Engine "ping" - Mustang Evolution
Old 04-25-2009, 12:13 PM   #1
Engine "ping"
When I first start the engine on my 01 mustang there is a "tapping" sound that comes from the engine. It lasts for about 30 seconds and then goes away. I do not hear it at any other time the car is running or idling nor do I hear it when I accelerate. Any ideas what I could do to eliminate this sound?
Thanks in advance for any suggestions!
Eeyore is offline   Reply With Quote
Old 04-25-2009, 06:34 PM   #2
Cobra GT's Avatar
Re: Engine "ping"
it sounds like valve train noise, after you start it the oil gets pumped to the top and it goes away? if it is a ping it could be that the timing is advanced at start up and then retards retards
1996 GT (sold)
1997 Cobra
1993 Ranger GT (not broke)
Want an 03/04 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
Cobra GT is offline   Reply With Quote
Old 04-25-2009, 09:05 PM   #3
hottcobra's Avatar
Re: Engine "ping"
^ good advice. Is it a pushrod engine, or a modular engine?
Old 04-25-2009, 09:19 PM   #4
Re: Engine "ping"
Any advice on how to fix this?
Old 04-26-2009, 12:11 PM   #5
Re: Engine "ping"
does it do it when you crank it up or just did , it could be the valve train making a little noise as the oil works its way to it~
Old 04-26-2009, 12:38 PM   #6
Re: Engine "ping"
It does not do it when I really get it going. As a matter of fact, in less than thirty seconds it goes away completely. My concern is, does it hurt/damage the engine?
Thank you for your insights!
Old 04-26-2009, 03:07 PM   #7
Cobra GT's Avatar
Re: Engine "ping"
If you are not getting oil to your valve train it will cause damage if it hasn’t already (ticking or tapping noise on start up). It is probably a bad rocker or the valve lash adjuster assuming you have a 4.6L. What weight oil are you using, with the 4.6 don’t use anything heaver than 10w30. If it is a pushrod motor it is probably the rocker, lifter, or pushrod, which can be adjusted or cheap to replace.
1996 GT (sold)
1997 Cobra
Want an 03/04 Cobra
Another "Which engine oil should I use" Thread OsirisGuy 1996-2004 Mustang GT 11 07-08-2009 12:34 PM
"Service engine soon" light FLGT 1996-2004 Mustang GT 9 03-03-2008 10:06 AM
MTI RACING "Extreme Velocity" 454 "Southern Stingray" C6/Z = Awesome JROC Pictures and Videos 10 10-26-2007 03:33 AM
w0000ttt!!!!! got something today (starts with "s" ends with "upercharger") fast64 Pictures and Videos 37 02-22-2005 05:52 PM
02:24 PM
