I have a question about times... - Mustang Evolution
Old 05-03-2006, 07:58 AM   #1
DarkShadow's Avatar
Send a message via AIM to DarkShadow
After reading EclipseGTSDude's thread about his times and reading a few others, I'm discovering that almost stock GT's run the same 1/8th mile times as me. How is that possible when I have almost 100 more hp than a stock GT? Yet, when I took it, to the track, there was a GT that was spraying that didn't have the top speed I had, don't know about times because they were just showing speeds that night. So what's going on? I would also have thought that with about 330 to the wheels I should be easily in the 8's if not mid 8's...? I know I don't build boost at all in first gear, but WTF? I also don't spin that bad out the hole. Yet I've beeaten stuff on the road that I know beats GT's like my buddies SRT-4. His best time that night was slower than my worst time and I know he beats GT's all the time badly...? What's up here?
DarkShadow is offline   Reply With Quote
Old 05-03-2006, 11:33 AM   #2
Re: I have a question about times...
there are many factors that come into play. 03/04 cobras dont run much better than mid 8s stock I dont believe~ (not 100% sure on that) and manage highish 12s stock in the quarter.
Until you get some practice in and get those numbers consistant and what not you will not know what the car can do. You should be cutting low 60fts (2.1~) etc etc. What were all the numbers on your slip when you went?
And just because you run 9.X in the 8th doesnt mean you will run 14.X in the quarter either you may be faster/slower who knows. Once does not 100% determine the other.
As it currently sits the auto is KILLING your times (and your power @ the wheels), with a tq converter, manual valve bodyshift kit, rear end gears, and good tires you would be amazed at the difference though.
Old 05-03-2006, 11:52 AM   #3
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Post your full slips again, if you don't mind. I can't remember what you had for 60' and mph and such.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 05-03-2006, 12:20 PM   #4
DarkShadow's Avatar
Best one:
Reaction: .5140
60 ft: 2.2670
330 ft: 6.1804
1/8 ET: 9.1896
1/8 MPH: 81.54
Next one:
Reaction: .1123
60 ft: 2.3209
330 ft: 6.2296
1/8 ET: 9.2214
1/8 MPH: 81.86
Last one:
Reaction: .1498
60 ft: 2.3408
330 ft: 6.2940
1/8 ET: 9.3265 (passenger)
1/8 MPH: 80.80
What do ya'll think it would do in a 1/4 track as is? I've heard that the MPH is the biggest factor in how powerful your car is, not neccessarily the ET...
I know I would benefit big time form a tq converter, I don't hardly spin at all in the box so I'm not sure if the tires are really a problem, I don't want to upgrade gears because that can actually hurt a FI car...I really think it's that no boost dead first gear that hurts it the most, that's why my 60ft is so bad...
Old 05-03-2006, 12:29 PM   #5
well with a 2.10 60ft you would shave off nearly 4 tenths~ (at least 3) alone. My bet is that you would be in the mid 13s as is~
Old 05-03-2006, 12:32 PM   #6
bbunt302's Avatar
#1) Those 60's are pretty bad. With a set of drag radials and an automatic (much less harsh on the tires than a manual at launch), you should be able to pull off at least a 1.8 60'. That's half a second right there. You'll probably actually lose more than that. They say that every tenth in the 60' is worth nearly two tenths overall (for a 1/4 mile track). I'd say you'd lose right around .7 seconds. Also since you have a turbo, you're gonna want to launch the car at a decent RPM. I've never raced an automatic though, so I can't tell you the best method to do so.
#2) Like Brandon said: torque converter and shift kit. Once again, I'm far from an expert on automatics. But from what I understand, they are very important to running decent times.
#3) Don't fear the gear.
Scary stuff.
Old 05-03-2006, 12:39 PM   #7
DarkShadow's Avatar
Yeah I do need to pull down that 60 ft, but I don't want to put drags on it because I don't want to buy a new rear end the next day. I haven't really been watching my rpm's, I need to. I think~ I've been launching pretty soft with the power braking, I'm going to try for a launch at around 3k this Saturday...
Gears can actually hurt the forced induction cars times because they don't put enough load on the blower, or something like that.
Old 05-03-2006, 12:48 PM   #8
Danger Dude's Avatar
Actually drag radials are not that bad on the 7.5 as much as big *** slicks. Since you are not building crazy HP at the bottom there is very minimal risk of major failure.
I am not sure I buy the not doing gears because of forced induction. Do you have open differential or a Tloc. I would consider getting a PATC Transmission like I have to help quite a bit at launch. I have a 2500 stall TQ and a PATC Interceptor 4R70W tranny
Old 05-03-2006, 12:59 PM   #9
bbunt302's Avatar
This is true. Plus the fact that automatics are no where near as bad as manuals on them. I think you should be okay, but I guess you never know with the 7.5s.
I also not to sure about the gears and boost deal... I know some people recommend lower (numerically) gears just due to traction issues, especially in set-ups where the boost comes in at low RPMs. However, a higher (once again, numerically) gear will get you into boost much quicker. If I were you, I'd have to at least put some 3.73s in there.
Scary stuff.
Old 05-03-2006, 01:07 PM   #10
I concur 100%
Old 05-03-2006, 01:11 PM   #11
if he can only brake TQ to 1500rpms~ what good will slicks do him if he doesnt break traction as he currently sits?
Old 05-03-2006, 01:36 PM   #12
DarkShadow's Avatar
Right, I think~ I've been launching somewhere around 2k without really breaking traction...
I've always been told by those who already had 3.73's put in or 4.10's that they don't allow the turbo/sc spool up enough. I've also been told by Andy and _J_, so forth that stock gearing is fine, maybe 3.55, but no higher than that....
Old 05-03-2006, 11:05 PM   #13
Dom
Dom's Avatar
Send a message via AIM to Dom
I would ask Matt and see what he is running out back.
Old 05-03-2006, 11:15 PM   #14
DarkShadow's Avatar
ET street drag radials I believe. I doubt he has the stock rear.
Old 05-04-2006, 08:20 AM   #15
your car would probably run slower times if you run slicks on your car as long as you are not having major traction issues. If you could rev her up to about 3k or 4k and launch on some DRs or Slicks you would run an AMAZING time.
Old 05-04-2006, 10:52 AM   #16
DarkShadow's Avatar
I'm thinking if I rev up to 3k or 4k I will have traction issues so better tires may help yet.
Old 05-04-2006, 11:07 AM   #17
well you currently can not do that, the tq converter wont let you
Old 05-04-2006, 11:36 AM   #18
DarkShadow's Avatar
Indeed.
Old 05-04-2006, 11:41 AM   #19
DarkShadow's Avatar
Someone give me a link already to a 3k stall converter. I've been trying to find one to no avail.
Old 05-04-2006, 11:44 AM   #20
MarkuzLS1's Avatar
Fuddle Racing
I like turtles.
Old 05-04-2006, 03:06 PM   #21
DarkShadow's Avatar
Hmm..how do those compare to the "PI Stallion 3000 stall" converters. The reason I ask is it seems that an offer for one with only 2oo miles on it has fallen into my lap. He is asking $550 shipped. I've heard good things about these, is that a good price? Because if these Fuddle's are good, that's still about the same price as a new one of those...
Old 05-04-2006, 03:19 PM   #22
MarkuzLS1's Avatar
Alot of the LS guys run 'em. I'm gonna get one, eventually. Don't know anything about PI Stallions, though.
I like turtles.
Old 05-04-2006, 03:26 PM   #23
Actually I have a TCI converter that came with the Interceptor tranny. If I had to do it over I would get a PI stallion
Old 05-04-2006, 04:02 PM   #24
MarkuzLS1's Avatar
Oh, Precision Industries. They make "Vigilante" converters for LS cars. They're supposed to be really good. They are damn pricey, though.
I like turtles.
Old 05-04-2006, 05:35 PM   #25
there is a good TC company local around here, they may be PI or PCI something like that~
Old 05-04-2006, 10:45 PM   #26
DarkShadow's Avatar
^Where? Where?
Old 05-05-2006, 08:24 AM   #27
PCI or something like that, search for tq converters in north alabama or alabama see what pulls up
Old 05-05-2006, 08:24 AM   #28
or put in a manual....
Old 05-05-2006, 05:17 PM   #29
DarkShadow's Avatar
Well I found out that the PI 3000 stall Stallion torque converter I was offered does have lock up, but it is not the multi disc with the 3 plate set up...
The seller said he has not heard of a 3.8 running the multi disc, but that is what everyone I have talked to has recommended and what I thought would be the best option. Please correct me if I am wrong.
He only wants $550 for it with 200 miles...
Old 05-06-2006, 09:25 AM   #30
DarkShadow's Avatar
Well I'm going back to the track tonight. I'm going to try out a few things and we will see how it goes.
Old 05-06-2006, 05:20 PM   #31
12second5.0's Avatar
Send a message via AIM to 12second5.0
Your 60 ft is terrible.You should be in the 1.8-1.7 range with a good set of drag radials.What exactly is your suspension mods?
12second5.0 is offline   Reply With Quote
Old 05-06-2006, 10:24 PM   #32
DarkShadow's Avatar
Well rain sucks. We called the track at 9:00 and when we got there at 10:00 it looked like no one had been there for a long time. I understand why though, it's just the whole getting ready thing and then oh sorry. Oh well.
As far as suspension, all I have are lowering springs and a Detroit Tru Trac. I'm looking into getting a rear sway bar pretty soon. Right now I don't want it bad enough to get a set of drag radials, I just wonder what I can do to get times down right now. Also how good are drag radials for every day driving and in the rain?
Old 05-06-2006, 10:29 PM   #33
They aren't very good in the rain.Lowering springs are hurting you because you most likely have no weight transfer.To add to that lowering the car also affects pinion angle which will affect how well your car hooks.
Old 05-11-2006, 11:05 PM   #34
DarkShadow's Avatar
Well me and a buddy officially stop watched my 0-60 time tonight.
From a dead stop with no power braking, it's about 6.1 on average, and this is factoring in about .2 seconds for me to move my foot from brake and stomp on gas and for him to recognize what I said and press stop.
Now with power braking my 0-60 was an average of 5.5 also factoring in the time it took me to let up the brake and him to stop the clock.
Now when I took it to the track, basically all I did was monitor all my systems EXCEPT rpm's and was focused on good reaction times, which apparently don't really matter as I'm just concerned with ET's. So I basically revved it a little and just punched it. But now if I make a concerted effort to power brake it up to just under 2k (where it starts breaking loose) I should bea able to shave that .1 second with no problem and be in the 8's easily as is. Now imagine that with a stall converter.
I will be going to the track for test and tune tomorrow night, Friday night as soon as my grad ceremony is finished. Anyone that wants to see possibly the first v6 stang to break into the 8's in the tri cities area (or further) come and see.
Old 05-12-2006, 01:17 PM   #35
his car is NOT capable of doing 1.7 or 1.8 60ft with any kind of tire he cant reve it any higher as its an auto lol.
1/4 times tim11 Pre-2005 V6 Mustang 5 11-01-2005 09:21 PM
New Best Times stangin99 Pre-2005 V6 Mustang 49 04-20-2005 10:01 PM
My Times timpryor Pre-2005 V6 Mustang 3 12-20-2004 12:38 AM
best times Fishers Stang Pre-2005 V6 Mustang 4 08-02-2004 03:21 PM
my times? timpryor Pre-2005 V6 Mustang 7 07-20-2004 10:11 PM
03:22 AM
