Mustang PATS system? - Mustang Evolution
Old 06-16-2009, 10:56 PM   #1
im having some problems with my anti theft system. i went into the store and when i tried to start up the car nothing happend the only thing was a blinking theft light. i tried disconnecting the battery (which was bought about 3 months ago) and it did not work. the only way i got her to start was by someone giving me a boost. this happend to me a VERY long time ago but as been free of incident for over 2 years is there any ideas why the car is not starting or any way of starting her back up?
kenneth01GT is offline   Reply With Quote
Old 06-17-2009, 07:05 AM   #2
2007STANG's Avatar
Region: West Virgina
Re: Mustang PATS system?
If it was the theif system getting the car jumped wouldn't have helped
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 06-17-2009, 09:50 AM   #3
thats what i figured but i tried fully charging the battery and and alternater is in great shape well i got it tested at 100 000 kms anyway and it's only at 114 000 thats why im a bit stumped
Old 06-17-2009, 01:36 PM   #4
Herbstang's Avatar
Ford uses a PATS system (passive anti theft system). There is an electronic device in the key that communicates with the power train control module (PCM) to allow the car to start. The signals are relayed through a device in the steering column that may be malfunctioning in this car. Try tilting your wheel in different positions and see if it won't start. could have broken wires
The transceiver is easy to replace.
1. Remove the plastic parts around the steering column
2. remove the lock cylinder. Put the key in and turn it to run and push in on the retaining pin with a punch or similar tool and pull the cylinder out.
3. remove one screw and remove the transceiver and disconnect the wiring connecter. The transceiver sits in the hole the lock cylinder goes in.
4. install the new one and put it back together.
Old 07-01-2009, 02:51 PM   #5
Try Black Cat Anti theft system. It is one of the best in present time. I am using it from 2 yrs.
Looking for HID Kits
Nice Place for HID Conversion Kits
Look For Your Motorcycle HID Lights
caryabhi is offline   Reply With Quote
Old 07-07-2009, 09:39 AM   #6
thanks everyone i guess my key just needed to be replaced i just happend to get luckey when it was boosted im considering taking out the theft system...well over riding it with a tuner
PATS, 2001 V-6 Mustang 860stevenp Pre-2005 V6 Mustang 16 12-05-2005 06:40 PM
PATS system natebest2000 Pre-2005 V6 Mustang 10 03-03-2005 01:26 AM
w00t, pats 13-2 Rellik The Bar 4 12-27-2003 08:18 PM
pats pats pats! Rellik The Bar 14 08-08-2003 05:04 PM
11:47 PM
