Dude... Am I the only hardcore autocrosser here? - Mustang Evolution
Old 06-27-2006, 07:07 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
This forum is dead. Which is a bummer 'cause I really like autocross and it'd be fun to swap driving tips and stuff. Anybody? Anybody at all?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-27-2006, 09:39 PM   #2
Re: Dude... Am I the only hardcore autocrosser here?
I haven't had the time this summer or the tires. Once I get some stuff settling down I'm gonna start hitting it again. I have one coming up next month I might make, and one in september I know I'm running at.
Old 06-27-2006, 10:21 PM   #3
Im sure you are not alone.
Old 06-28-2006, 12:44 AM   #4
timpryor's Avatar
once i get the cobra's suspension done i will start but that may take a while
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 06-28-2006, 06:30 AM   #5
i think it would be a blast... but i never hear of anything in my area. plus, i need to redo my suspension as well, but that should be happening shortly.
1999 3.8 V6 Electric Green Mustang
5 speed
Mods: MAC Dual Catback Exhaust, MAC Shorty Headers, CAI, Sequential Taillights, 03 17" Cobra Rims
My Garage
electricstang is offline   Reply With Quote
Old 06-28-2006, 09:06 AM   #6
Zim
You want to **** me?
Zim's Avatar
I just dont have the money for the tires and what not... wish I did. If I had the money, Id do open track stuff out in topeka though
I like toys
Old 06-28-2006, 12:20 PM   #7
I would love to but there is no local track and I wouldnt dare do it on my daily driver.
Old 06-28-2006, 03:18 PM   #8
We use parking lots and air force bases over here lol. Just set it up that morning and go for it.
Old 06-28-2006, 05:07 PM   #9
Region: Iowa
That's the way it is in the Quad Cities. Parking lots, air ports.... It's a blast.
Old 06-29-2006, 03:31 PM   #10
do you have your coil overs indexed.
Old 07-03-2006, 10:30 AM   #11
I just bought a car for this purpose , a 94 stang with the 3.8 . Someone did the springs and sway bars already and it has a k&n filter , duel exaust without cats, car sounds good motor seems solid ,car handles great!
BUT, I have a big problem ,
I have a major hesitation off idle ,
I have changed plugs and oil ( things I do when I buy a used car anyway)
cleaned the mas then swapped it with another ( a buddy owns a wrecking yard)
swaped the maf
swaped the air idle dealy
swapped plug wires
checked base timing (dead on )
swapped coil pack
cleaned throtle body
It sure feels like timing and I wonder if someone has installed a cam or timing cain and installed it one tooth out ( as a mechanic i have seen it done before)2:
any suggestions befor I tear it apart?
crash is offline   Reply With Quote
Old 07-03-2006, 11:09 AM   #12
welcome to the boards. Post this again in the correct forum and you will get a much better response.
Old 07-03-2006, 02:22 PM   #13
TY for the welcome , I have re posted my woes in another area, Hope to get some help there
Old 07-06-2006, 05:54 PM   #14
Region: Iowa
What do you mean indexed?
Hardcore Steeler fan.. wiarumas The Bar 11 01-23-2006 02:49 AM
friends prank dude, dude ****s himself... *WW* Zim The Bar 14 10-27-2005 09:26 PM
Hardcore Weight Reduction Dan Pre-2005 V6 Mustang 8 06-03-2005 08:28 AM
hardcore bush supporter V6STANG007 The Bar 7 10-28-2004 12:42 PM
So you think you're hardcore... WhiteStang99 The Bar 11 09-13-2004 09:18 PM
04:29 AM
