transmission problem..2006 v6 - Mustang Evolution
Old 05-17-2009, 03:00 PM   #1
just purchased 2006 mustang...after a week got in the car,put it in gear and the car won't move..what kind of problem does this sound like?
jackwhite is offline   Reply With Quote
Old 05-20-2009, 10:27 PM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: transmission problem..2006 v6
Sounds like you have an auto transmission with no fluid in it. Either a leak or excessively low fluid level from the factory... If it worked for a week I'd say leak. You bottom it out recently, or hit something in the road to put a hole in the tranny pan?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 05-21-2009, 12:49 PM   #3
SaleenFiend's Avatar
All in agreement say Aye!
AYE!
Old 05-21-2009, 02:24 PM   #4
SORRY i DIDN'T GIVE ENOUGH INFO..BOUGHT THE CAR USED WITH 38000 MILES ON IT...ITS A 5 SPEED...HAD IT A WEEK AND THE CLUTCH WENT OUT..HAVE YOU HEARD OF THIS BEING A HISTORY PROBLEM WITH THE MUSTANG?
Old 05-21-2009, 04:21 PM   #5
You sure the clutch is worn out? Not the cable or quad is broken? It is very possible to burn a clutch up quickly. If you try to or can't drive a stick. I have seen clutches go in 5000 miles
Transmission problem.... I think...HELP! BbV06Stang Pre-2005 V6 Mustang 8 06-07-2009 10:59 PM
Transmission help jwalthersoccer Pre-2005 V6 Mustang 32 05-17-2009 09:29 AM
Transmission fit problem claytonbeaver Classic Mustangs 2 05-05-2009 09:17 AM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
02:30 PM
