Good Combination? - Mustang Evolution
Old 09-29-2009, 09:34 AM   #1
Good Combination?
351W- bored .030 over 393ci
Carb. - 750 cfm holley
Heads- Ford Aluminum Performance cylinder heads
210CC intake runners
60CC combustion chambers
2.05 Stainless Steel once piece Intake valves
1.60 Stainless Steel once piece Exhaust valves
.600 valve springs with hardened valve keepers
Intake-351W Polished Dual Plane Aluminum Intake
180 degree medium high rise design
Rpm Range Idle - 6500
Intake Port Dimensions 1.87" x 1.06"
Cam-Duration @ .050" Lift:Intake-253 Exhuast-253
Valve lift intake-.54 exhuast-.54
Valve timing @.006" Open Close
Intake 43 BTDC 82 ABDC
Exhuast 82 BBDC 43 ATDC
Compression- 10.5/1
Stoker Kit-Eagle 3.850" stroke cast steel crank
5.956 Eagle I-beam 5140 steel rods
Speed Pro Hypereutectic flat top pistons
Speed Pro PREMIUM Moly file fit Rings
Clevite 77 Main , & Rod bearings
Just wanted some opinions. Thanks
mustangfan9969 is offline   Reply With Quote
Old 09-29-2009, 09:52 AM   #2
hottcobra's Avatar
Re: Good Combination?
sounds like a 420bhp engine to me.
Old 09-29-2009, 11:24 AM   #3
trying to get 450 to the wheels
Old 09-30-2009, 08:29 AM   #4
any help there?
Old 09-30-2009, 10:26 AM   #5
99 SVT Cobra's Avatar
I would say you are getting pretty close.
Bassani Off-road X-pipe, Magnaflow Catback, BOMZ Racing CAI, Smoked Tail lights, Black Projector Headlights
99 SVT Cobra is offline   Reply With Quote
Old 11-13-2009, 10:48 AM   #6
I don't think he is pretty close.
Perk Mustang Headlights
perk is offline   Reply With Quote
Old 11-13-2009, 04:36 PM   #7
1980rustang's Avatar
im building up a 351w too but im not going too radical cause i am still a kid and i wanna atleast live till i get married but i am trying to get more compression out of the engine its a 1972 so what could/ should do to it to raise the compression?
1980rustang is offline   Reply With Quote
Old 11-13-2009, 08:08 PM   #8
OsirisGuy's Avatar
To raise an engine's compression you have to increase the cylinder volume as opposed to the combustion volume. To increase cylinder volume you will have to bore out the engine or you could stroke the engine which is increasing the length the piston travels inside the cylinder.
To do either of these you should plan ahead and you'll need new internals. New crankshaft allows the piston to travel further. I believe the piston rods stay the same length though and you can change the the height (thickness) of a piston (I believe sometimes) unless you bore out the engine in which case you will need to get new pistons, larger diameter ones to be specific.
Just as an example, a lot of 302cid (5.0L) like to bore out the engine to a 306cid.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 11-13-2009, 08:20 PM   #9
see this is why i like collision its much easier!!
Old 11-22-2009, 12:33 PM   #10
CammedMystic's Avatar
I say yeah 430 420 sounds about right.
Fully Built Teksid Block Stage 10 Custom Comps Full bolts missing JLT and 2.8 Kenne Bell
Want to hear the Cams go here
http://www.youtube.com/user/MysticCobra04
CammedMystic is offline   Reply With Quote
So Tivo and Comcast? Anyone have the combination? Brent The Bar 1 05-12-2008 09:37 PM
Good place, good prices? crazeflier07 Pre-2005 V6 Mustang 6 11-09-2006 07:48 PM
exhaust combination: tedness Pre-2005 V6 Mustang 5 09-05-2005 02:01 PM
Color combination help!!! CCstang2004 Mustang Audio & Video 20 07-01-2005 02:54 PM
this combination of purchases: tedness Pre-2005 V6 Mustang 12 03-16-2005 07:59 AM
05:50 AM
