP-2010 Filter
Measurements
* Filter Weight - 16.8 oz
* Overall OD - 3.66"
* Overall Height - 4.09" to top of "nut" / 3.71" to top of can
* Filter Element OD - 3.36"
* Filter Element Height - 2.24"
* Media - Synthetic (appears pink/orange)
* Number of pleats - 55 + 1 joint
* Depth of pleats - 0.72"
* Media length (unrolled) - 89.3"
* Media width (glue not included) - 2.1"
* Media thickness - 0.030"
* Total media surface area - 187 sq. in.
* Total media volume - 5.6 cu. in.
* Inner Filter Support Material - 0.015" Thick Perforated Steel
* Inner Filter Support OD - 1.66"
Can - 072206C1 / Product of USA
ADBV - AAX / 77
Base - ZZ
* Gasket Retention - Press Fit
* Thread - M22 -1.5
* Relief Valve Location - dome end
* Gasket includes lubricant
Purolator PureOne PL24651 Oil Filter
Measurements
* Filter Weight - 12.6 oz
* Overall Height - 3.77"
* Can Material - 0.014" thick steel
* Filter Element Height - 2.65"
* Number of pleats - 60 + 1 joint
* Media length (unrolled) - 91.5"
* Media width (glue not included) - 2.56"
* Total media surface area - 234 sq. in.
* Total media volume - 7.0 cu. in.
* Inner Filter Support OD - 1.72"
Can - F07518G2 / Made in USA
ADBV - 6944453 / AAX / 104
* Gasket includes teflon
* Thread - M22-1.5
Old 04-14-2009, 10:46 AM   #2
DarkShadows's Avatar
Re: Motorcraft FL-820s vs Ford Racing CM-6731-FL820 Oil Filters
Interesting read indeed
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 04-14-2009, 12:30 PM   #3
interesting, i use an 820s
Old 04-15-2009, 03:01 PM   #4
another thing to add, the fl820 is now being redesigned to be shorter to easier get in tighter spaces for such vehicles such as older t-birds, continenentals, etc...
iamdat is offline   Reply With Quote
Old 04-15-2009, 03:18 PM   #5
hmm I wonder if it will make the cut for some UPR k members also?
Old 04-15-2009, 03:28 PM   #6
i wouldnt know. us pushrods boys use FL1A's
Old 04-15-2009, 03:36 PM   #7
push'n your hot rods? what?
edit: Now if somebody doesn't give me a good "I see what you did there + pic" You suck
Old 04-15-2009, 03:58 PM   #8
damn, just......not.......clev....errr......eeeee......nufffffff
Old 04-16-2009, 01:32 AM   #9
RyansQuick6's Avatar
FL-400S FTMFW!!!!
RyansQuick6 is offline   Reply With Quote
Old 04-16-2009, 06:56 AM   #10
Originally Posted by RyansQuick6 View Post
FL-400S FTMFW!!!!
is that a riding mower filter??
96 GT- Who knows what's in it.
Old 04-16-2009, 12:15 PM   #11
No, it's smaller, I buy it at walmart next to the Hot Wheels!
Old 04-16-2009, 04:23 PM   #12
LOL.
Old 04-19-2009, 04:39 PM   #13
Scut95's Avatar
I was wondering what cars these filters were for. But I got my answer. I never heard of those numbers because I'm still rocking a pushrod engine and an FL-1A filter, which is a pretty big filter actually.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
What Oil Filters TO Use, And Not To Use JROC General Car Discussion 10 02-24-2007 08:19 AM
10:03 AM
