which 5.0 to use - Mustang Evolution
Old 11-15-2009, 09:27 AM   #1
Region: Arkansas
which 5.0 to use
i posted this in the classic section with no luck maybe this will get a better response. im working on a restomod 70 mach 1. ive found a two motors (1)5.0from a late 80s mustang, its all stock with an automatic trans and un known miles $200 (2)5.0 with gt 40 heads from an explorer with 30,000 no trans $500-$700. i may buy both because they are so cheap. but are there specific year mustang 5.0s that are better or even some from other vehicles. by better i mean horsepower and durability, i dont have a lot to spend and i plan on driving the crap out of it. thanks
dhouse is offline   Reply With Quote
Old 11-15-2009, 09:53 AM   #2
67mustang97's Avatar
Region: Vermont
Re: which 5.0 to use
You may want to look for a 85 or earlier 5.0 then you wont have to worry about fuel injection. Are you sure you don't want to go with a bigger displacement engine you have a lot of room under your hood.
Old 11-15-2009, 04:26 PM   #3
outlawfrog's Avatar
go big....go big!
1996 GT, 5-speed, Moonlight Blue, Opal Gray leather, Flowmaster Cat-Back exhaust (Delta 40 series), BBK cold air intake & 75mm TBI, Super Chips programmer.
outlawfrog is probably right
Originally Posted by outlawfrog View Post
I might pull an "osirisguy", and make that my new sig quote!
outlawfrog is offline   Reply With Quote
Old 11-15-2009, 04:59 PM   #4
fast64's Avatar
I think he wants fuel injection
What year are the donor cars? You will want a 89+ Mustang for the MAF (instead of speed density). If the Explorer is 97.5+ it will have GT40P heads, which are desirable but I believe require a different exhaust manifold/header than older 302/5.0 motors
They are both very similar motors. The Explorer uses a different upper intake (similar - if not the same - as the intake on a 94-95 Mustang).
GO BRAVES
Old 11-16-2009, 09:22 AM   #5
Region: Arkansas
im looking for fuel injection. id love to go big but,i dont have the money and im not building it to be fast, im building it to be a daily driver. i dont know the year models of the donor cars but i know the explorer 5.0 does have gt heads. btw both motors come with the computers. thanks for all the help. im at the mock up stage and need to get this figured out. will all 5.0 use the same motor mounts???
Old 11-16-2009, 09:27 AM   #6
outlawfrog's Avatar
isn't there some sort of stamp or tag on the blocks, that you could use to ID the year, etc? with that, you'd be able to findout what need for motormounts and ****
Old 11-16-2009, 10:24 AM   #7
fast64's Avatar
If you use motor mounts for a '70 302, any 302 should bolt in.
Yes, the casting number behind the starter can tell you the year of the block.
GO BRAVES
Old 11-16-2009, 12:02 PM   #8
Region: Arkansas
i was thinking the 70 302 mounts would work. i have the original 351 mounts any chance these will work? ill have to check the blocks to find the years
Old 11-18-2009, 07:13 AM   #9
Region: Arkansas
im getting the 5.0 and trans thursday. even if its not the one ill use its good enough to mock it. ive done a little research and i think the 351 and 302 motor mounts are the same. im hoping to get it in by this weekend.
Old 11-18-2009, 01:50 PM   #10
Region: Vermont
You should be able to use the same motor mounts without a problem. 1965-1970 Mustang 289, 302, 351W, 351C; 1967-1970 Mustang 390, 428; 1967-1970 Cougar 289, 302, 351W, 351C. all use the same mounts as far as I can tell.
Old 11-19-2009, 09:13 PM   #11
Region: Arkansas
i got the 5.0 with the trans. i was told its out of an 89 model mustang. i have checked the block yet.
i mounted my old 351 mounts to the block today and hope to have it in the car tomorrow.
ill post pics of the motor tomorrow and maybe someone can tell me more about what i have.
Old 11-20-2009, 07:10 PM   #12
bbunt302's Avatar
87-92 is the ideal year range for 5.0s. They come with the forged pistons instead of the hypercraptastic ones.
Scary stuff.
Old 11-20-2009, 10:19 PM   #13
Region: Arkansas
that sounds good for me. it went in easier and qucker than i thought. i did it by myself in under 30 min.
i plan on rebuilding it but i dont want to do anything drastic mainly stock with some subtle upgrades. any suggestions, i dont want to spend over 1000 if i can keep from it?
Old 11-22-2009, 12:26 PM   #14
CammedMystic's Avatar
I would only buy a notch only because they do look cleaner than hatch and they 2800 pounds you cant beat that
Fully Built Teksid Block Stage 10 Custom Comps Full bolts missing JLT and 2.8 Kenne Bell
Want to hear the Cams go here
http://www.youtube.com/user/MysticCobra04
CammedMystic is offline   Reply With Quote
Old 11-22-2009, 02:26 PM   #15
fast64's Avatar
He's just wanted a motor
GO BRAVES
Old 11-22-2009, 02:27 PM   #16
Region: Arkansas
what??? i think your in the wrong thread... they didnt make hatchbacks in 70
Old 11-23-2009, 11:13 AM   #17
Untamed's Avatar
The 70 302 mounts will work for any 302 or 351. The 351W or 351M would be my pick.
Untamed is offline   Reply With Quote
Old 11-23-2009, 12:21 PM   #18
Region: Arkansas
yep they did. i got the motor in with the original 351 mounts.
Old 11-23-2009, 12:26 PM   #19
Untamed's Avatar
cool.
06:27 AM
