Tips on increasing HP in '91 2.3L??? - Mustang Evolution
Old 12-29-2009, 02:53 AM   #1
So, I picked up my '91 coupe for $500 ( clearly the better choice btw that or 92 civic). I know 4 cyl. are the babies of the family, but I would like to do some thing to increase the HP. Most performance parts are for v6 and up, but there's gotta be something I can do aside from a complete engine swap. Any suggestions other than "just be happy with good gas mileage"? Thx
mylil4banger is offline   Reply With Quote
Old 12-29-2009, 06:18 AM   #2
Re: Tips on increasing HP in '91 2.3L???
You could always stick a turbo on it, this would probably be the easiest HP boost..... butin my experience the 4 bangers are more expensive to get HP out of when you canbuild a very respectable 8 banger for under 2K (doing it yourself if you can)
msclecrmn is offline   Reply With Quote
Old 12-29-2009, 08:30 AM   #3
You can remove the inner cylindar from the intake tube to open up the intake a good bit. Other than that, anything you do is going to be minimum gains until you start looking at forced induction.
And I know what you mean. I have a 93 4 banger that I daily drive. The mileage is great (now that I fixed the ICM issue)...but man does the power suck going from a 600 rwhp cobra to a 75-80 rwhp fox. lol
Old 12-29-2009, 08:28 PM   #4
Yeah, I was actually looking for a 83-88 turbocoupe today to do a swap, or a universal turbo charge. I do all the work myself, but it would be cheaper to just buy a 5.0 than to swap to one. I did pick up a flowmaster delta 44 muffler w/dual outs and have a friend welding custom dual tail pipes. That should help a bit.
Old 12-30-2009, 09:07 AM   #5
arent they 88hp stock... at the flywheel lol or is it 105?
do an SVO 4 banger turbo motor or just enjoy the gas mileage.
Old 12-30-2009, 09:20 AM   #6
The 93's are 105. I believe they made that jump in 91ish or so. Before that, they were 88 at the crank.
Old 12-30-2009, 11:06 AM   #7
They are 105HP startin in '91 which is what I have...
Old 01-01-2010, 12:39 AM   #8
Cool Re: Tips on increasing HP in '91 2.3L???
Not really. You can't just bolt the turbo onto your N/A 2.3 but it's a simple and cheap matter to swap a turbo'd TC 2.3 into your '91. The outside dimensions of the motors are identical. Pull the Mustang's motor and drop in the TC's motor. Fabricate a simple mount for the VAM, swap the Mustang computer for an '87-'88 TC computer, make about 6 wiring changes at the computer harness connector, splice in the VAM connector and you're up and running with 200 hp. Add an intercooler, some mild headwork, Bob's log manifold and a 3" exhaust system and you're right at 300 hp. It's really very simple and has been done a million times.
Haven't dyno'd mine yet but I estimate I'm in the 350 hp range.
Happy New Year!!
evintho is offline   Reply With Quote
Old 01-01-2010, 08:59 AM   #9
Thnks for that. I was actually referring to bying a 5.0 being cheaper than swapping my 2.3 to a 5.0.
Old 01-01-2010, 04:53 PM   #10
MonteCitan's Avatar
It is also possible to use a ranger cam (different profile with more torque) cylinder head work/exhaust work..
But as has been previously mentioned - The turbo 4 would be the best bet, and a lot of 5.0s would be struggling to keep up with a few mods on said turbo motor..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-17-2016, 06:14 PM   #11
Here's some cheap help
I have a 93 2.3. A couple things that help are platinum plugs, coil packs from a 96-97 GT Stang, build a cold air intake with the filter inside the fender and a 94-95 GT mustang mass airflow sensor, lose the cat converter if you can, higher flow muffler with larger pipe, stock 94-95 GT mustang 19lb injectors and a boost in feul pressure to 48 psi. If you don't have it already, grab an 8.8 posi rear with decent gears from a gt fox(bolt-in). Later, look forward to a turbo from a turbo t-bird or svo.
Hitmanracing is offline   Reply With Quote
Old 04-18-2016, 12:12 AM   #12
Mile high JDF's Avatar
While this is great advice, this thread was started in 2009
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-21-2016, 01:17 AM   #13
So it was lol
increasing wheel size cash05_mustang Mustang Wheels & Tires 9 04-23-2006 12:05 AM
RANT: increasing number of bad drivers fast64 The Bar 33 03-11-2005 11:43 PM
SLP Tips and stock tips from 98 Cobra SVT_Rob Mustang Parts for Sale and Wanted 7 08-10-2004 09:08 PM
Increasing Top Speed megax29 Pre-2005 V6 Mustang 40 07-13-2004 09:51 PM
07:04 PM
