Post your Autocross Setups - Mustang Evolution
Go Back   Mustang Evolution > General | Audio | Detailing | Wheels | Track | Regional > General Mustang Discussion
Closed Thread
Old 08-17-2005, 11:22 PM   #1
tedness is unknown around these parts
Send a message via AIM to tedness
My autocross setup:
Mustang V6 Platform
Drivetrain
- Steeda Tri-Ax Shifter
Suspension
- Maximum Motorsports Caster/Camber Plates @ -1 Degree Camber
- Tokico HP Blue Shocks/Struts
- H&R Super Sport Springs @ 1.75" 700-760lbs front / 1.60" 275-300lbs rear
- Prothane Front/Rear Spring Isolators
- GT Rear Sway Bar
Wheel/Tire Combination
- 17x9 Cobras w/ 275/40/17 Hankook Ventus HRII tires
tedness is offline
Old 08-20-2005, 09:51 AM   #2
Senior Member
Tbird232ci's Avatar
Tbird232ci is unknown around these parts
Re: Post your Autocross Setups
are you running anything in the name of performance brake pads? ive hear the Green Stuff pads are great
Tbird232ci is offline
Old 08-20-2005, 11:04 AM   #3
Terminator Owner
SpectorV is just getting started.
you can see what I have via my garage, but no autox tracks around.
SpectorV is offline
Old 08-21-2005, 04:44 PM   #4
lowflyn is unknown around these parts
V6 platform
Ford C springs
Tokico Bullitt s/s
Bullitt front and rear sways
MM 4 way adjustable -1 camber as well
Steeda monochromy midlength subframes
Toyo TPT's all the way around on my stock 16's.
Haven't hit an autox anywhere yet...trying to get on base to run the one there but I've heard it sucks. I gonna try sometime.
lowflyn is offline
Old 12-22-2005, 05:17 PM   #5
fastmustangs1's Avatar
fastmustangs1 is unknown around these parts
Thumbs up Re: Post your Autocross Setups
Here is my setup so far.
Kenny Brown front Springs
H&R Sport Rears
Kenny Brown strut tower brace,
k-member brace, pinion snubber
GT front and rear sway bars
GRC Performance Full-length subframes
Koni Sport Struts and Shocks
Maximum Motorsports lower control arms,
aluminum rack bushings
Energy Urethane Sway Bar, Spring isolators,
rear shock bushings
Prothane End-link kit
Front Camber at -1.5°
Rear Camber at -0.5°
Panhard bar and CC plates next.
Macunicorn on other stang sites
fastmustangs1 is offline
Old 01-08-2006, 10:31 AM   #6
Js281GT is unknown around these parts
maximum is the best. If you guys ever want any discounts let me know. I have a couple friends that work there.
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline
Old 01-09-2006, 09:37 AM   #7
Ran my first autox yesterday, man what a blast, at least I'm no longer a n00b. I dnf'd on 4 of my 6 runs though lol.
lowflyn is offline
Old 01-11-2006, 04:49 PM   #8
Horse is unknown around these parts
Send a message via AIM to Horse Send a message via Yahoo to Horse
Lets see, most of this is in my sig but here goes.
Maximum Motorsports coilovers w/ the aggressive spring rate. (stiffest you can have without race valved struts and shocks)
MM caster/camber plates _1.2* camber
bilstien shocks and struts
gt rear swaybar
GT quad shocks
T-loc
Hey Fastmustangs1, how did you get -.5* camber on your rear axle? You do an IRS swap or something?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline
Old 01-16-2006, 06:52 PM   #9
gt rear swaybar
GT quad shocks
T-loc
Thats a nice set up. Do the coilovers help alot? How much weight do you think you shaved?
Js281GT is offline
Old 01-20-2006, 02:53 PM   #10
Dark02Pony's Avatar
Dark02Pony is unknown around these parts
Send a message via AIM to Dark02Pony
ill 2nd that, i have green stuff pads with slotted and cross drilled rotors on my mustang and it stops on a dime
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline
Closed Thread
Sowela autocross 3/21 tigercrazy718 Regional Mustang Discussion 2 03-11-2010 03:08 PM
2 questions about mod setups... Impackt 1996-2004 Mustang GT 0 02-15-2007 07:15 PM
Question about exhaust setups fast dreams Pre-2005 V6 Mustang 11 05-21-2006 11:44 PM
Autocross Pics tedness Pictures and Videos 14 09-16-2005 10:04 AM
Warming up for AutoCross Ken The Bar 8 10-18-2004 12:14 AM
03:54 PM
