Waxin the engine bay?? - Mustang Evolution
Old 06-18-2009, 04:10 PM   #1
SVTCOBRA's Avatar
I dont know how many times a week or month you guys clean your mustangs but my is almost always cleaned.(Some say it is washed more than it is drivin)
It is washed about twice a week and waxed every two or so weeks. I was woundering if anyone has waxed the engine bay and maybe even power wash it(I just get a wet rag and some soapy water and wipe it clean).Is it is ok to power wash the engine bay? Should I cover up all the electrical stuff if I power wash it?
SVTCOBRA is offline   Reply With Quote
Old 06-19-2009, 07:44 AM   #2
Re: Waxin the engine bay??
washing with water runs a risk of messing up the electronics. If you can keep those from getting wet then it should be ok.
I would only use water if its so nasty that you dont have a choice. They say to leave the car running while you do this but im not sure~
I clean mine by hand~ you can wax the paint if you wanted to but mostly its not clear coated so it wont do much. I would just keep it clean every week or so wipe it all off to keep it near perfect.
Old 06-19-2009, 10:58 AM   #3
A dry rag and some engine safe cleaners will do the trick if it's really dirty. Never dull works good on the chrome accessories, especially the piping (works really good on exhaust). I clean in the engine bay every time I wash the car. Just remember to be careful when cleaning around the wiring and connections...you don't want to accidentally unplug something or pull a wire connection apart.
Old 06-19-2009, 11:57 AM   #4
SaleenFiend's Avatar
If you want you could try the spray on as you dry wax stuff?
Old 06-19-2009, 12:11 PM   #5
SVTCOBRA's Avatar
Ok so there are engine safe cleaners. What name brand or company makes this.
Old 06-19-2009, 12:26 PM   #6
I use meguiars interior detailer, it says safe for electronics so you can spray it on things that you would have to worry about shorting out.
Old 06-19-2009, 02:18 PM   #7
SVTCOBRA's Avatar
Thank you Mr. SpectorV
Old 06-19-2009, 03:09 PM   #8
Super Clean works good on the valve covers and radiator cover, as well as other black surfaces and places that hold dirt and grime. I spray it on the rag and then apply the rag to the surface, I don't spray it directly on the engine pieces. It works good, but do it when the engine is cool, don't let it remain on the painted surfaces.
Old 06-19-2009, 03:58 PM   #9
plus the interior detailer from meguiars is not greasy~ its good after its all nice and clean to keep it that way.
Old 06-19-2009, 04:01 PM   #10
I see you trying to get that thanks...
Old 06-19-2009, 05:46 PM   #11
uhh...me no I'm just trying to contribute whatever knowledge I've gained through personal experience and others to fellow 'stangers, in the hope that they will use this knowledge to better their mustang experience...the thanks is just a way for people to show gratification for my contribution
Old 06-20-2009, 07:01 PM   #12
SVTCOBRA's Avatar
well I have tried SpectorVs way (with the meguiars wipes) and it worked well, my neighbor walk by and busted my balls about how much I clean my car and when I showed him the engine bay it only added fuel to the fire. So it must look good .Next time Ill try your way sonicpony03. Thanks for the help you guys.
Old 06-20-2009, 08:21 PM   #13
Anytime friend. The meguiars is probably fine since you keep up with cleaning the engine. When I first started cleaning mine, I used some super clean to get the heavy grime and dirt that accumulated...same with my buddies GT. I think you'll be fine with either way...
Eagle One "Nevr Dull" works amazingly on chrome. My tips looked brand new after using some of it, same with the emblems...I highly recommend it ~ $4.00+ a can.
Old 06-20-2009, 11:15 PM   #14
upton7's Avatar
I don't know how everyone else does theirs. But I worked for a dealership and I washed the cars and i would lightly go over it with water once then wash it softly with a regular mit and soap then i would rinse it off with as little amount of water as you can then dry the plasics and anything else that may need dried. I never had a car not start afterwards.
Old 06-20-2009, 11:30 PM   #15
SVTCOBRA's Avatar
Originally Posted by upton7 View Post
But I worked for a dealership and I washed the cars.
My uncles friend owns a Ford dealer and he let me work there and wash and drive all the new Fords except the GT500 did it for free just so I can be around my beloved Ford.
Old 06-21-2009, 03:01 PM   #16
upton7's Avatar
this was a used car dealership/ repair shop
Old 06-21-2009, 03:54 PM   #17
SVTCOBRA's Avatar
NO a FORD dealership New and Used cars
Old 06-21-2009, 06:02 PM   #18
upton7's Avatar
what i'm talkin bout where i worked
Old 06-21-2009, 09:29 PM   #19
I wash my engine bay with diluted simple green or greased lightning and a rag...then rinse it off. I will do this after letting the engine get to operating temps...then wash and rinse off with the misting setting on the hose nozzle. Then I will use the air hose to blow out excess water, then start the engine again and let it run for 5 minutes. Then I'll wash the rest of the car. When done I will do all the painted parts with zaino...but only when I wax the car as well.
I haven't done this as much as I used to, but will start to again soon...the car needs one of my special in depth details again soon.
Old 06-22-2009, 12:06 AM   #20
SVTCOBRA's Avatar
Oh sorry my bad man. I got alittle jumpy.
First pictures of my engine bay? MonteCitan Pictures and Videos 18 09-20-2006 09:06 PM
Cleaned up my engine bay the other day Zim Pictures and Videos 12 03-30-2006 10:01 AM
cleanin engine bay.... tedness The Bar 22 07-02-2005 05:38 PM
Engine Bay Cleaning bluemustang Mustang Audio & Video 17 04-28-2005 05:53 PM
Engine bay or interior? Dom Mustang Audio & Video 8 08-27-2004 03:07 PM
02:39 PM
