Roush Drama - Mustang Evolution
Old 01-11-2010, 07:49 PM   #1
StgRsh's Avatar
Roush Drama
Well....I wanted to put an x-pipe on my V6 '04 but all the ones that are available will not fit. The guys at roush said putting one on will require custom work and have a high risk of an exhaust leak.
ALSO Roush does have available X-Pipes but only fit the GT's in my year. I suppose it would be possible to have it fitted. However i live in California so I can't have a permanant weld 'cause i need so slap on the original catted y-pipe.
Any suggestions???
Screamin' Demon Coil Pacs, Motoblue pullies & harmonic balancer, Intake, HID w/ Angel Eyes, Eibach sway bars, Steeda Lower Control Arms, Custom X-Pipe
StgRsh is offline   Reply With Quote
Old 01-11-2010, 10:37 PM   #2
upton7's Avatar
Re: Roush Drama
You could try to get a muffler shop to make you one
Old 01-12-2010, 09:19 AM   #3
Re: Roush Drama
if you have a V6 people make off road pipes for them that bold up but it will require GT style catback to work~
Old 01-12-2010, 08:41 PM   #4
StgRsh's Avatar
Re: Roush Drama
It is a gt style Cat back but the mufflers are farther back w/ the roush system. Any type of midpipe that is curently on the market will not fit by just bolting it on.
Or should I modify a gt midpipe originally meant for the roush system?
Old 01-13-2010, 07:15 AM   #5
Re: Roush Drama
as long as the final result allows you to bolt up and unbolt so remove the catback from the mid section its not that bad.
Old 01-13-2010, 09:55 AM   #6
StgRsh's Avatar
Re: Roush Drama
Ok. i guess i can get the flanges cut off and replace it with a 2.25'' size to fit the stock headers...
Old 01-13-2010, 10:43 AM   #7
Re: Roush Drama
my H is like 2.5 and my catback is 3.0 and it works fine with the flanges so you should be ok~
Old 01-13-2010, 10:46 AM   #8
Re: Roush Drama
Are you sure your catback is 3? I believe stingers are only 2.5" all the way back.
Old 01-13-2010, 10:50 AM   #9
Re: Roush Drama
I was going to ask the same thing. I figured a 3" diameter would be too big, even for that supercharged car. Most aftermarket systems are 2.5" mandrel bent, at least mine is. Isn't the stock piping on the cobras 2.25" like the v6's and GT's?
Old 01-13-2010, 10:54 AM   #10
Re: Roush Drama
No, stock piping is 2.5" on the 03/04 cobras. The stingers bolt up with no issues to the stock mid pipe with no need for any reducer.
3" piping is good on cobras running higher boost levels, but I know someone with a 3" exhaust and it kind of resembles a V6 when they switch to 2.5" piping. It sounds hollow like there isn't enough air moving to fill the pipes until they get into boost.
Old 01-13-2010, 11:58 AM   #11
Re: Roush Drama
Coolio, good to know.
Old 01-13-2010, 12:14 PM   #12
upton7's Avatar
Re: Roush Drama
i got two and a half all the way from the downpipe to the tips is that to much?
Old 02-21-2010, 12:07 AM   #13
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
Re: Roush Drama
i have an x-pipe made for my side exit exhaust. since i live in cali i still have my cats. but any good muffler should be able to make an x-pipe to fit your exhaust set up no problem.
SaturnMan8227 is offline   Reply With Quote
Old 02-21-2010, 03:37 PM   #14
StgRsh's Avatar
Re: Roush Drama
yeah thats what i eventually did. I got the magnaflow X centerpiece and had the shop attach 2.5'' pipes to it
Old 02-21-2010, 07:59 PM   #15
Re: Roush Drama
i did the same thing. 2.5in from the cats back, no mufflers for me. i still have to get the roush tips and install the roush side skirts
Old 03-18-2010, 07:54 PM   #16
LilRoush's Avatar
Re: Roush Drama
Roush's V6 cat back is based on a Y mid pipe splitting into another Y feeding the pair of mufflers. If you use the GT flow pipes (between the mid pipe and mufflers), you can use any V6 midpipe that mates to a GT cat back. I'm running a Mac H pipe on mine right now. Bolted right up when I got rid of my X pipe. And FWIW, H or X doesn't matter on the V6.
~Matt
2000 Roush #5004 M112'd V6
1970 Mach 1 351W 5 speed swap
2001 Explorer Sport 4.0L
LilRoush is offline   Reply With Quote
Old 03-18-2010, 09:37 PM   #17
Re: Roush Drama
My "Roush Style" exhaust was for a GT not a V6. That's why I had the X-Pipe made. It was made by Borla for a Razzi Body kit. I got it for half the price it would have cost me to get the actull Roush V6 kit. The Borla Mufflers were to mild for me and I had them removed a while back.
Old 03-19-2010, 05:33 AM   #18
LilRoush's Avatar
Re: Roush Drama
If you had the Borla side exit for the Razzi kit, I wouldn't call it "Roush style". They are differnt bends to line up the tips correctly.
~Matt
Old 03-19-2010, 06:53 AM   #19
Re: Roush Drama
I have the Roush side skirts installed too. Now I have never seen a True Roush Exhaust system before install. But from what I can tell from what I have, the bends are the same. The tips are just different. Other then that, I had no issues with the install or fitment of the side skirt with my exhaust set up.
I never said I had a Roush Exhaust, I said "Roush Style" as in side exit. here's a pic. as you can see the tips line up fine.
Old 03-21-2010, 07:46 AM   #20
LilRoush's Avatar
Re: Roush Drama
Right side of mine:
~Matt
Old 03-21-2010, 09:37 AM   #21
Re: Roush Drama
The bends look better on mine. but the borla mufflers also look smaller. I removed the mufflers all together the borlas were way to quite for me.
is that the spintech muffler?
Old 03-21-2010, 11:22 AM   #22
LilRoush's Avatar
Re: Roush Drama
Spins on mine. I ditched the Magnaflows Roush uses in the first month after gaining a bit of rwtq with these. My pipes are beat to crap from years of racing and running them into the ground.
~Matt
Old 03-21-2010, 12:52 PM   #23
Re: Roush Drama
Cool. I was thinking about getting spins for mine. Don't get me wrong the car sounds great with out mufflers but I need something to make the police happy
Old 03-25-2010, 05:09 PM   #24
Re: Roush Drama
nice parts you got there
dwilsonjr74 is offline   Reply With Quote
Nascar Drama bluemustang The Bar 13 02-15-2007 08:40 PM
More Chavez Drama bluemustang The Bar 26 10-03-2006 04:49 PM
Drama... bluemustang The Bar 5 08-17-2005 01:28 PM
10:46 PM
