VMP Tunes the 07 Shelby GT500...505 RWHP - Mustang Evolution
Old 09-12-2006, 07:08 PM   #1
Today Jerry and myself got the opportunity to work on a gentleman's brand new GT500. With just over 1000 miles on the odometer the car still smelled like new.
All runs were done on an industry standard Dynojet 224x, you can't fudge these #s like other dynos. 93 octane pump fuel was in the tank.
We ran the car 3 times stock to get the drivetrain up to temp and get a good average HP #. The car made 421/438, then 424/427, and 419/22. I would say the blower and engine are very sensitive to heat soak.
On every run we monitored air/fuel with two widebands, boost after the blower/intercooler, and restriction before the throttle body. We also datalogged a myriad of parameters with the SCT X-Cal2 and Live Link datalogging software.
The stock tune has no timing in it at all, it's really quite disgusting. With the stock tune the air/fuel came in a little lean below 2000rpms, ran 11.5 through the mid range, and hit high 10s past 5000rpm. The car makes about 9psi of boost in stock form, just like the guage on the dash says. With the stock airbox the MAF is almost pegged, reading 4.95v.
Now that we had some good data on a stock car we started playing with the tune. When it was all said and done we arrived at 482RWHP and 477RWTQ, no you're not reading that wrong, that is approximately a 60RWHP gain. This was not a money shot either, the car was ran 11 minutes before and made 481RWHP/476RWTQ on the previous run. This was no ragged edge tune either, the Air/Fuel was 11.5:1. I was not about to blow up a brand new and very expensive car just to be an internet hero. We did not have time to let the car cool for a money shot. I was so excited that I started on the intake install right away.
I whipped up a prototype intake the night before with parts I had laying around. I took a piece of 4.5" aluminum tubing, a 4.5" cone filter, and a little CNCed aluminum flange that I had made a while back. The flange allows you to mount a slot style mass air sensor into a tube. It wasn't much, but it would give us something to play with. We had to retain the stock tube that passes between the Strut Tower Brace and valve cover. The tube is rubber with a plastic insert to keep it from collapsing, I'm sure it's restrictive, just like the stock airbox and panel filter. An aftermarket tube with thinner walls would flow a lot more air and still fit between the valve cover and STB.
The air intake required some tuning because the mass air sensor was installed in a new tube. This totally throws off the air/fuel and requires that the maf transfer function be redone, however an experienced tuner can do this in a few pulls. With the prototype intake the car made 505 RWHP/487RWTQ. Simply amazing, with the new intake the car picked up a slight amount of boost past 3500rpm, about 1psi peak at 6000rpm. The sensors were still measuring a little bit of intake restriction though, so the rubber tube between the maf housing and throttle body definitely has to go. I ordered a piece of 4.75" silicone hose, but it did not arrive until after the dyno testing was done today.
Tune with stock airbox vs tune with air intake, shown with boost.
Stock vs tuned vs tune+intake shown with air/fuel.
This car has a supercharger inlet pressure sensor between the blower inlet and throttle body, this will be handy for measuring various inlet restrictions. In the next few weeks I should have a throttle body to test.
The best part is the car feels just like stock until you romp on it. A quick 1-2 shift can now get you in trouble, even with TCS on.
We disconnected the exhaust after the X pipe, it was only worth a few HP.
I've debated whether or not to post this pic of the intake I made. Namely because its very simple and easy to duplicate. However, since I'm mainly in the tuning business I've decided it does not really matter.
A word of warning to all Shelby GT 500 owners out there. This car has a totally unique electronic control system, not seen on any other Ford (not even the Ford GT). The drive by wire system will take power away if you pulley the car, and then add it back in slowly. The car could be given what is thought to be a *safe* tune on the dyno, but then blow up a few days later.
I am still looking for several more of these cars to work on. If you are in the Central Florida area contact me.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 09-12-2006, 07:22 PM   #2
Zim
You want to **** me?
Zim's Avatar
Re: VMP Tunes the 07 Shelby GT500...505 RWHP
Holy hell... badass man. I wonder what some headers, catless midpipe, and new catback would gain on that thing. So thats JUST a air intake thats less restrictive with a tune and you gained close to 85rwhp??? Simply AMAZING.
I like toys
Old 09-12-2006, 07:22 PM   #3
Zim
Zim's Avatar
VERY nice...
I like toys
Old 09-12-2006, 07:56 PM   #4
Nice numbers. Our shop ended up getting about the same and then drove to the track and ripped off a 12.2 on the street tires with Cody driving (12.85 with the owner driving). I believe the guy is doing full exhaust, 4.10 gears, and the JLT prototype CAI, like Evolution has been running, soon. Should be interesting to see where it ends up after that.
Still, not a fan of the car, but, they are decent numbers none the less.
Old 09-13-2006, 07:22 AM   #5
Herbstang's Avatar
WOW
Old 09-13-2006, 01:19 PM   #6
timpryor's Avatar
my jaw just dropped thats f'ing amazing, wonder what full exhaust and a blower pulley would bring down
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 09-13-2006, 03:33 PM   #7
Good work man. That is awesome.
Old 09-13-2006, 10:23 PM   #8
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
and the ambient temp looks like it's in the high 90's...wow....amazing!
Do you have video of the dyno run?
Everybody and their grandma are going to be at your shop now wanting a tune. I still can't believe it
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 09-18-2006, 10:27 PM   #9
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Very nice, you can't keep telling me these things don't have the potential that the `03 and `04's did.
DarkShadow is offline   Reply With Quote
Old 09-18-2006, 11:03 PM   #10
They have the potential, it just isn't as easy to mod. 03/04 cobras came with a 3.5" stock upper. You could drop all the way to 2.75" and still have room to drop further if the eaton would take it. This one comes stock with a 3.0", and a 2.6" requires snout modification.
Ford did all they could to make it harder to mod so that there wouldn't be as many blown engines that were modded and returned to stock.
Hell, rumor has it the upper pulley is made in a way that it will fail if you take it off and try to put it back on.
It has lots of potential, just look at the lightnings since they are pretty much the same...but they are unstyled, over weight, over priced (even at msrp) cars that ford sold out and badged as a shelby.
02:15 AM
