Lowering Roush? - Mustang Evolution
Old 07-15-2009, 09:16 PM   #1
StgRsh's Avatar
Lowering Roush?
I know lowering a Mustang yields great handling benefites, but will it be fine with a Roush body kit.
The sideskirts sit only 5in. off the ground. Who would lower it?
StgRsh is offline   Reply With Quote
Old 07-16-2009, 10:41 AM   #2
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: Lowering Roush?
depends where you drive it, to get out of my parking lot i have to go over about a good 2 in drop on to some uneven road, getting out of the drive way might be good, but getting back might be another story.
if you do it, just be aware of the roads, a little dip here or there if big enough will scrape that. I think i have seen lower though, it just really depends on where you drive it.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-16-2009, 11:00 AM   #3
Re: Lowering Roush?
it will have greater potential for scraping without a doubt, probably will scrape on the back edge of it. do you see anything lower under your car or is that the lowest part
Old 07-16-2009, 11:08 AM   #4
StgRsh's Avatar
Re: Lowering Roush?
There are the two screws holding up the exhaust that are 4in. off the ground
Old 07-16-2009, 12:40 PM   #5
Re: Lowering Roush?
yea, you may can go an inch or maybe 1.25 but expect scrapes now and again
Old 07-16-2009, 07:33 PM   #6
LilRoush's Avatar
Re: Lowering Roush?
Why not use Roush springs to lower the car? Stage 2 and 3 cars all got a suspension upgrade with that same body parts.
~Matt
2000 Roush #5004 M112'd V6
1970 Mach 1 351W 5 speed swap
2001 Explorer Sport 4.0L
LilRoush is offline   Reply With Quote
Old 07-16-2009, 09:52 PM   #7
Re: Lowering Roush?
This is how low my car is...and it's easily daily drivable, just bottoms out alot lol.
When I get the car back on the ground this weekend I'll measure from the sideskirts and then from the lowest point.
Old 07-17-2009, 08:48 AM   #8
Re: Lowering Roush?
the side skirts on 03/04 cobras are not the issue, the cats hang lower. My cross member brace (verts only) is my issue, that sucker hits everything
Old 07-17-2009, 10:35 AM   #9
StgRsh's Avatar
Re: Lowering Roush?
LilRoush, I called Roush and their springs only lower it 1.2 in front and .8 in back. It sounds pretty decent. However, their shocks ($700) are "specifically tuned for the car", but I don't think they even come near the quality of Koni's.
Old 07-17-2009, 10:37 AM   #10
Re: Lowering Roush?
Yeah, my cross brace hits everything too...well, everything in the land fill. Mine disappeared a long time ago...but it did take a beating when it was on there.
Old 07-17-2009, 07:29 PM   #11
LilRoush's Avatar
Re: Lowering Roush?
Koni's are crap compared to how well matched the Roush springs and the Roush spec Bilsteins are. They drop the car about 1.5" once it settles.
~Matt
Old 07-17-2009, 09:11 PM   #12
Y2E0L0L5OGWT's Avatar
Re: Lowering Roush?
No. That's the most ridiculous thing I've ever heard. Btw, for what it's worth, Jack Roush's son races in the Koni Challenge Series in a Mustang with a Koni suspensions...Just FYI....
Old 07-17-2009, 09:16 PM   #13
Re: Lowering Roush?
if you like koni's thats fine just have the valve on them for valved to match the rate of the spring
1.2 inches aint very much really, you will want more but you are being wise to hold off due to the side skirts being so low
Old 07-17-2009, 10:17 PM   #14
LilRoush's Avatar
Re: Lowering Roush?
I was talking about slapping on some off the shelf Koni dampers vs. using the Roush suspension designed to work together.
And I'm very aware of the Koni Challenge. The Roush family is into more or less all automotive racing these days.
~Matt
Old 07-18-2009, 04:29 PM   #15
StgRsh's Avatar
Re: Lowering Roush?
The Roush spring/shock kit is $1000, completely overpriced for what it is. I would get the Koni suspension package, but it lowers the car too much. My original plan was to put the Roush springs on the Koni's, but they aren't compatable.
Don't know if i'm over reading into it too much or if I should man up and buy the damn thing.
Old 07-20-2009, 04:51 PM   #16
LilRoush's Avatar
Re: Lowering Roush?
Where are you seeing that price? Sounds more like the full out package, not just shocks/struts.
Ever driven a car with the Roush suspension package? Or what are you using to compare performance to price?
~Matt
Old 07-21-2009, 11:26 AM   #17
StgRsh's Avatar
Re: Lowering Roush?
The Roush store online sells the shocks/springs individually that add up to a grand. However I was looking on carparts.com and found the shocks and struts for $600 and Troyfordracing.com selling the springs for $186.
The only concern I have is lowering the car too much.
If I don't like the amount it drops, do you know where to get spacers?
Old 07-21-2009, 12:13 PM   #18
LilRoush's Avatar
Re: Lowering Roush?
If it drops too far, put the stock stuff back in.
Check out Stage 3 Motorsports for Roush goodies. They usually have the lowest prices, and back everything with amazing customer service.
~Matt
Old 03-18-2010, 05:32 PM   #19
Re: Lowering Roush?
Well my roush came like it is from the factory but na it will be ok but you are gonna scrub every where and the front lip is gonna be fukin aggervating to keep from hittin **** and scrappin the ground. And lowering a mustang gives it awesome handling by the way....
TheBestRoush is offline   Reply With Quote
Old 03-18-2010, 07:50 PM   #20
LilRoush's Avatar
Re: Lowering Roush?
I know this is an old thread that got bumped, but based on the other thread, I just realized a MAJOR fact that wasn't in this one. You have a V6. Roush's V6 springs are made to work with the factory dampers that came on the car from Ford. The Stage 1 V6 suspension was the springs and addition of the rear sway bar (same as the GT). There are several variations of the Roush spring for the V8 cars, but I wouldn't use any of them on a V6 unless you have major suspension work done.
You don't need high dollar dampers to match the springs, and they'll give you a good look and still be able to drive on the street without hitting all the time.
~Matt
Old 03-18-2010, 09:43 PM   #21
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
Re: Lowering Roush?
I have the Roush Lowering Springs if any one is intrested. They are brand new never installed. Because the small they offer on the V6 I want something bigger.
Send me a Private message and maybe we can swing a deal.
SaturnMan8227 is offline   Reply With Quote
12:28 PM
