1996 mustang steering problems - Mustang Evolution
Old 04-16-2009, 10:14 AM   #1
Smile 1996 mustang steering problems
hi all,
I'm a newbie so bare with me. I just bought a 1996 mustang V6 auto for my daughter and I noticed that the steering has play in it. According to a mechanic, it is the lower steering shaft. How hard is this to replace and cost? Is there anything else I should look for? Mechanic says tie rod ends and rack are good with exception of rack bushings. Any ideas?
Thanks
Hank
whr1966 is offline   Reply With Quote
Old 04-16-2009, 10:55 AM   #2
SaleenFiend's Avatar
Re: 1996 mustang steering problems
Start with the rack bushings, should help eliminate looseness, If the he is right that everything is good (tie rods, etc) and the problem continues then you probably have a bad rack.
Old 04-16-2009, 11:58 AM   #3
Thanks Saleenfiend. However, I think you are misunderstanding me or i just didn't explain it correctly. I have a lot of play between the steering wheel and the rack. I can turn the steering wheel about an inch or so without it moving anything and it makes a clicking noise while turning. Also, if I grab the lower shaft by the u-joint from under the hood area, I can move it around a little. But the joint seems to be tight. A little too much in my opinion. Anymore ideas.
Old 04-16-2009, 01:38 PM   #4
Reading comprehension fails me, I skimmed through and made assumptions. I don't see why the shaft needs replacement especially if it is tight. It seems like the Rack may have issues. But I would start with the Bushings as stated (depends on how Shot they are)
1996 mustang
2000 Mustang Steering wooltonboy General Mustang Discussion 4 05-28-2009 10:15 AM
Suspension & Steering Problems. megax29 Pre-2005 V6 Mustang 5 01-05-2009 05:48 PM
1996 mustang? mustangmadnes09 General Car Discussion 6 09-04-2008 11:31 AM
1996 Mustang HELP! roadfeet Pre-2005 V6 Mustang 2 04-23-2006 06:16 PM
1996 Mustang GT Buzz 1996-2004 Mustang GT 1 04-22-2006 12:48 PM
11:40 PM
