A/C squeak - Mustang Evolution
Old 11-14-2009, 06:24 PM   #1
Foxone's Avatar
A/C squeak
Is there a fix for a squeaky A/C? Mine squeaks at idle, even with the A/C turned off, and goes away as the car warms up, its not a constant squeak, intermitent. Clutch going out in it?
Foxone is offline   Reply With Quote
Old 11-15-2009, 09:55 AM   #2
67mustang97's Avatar
Region: Vermont
Re: A/C squeak
Are you sure it's coming from your ac? Is your defrost on when you hear the noise with your ac off?
Old 11-15-2009, 10:28 AM   #3
Foxone's Avatar
Re: A/C squeak
With it all off
Old 11-15-2009, 07:52 PM   #4
OsirisGuy's Avatar
Re: A/C squeak
Have you tried some belt dressing? Just to eliminate that.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 11-15-2009, 08:39 PM   #5
Foxone's Avatar
Re: A/C squeak
Nah, its comeong from inside the AC
Old 11-15-2009, 08:41 PM   #6
OsirisGuy's Avatar
Re: A/C squeak
Bad pulley? Are you running UDPs?
OsirisGuy is right
2002 Mustang GT
Old 11-15-2009, 10:10 PM   #7
Foxone's Avatar
Re: A/C squeak
Nope bone stock.
Old 11-16-2009, 07:29 AM   #8
Region: Vermont
Re: A/C squeak
Must be a bad compressor time for a new one.
Old 11-22-2009, 12:31 PM   #9
CammedMystic's Avatar
Re: A/C squeak
Sounds like the bearing in pulley
Fully Built Teksid Block Stage 10 Custom Comps Full bolts missing JLT and 2.8 Kenne Bell
Want to hear the Cams go here
http://www.youtube.com/user/MysticCobra04
CammedMystic is offline   Reply With Quote
Old 11-22-2009, 02:01 PM   #10
Foxone's Avatar
Re: A/C squeak
I wonder if you can replace just the bearing?
Strut Squeak greenpony02 Pre-2005 V6 Mustang 14 03-09-2010 01:21 PM
06 Rattle/ Squeak in front. 99ford Pre-2005 V6 Mustang 3 02-10-2010 08:09 PM
Rear Axel Squeak a3705872 Pre-2005 V6 Mustang 2 11-19-2009 07:36 PM
body kit squeak Warfire80 Mustang Audio & Video 9 11-15-2005 11:20 PM
Rear Squeak....Please Help!!! drzeusd Pre-2005 V6 Mustang 3 10-20-2003 02:44 AM
10:20 PM
