Knocking noise - Mustang Evolution
Old 10-12-2009, 09:49 PM   #1
Foxone's Avatar
Knocking noise
Ok, I installed new struts and shocks this weekend. My strut mounts were in good condition, really just replaced cause the car has 116K on it. Im getting a knocking noise when the wheels drop down in front, like coming out of a driveway, sounds fine going over bumps. What should I look for? Could the sway bar bushings be worn out?
Foxone is offline   Reply With Quote
Old 10-12-2009, 11:35 PM   #2
Send a message via AIM to dtbback
Re: Knocking noise
Well my first silly but neccesary question is did you buy OEM parts or aftermarket. the second is that if you are hearing a knocking noise when the wheels are dropping out it might be a shock problem. Like they are dropping out too much. I think? Anyway i am sure others will chime in. Ohh but another silly suggestion. Make sure that you double checked tightening everything and that you had a good seat for your struts when you do.
dtbback is offline   Reply With Quote
Old 10-13-2009, 07:43 AM   #3
Re: Knocking noise
did you tighten the strut nut correctly where it goes through the CC plate (into the engine bay) that has to be TQ'ed correctly and can only be done with an impact since... you spin the shaft of the strut doing it by hand and get no where (unless it has a slit or a way to hold the shaft still while you tighten the nut)
Other than that make sure the bolts on the stock CC plates are tight (TO SPEC no tighter to prevent issues with breaking bolts)
The only other catch is where the strut bolts to the knuckle~ recheck your bolts to make sure.
Old 10-13-2009, 05:42 PM   #4
Foxone's Avatar
Re: Knocking noise
I used a basic Gabriel replacement since I was short on cash. I tightened the nut fully, pretty sure everything is tight, but I guess Ill double check, the setup is totally stock. Im wondering, does the OEM strut have a bumper inside to absorb the shock that the gabriel does not?
Old 10-24-2009, 09:47 PM   #5
Foxone's Avatar
Re: Knocking noise
When in doubt, rip it out! I replaced the ball joints, sway bar bushings, new brakes, rotors and now it sounds like a new car going over bumps.
Old 10-25-2009, 07:55 AM   #6
67mustang97's Avatar
Region: Vermont
Re: Knocking noise
You could check your say bar links.
Old 10-28-2009, 10:38 PM   #7
Foxone's Avatar
Re: Knocking noise
replaced those to.
« REP'N | 4 Banger »
Engine Knocking NotoriousSPG Pre-2005 V6 Mustang 10 07-08-2010 04:42 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
05 GT front end knocking noise texastosh 2005-2010 Mustang GT 2 09-01-2007 01:57 PM
Knocking 3.8 Skip Fix Pre-2005 V6 Mustang 5 03-31-2007 09:26 PM
Knocking engine Black Panther Pre-2005 V6 Mustang 25 11-02-2004 06:57 PM
10:43 AM
