what trans fluid - Mustang Evolution
Old 06-08-2009, 09:26 AM   #1
DarkShadows's Avatar
what trans fluid
Well it seems it is time to change my trans fluid again. Last time i went with the GM syncromesh, it worked fantastic but i ran into a issue this weekend. back to back runs in the higher rpm range left my shifter notchy and hard to shift. had to let it cool down a good bit before i could shift it normal again. So my question is what fluid should i use that would withstand mid to high rpm runs - ie road course, autox, drift and so on. it could be it just needs to be changed, cause i did it last year about 10000 miles ago, but i do track the car. so im sure its time again but i just wanted to know what yall thought.
-nathan
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 06-08-2009, 09:44 AM   #2
Re: what trans fluid
I just bought the sycromesh stuff (if you buy it again, buy the penzoil sycromesh as it is the same as the GM stuff only 1/2 price...penzoil makes the GM stuff). It could just be that it is time for a change like you said....
Old 06-08-2009, 09:46 AM   #3
So you wouldnt use the royal purple sycromesh? and the penzoil is still syntheic?
Old 06-08-2009, 09:55 AM   #4
Y2E0L0L5OGWT's Avatar
I run royal purple synchromax and have nothing but good things to say about it...I put it in last year, about 12,000 miles ago and shifting still feels just as crisp & smooth as it did then...
Old 06-08-2009, 09:57 AM   #5
The penzoil IS the GM sycromesh...in a different bottle...without the GM name tax.
The royal purple stuff I've heard is good...and I've heard is dangerous to your trans. But, that's the case with anything you want to use. It seems it is hard to get a definitive opinion as if someone doesn't use it, then it must suck. You could try it though and it will probably feel like the GM stuff for a long time...
The problem is, whatever you use may take a long time to start feeling like what you are describing. The GM stuff took 10000 miles you said....so...the next may take that long too.
Old 06-08-2009, 09:57 AM   #6
after reading about gm syncromesh its not good for some components in some transmissions, the T-56 that the camaro and corvette use have different blocker ring materials and such and in the T-56 or what have you in our cars its not good for it~ just research before you put it in, OEM for fluid changed regularly will work fine.
Old 06-08-2009, 10:00 AM   #7
Well, since he has a 5 speed...he's covered.
And I did research before I bought it...
Old 06-08-2009, 01:00 PM   #8
so your running the risks?
Old 06-08-2009, 01:03 PM   #9
That would be a safe assumption.
Old 06-08-2009, 08:28 PM   #10
I too am running Penzoil Synchromesh. Read up on it and decided it would be best for what I'm wanting.
Old 06-08-2009, 10:01 PM   #11
Sounds like you just destroyed your trans too...just like me.
Old 06-09-2009, 04:31 AM   #12
jimmy_beaner's Avatar
Region: Iowa
I've got Redline D4, and my shifting became noticeably better when I switched to it. It's supposed to be for high RPM shifts and what-not I guess.
Old 06-09-2009, 07:04 PM   #13
To be honest I haven't noticed any difference. Then again I changed the clutch, resurfaced the flywheel, put a firewall adjuster and a quadrant on there...so it'd be hard to tell a difference.
I do know I can shift a hell of alot better after adjusting the clutch where I want it now. Have not noticed a difference in the shifter.
Old 06-09-2009, 09:08 PM   #14
So did my quadrant work out for you then? If so, sweet. It was definitely the right price for you.
Old 06-10-2009, 06:38 AM   #15
im gonna need help installing mine here soon.
Old 06-10-2009, 07:05 AM   #16
SaleenFiend's Avatar
I have a UPR speed hook if you don't already have one. The clutch adjuster and quad is a simple install. I went back with Motorcraft Mercon V and I felt a huge difference in the transmission after just changing the old fluid. Can't go wrong with the factory stuff, and I find it hard to believe that a fluid makes a huge difference...
Old 06-10-2009, 07:58 AM   #17
^^^ I put a V of something in mine...I think it was Mercon...and now the trans is notchy as hell....no where near as smooth as it was before the swap.
Old 06-10-2009, 08:20 AM   #18
what exactly is the speed hook? i have the steeda quad and firewall adjuster thou
Old 06-10-2009, 08:36 AM   #19
It's like the steeda quick release. It's a single hook quadrant with a quicker ramp up ratio. It is something you would need if you got the MM clutch pedal height adjuster. I had to get the steeda one, didn't know UPR had one.
And I can help you install that quadrant. It's pretty simple...specially if you take out your front seat.
Old 06-10-2009, 09:00 AM   #20
Well the front seat weights all of 18-20lbs now so thats no problem
Old 06-10-2009, 01:03 PM   #21
A single hook quadrant.
Triple: (what I have w/cable on 2nd hook)
http://www.sullivantuning.com/upr/im...THsilv_hme.gif
Speed release:
http://images.channeladvisor.com/Sel...se_lrg-new.gif
Old 06-14-2009, 04:33 PM   #22
i always liked to use royal purple synchromax in the winter since it is naturally thinner but during the hotter months i would use pennzoil synchromesh
jroc07gt is offline   Reply With Quote
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
Trans fluid pressure problem? Otlaw80 1979-1995 Mustang GT 1 05-24-2009 03:56 PM
Maybe I Need Blinker Fluid nay's mustang 1979-1995 Mustang GT 6 02-10-2009 04:50 AM
Tranny fluid 97conv6 Pre-2005 V6 Mustang 12 09-08-2005 09:52 AM
05:11 PM
