Gears..? - Mustang Evolution
Old 08-29-2009, 03:44 PM   #1
Gears..?
This is just a question, I'm not really looking to do this to my car.
I see lots of posts about getting new gears and such and they usually are somethin' like 3.73. What does all this mean? I'll admit I'm not the most car savvy person
ThaBear14 is offline   Reply With Quote
Old 08-29-2009, 04:37 PM   #2
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: Gears..?
It's a ratio. For every 3.73 turns of the driveshaft, the wheel will turn one time. Numerically higher gear sets will give you better acceleration out of the hole, but you'll sacrafice by running at higher rpms for a given speed. That's my real quick explanation
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 08-29-2009, 11:30 PM   #3
OsirisGuy's Avatar
Re: Gears..?
^Yup, dead on.
If you sat under your car and turned the driveshaft 3.73 turns (think 3 turns and just under 3/4 of the fourth rotation) the back tires will fully turn once (one revolution). good to know if you ever have to figure out gears. This would be for 3.73 gears.
3.73, 4.10, etc... are all just a sort of shorthand. It's really a 3.73:1 ratio, or 4.10:1 ratio.
The steeper (higher ratio) of the gear, the quicker your car will accelerate. This is the only real benefit for them but it really is an amazing benefit. They will not add horsepower and the only real negative side effects include going through the gears faster because of the higher RPMs and your gas mileage may also be affected by 1 or 2 MPGs. Some drivers have reported an increase by this much though as well.
As a rule of thumb manual transmissions will upgrade to the 3.73 while automatics will go for the higher 4.10 but it's up to personal preference on which ratio to choose, and there are plenty of other options out there too.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 08-30-2009, 09:07 AM   #4
Re: Gears..?
Alright thanks guys that makes perfect sense now.
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
3.73 gears tim11 Pre-2005 V6 Mustang 5 10-25-2005 08:21 AM
4.10 gears powerhungry966 Pre-2005 V6 Mustang 7 10-23-2005 06:53 PM
gears 8.8 or 7.5 strike1980 Pre-2005 V6 Mustang 5 07-31-2005 11:05 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
10:10 PM
