03 vert - Mustang Evolution
Old 08-13-2009, 09:32 PM   #1
redcobravert's Avatar
03 vert
I ran a 12.40 at 120 with bolt ons stock springs stock irs they are killin me
redcobravert is offline   Reply With Quote
Old 08-14-2009, 07:50 AM   #2
Re: 03 vert
you need to replace the bushings in the IRS with: http://www.fulltiltboogieracing.com/
and lower the car with a stiff spring like H&R race and go with at least coupe (03/04 cobra coupe) shocks/struts as they are stiffer than the verts)
This is high on my priority list, but since I dont go to the track its not something I have to do ASAP.
oh and you had best have an IRS brace.
Old 08-14-2009, 08:00 AM   #3
Re: 03 vert
I have the a brace but the first one failed me with my stock tires it was a steeda brace it was metal and ended up bending from the wheel hop and cracked the rear diff cover and that wasnt very fun to replace. I now have a billet brace and a set of 315 nittos on the rear and i havent had a problem yet.
Old 08-14-2009, 08:14 AM   #4
Re: 03 vert
sounds good, from everyone Ive talked to the delrin rear end bushing kit (do NOT go with any polyurethane crap) is amazing when done for track or for autox.
OH, not sure how I forgot but if you do not have full length subframe connectors GET THEM YESTERDAY! lol they make a HUGE difference in wheel hop, and just normal drivnig (95% of my creeks and pops left after subframes)
Old 08-14-2009, 08:19 AM   #5
Re: 03 vert
damn i will have to look into that i just have the stock ones. who makes a good set of those
Old 08-14-2009, 08:39 AM   #6
Re: 03 vert
many companies but I pesonally would go with maximum motorsports full length or griggs full length. Other companies have them but generally they are weak and are not very good.
YOU must go full length and ONLY weld on (not bolt on) and they must be welded on on a drive on lift (well they can be done on a 4 post but you MUSt make sure every seem in the car is correct before you weld when the car is in the air which takes time~ a drive on is the fastest way)
You can get powdercoated BUT they have to be sanded where they are welded so get bare steel and coat the **** out of them with rust proof paint.
My buddy's '94 GT 'vert: MarkuzLS1 Pictures and Videos 7 04-11-2007 10:45 AM
03 SVT Vert FS Riversnake Mustangs for Sale and Wanted 3 09-29-2006 09:40 PM
anybody want an 05 yankees v6 vert Dark02Pony The Bar 30 10-26-2005 12:18 AM
90 gt vert f/s cheap scott8950 Mustangs for Sale and Wanted 13 08-29-2005 04:06 PM
luv my 'vert fumble_buck New Member Introductions & Greetings 24 01-25-2005 06:57 PM
09:06 PM
