The BOSS 302 is back - Mustang Evolution
Old 11-07-2006, 09:52 AM   #1
Looks like this might be the engine that could go into the rumored boss in the future.
Ford Mustang Blog - Mustang News Blog Archive BOSS 302 Crate Engines Coming In 2007
Old 11-07-2006, 10:26 AM   #2
bluemustang's Avatar
Re: The BOSS 302 is back
yeah its gonna be the hotness for sure
Old 11-07-2006, 11:30 AM   #3
Thomas91169's Avatar
so theyre going back to the 5.0 pushrod? :no:
is it just me, or is ford severly confused in which direction they want to go in?
-Thomas-
Old 11-07-2006, 11:50 AM   #4
http://www.mustangevolution.com/foru...ine-24176.html
Repost
Old 11-07-2006, 11:55 AM   #5
But my article is different.
Old 11-07-2006, 04:30 PM   #6
bbunt302's Avatar
This will probably never show up in a production vehicle. It's quite sad, but it's also quite true.
Scary stuff.
Old 12-25-2006, 09:01 PM   #7
I doubt it. The 302 crates are unrelated to the coming Hurricane/Boss -- an all new motor (from what I hear) with larger bore spacing than the current modulars and even a tad larger than the old pushrod Ford smallblocks (Boss 302) -- likely similar to the old FE-based legendary 427, but a fully modern OHC design provisioned for VVT/VCT, direct injection (and possibly cylinder deactivation in the trucks -- dunno).
There's no way Ford will go backwards to a pushrod motor IMO. On the contrary, expect Gm to move toward OHCs in the future -- while they've done a lot with pushrod design, all other things being equal, there's no way a pushrod motor can be the equal of an OHC motor (of the same disp) if judged in toto on: efficiency, clean-burn and HP.
While pushrod motors can make good HP with bores of about 4" (or more), the intake passages will always have to accommodate intrusion of the pushrods (flow cosiderations) and the higher reciprocating mass of the valve train forces much stiffer springs and higher losses/lower revs unless more expense is thrown at exotic components. In the Z06 'Vette, GM deals with that with expensive titanium valves and super light rotating assemblies (titanium rods, alloy coated pistons, etc) because they loath two things: 1) admitting that Ford is ahead of them on engine design, 2) investing in a new hi-po motor that will obsolete their very capable, if long in the tooth, smallblock. But the writing is on the wall.
Additionally, a pushrod motor just cannot flow as much air as a DOHC motor, all other things being equal -- that why everything performance from Indycars to Ferraris runs DOHC motors. Ford's modular is, in general, a superb design, IMO, but was conceived at a time when the trend was to smaller displacements, hence the small bore-spacing.
With the demand for more NA hP in the trucks, the resurgence of the pony car and the coming battle-royal with Gm and DCX, the modular just cannot provide enough displacement, hence the rumored H/Boss motor -- likely 5.8 and 6.2L initially, but fully capable of 7.0L (magic 427/429cid) with rod angles less severe (by far) than either the current Ford modular 5.4 or GMs LS7.
The new Boss motor, however, will be unrelated to either the existing modular or the recent Boss crates to my understanding.
68fastback is offline   Reply With Quote
Old 12-26-2006, 12:11 AM   #8
^^^that just gave me a chubby.
so do you think that when GM finally switches over to OHC design they will lose the lead they had with the LSx series motors, plus if ford does do the above, might ford start to turn the tide in the naturally aspirated performance market?
-Thomas-
Old 12-26-2006, 12:52 PM   #9
Well, GM is already well-versed in DOHC (the Caddy Northstar and Olds mini-Northstar V8s) but as soon as Ford abandoned the smnallblock to crate/racing duty in favor of the small-bore modulars, there reall was no incentive for GM to move the only ral peformace car they had (the 'Vette) to the northstar when the highly refined LS1 could still be pushed a bit further.
But they know they're pushing the rod-angle/durability/cost tug-of-war to the limit as an NA motor -- that's why the upcoming rumored blue-devil/SS/StingRay [whatever they'll call it] will be forced-induction. The remec TR-6060 first built at Ford's behest exclusively for the GT500 will go into the new super-vette and the high first gear ratio (only slightly diff than the GT500) would seem to reinforce forced-indiction [likely turbo]. Since the bottom-end on the LS7 is already stout and using light/exotic parts, little else needs be done for more HP but add forced induction.
I'm not meaning to imply the 'vette and the mustang are to be considered in competing classes -- the 'vette will always be considerable more expensive and can afford a super-light aluminum/fiber/composite chassis (rumored to be down to 2950 lbs in the blue-devil for $100K+) and exotic components that the pony car price points can't embrace -- but from purely a trechnology point of view, the LS-series is effecively tapped-out as an NA motor without further impinging on reliability or emissions (or both), or even more substantial cost increases. Without the 'vette carring the R&D costs on the LS7, it would be virtually impossible, IMO, for GM to price a true hi-po Camaro (LS7 second year??) within reasonable pony-car price points. With some creative accounting for the 'Vette to carry most of the base R&D, it will be much easier.
That's why I think Ford will similarly write much of the R&D for the new H/Boss primarily against the F-series for which the base motor is actually being developed. Done right, that can provide the mustang with the right bore-spacing and base technology to produce some impressive (HP/torque, efficiency, and suitability to further modification) naturally-aspirated variants in the future, e.g. DOHC 3v and 4V and forced-induction too -- and the right price points to compete effectively.
Assuming for a moment the H/Boss will employ much of the advanced tech of the new DOHC 3.5 V6 (as a technology model, not dimentionally) a 6.2L H/Boss should have little trouble producing 500HP naturally aspirated with emissions levels far superior to the LS7. As an enthusiast we often forget the importance of this, but the reason for the existing mustang mix of V6/4.6 3V and 5.4 4V is largely driven by Federal CAFE standards. So, today, Ford has to force-feed the dealers more V6s than anyone wants, IMO, to meet overall CAFE. With a new H/Boss, done right, we could see the very first new-generation killer hi-po Ford motor that's cleaner than 95%+ of all cars being produced today. The 265HP 3.5 V6 meets PZEV -- "Patial Zero emissions" - an amazing technological accomplishment at that output level. Extrapolating to a 6.2 or 7.0 dohc H/Boss at 500+HP that meets the same standard would appear totally doable. That means Ford could conceivably make (if they choose to ramp production as we hope) as many such motors as the public cares to buy with little concern over CAFE/emissions (based on today's politics anyway) -- a nice position to be in when your competition has motors that are either big, dirty and archaic (DCX-'hemi' [which it's not]) or small, averagely dirty and at their NA-design-limits (GM smallblock).
Ford could easily have resurrected the old smallblock (5.0 'Boss') with electronics, forged and exotic goodies and, at significant expense, have a killer pushrod production motor like the LS7, but Federal legislation alone will force production retirement of such designs soon enough and even low volume production of such designs will polute(no pun intended) the overall ability to achiece model-CAFE. So Ford is doing (though financially painfull) the absolutely right thing, IMO, buy moving toward an all-new truly modern design, incorporating all the state of the art of what's been learned to actually get out in front of the cost/emissions/HP tug-of-war curve and putting it first in the F-series (where, right or wrong, the DCX [non-] 'hemi' is impinging on sales), and then using that solid base as the new hi-po base going forward in the mustang,etc ...at least that my opinion of what we're seeing and will see.
I applaud such thinking and resolve on Ford's part, especially right now while under intense financial pressures. That might mean we see the roll-out (H/Boss SOHC 2V -> 3V -> 4V and forced indiction) take a little longer than we might like (hope not) -- possibly not maturig until the 2012 ground-up re-engineered mustang platform that will likely be a bit lighter and capable of [conservatively] supporting 800-850HP production motors -- but being on the right base is ultimately far more important given all the engineering, ever-changing political constraints AND ever-intensifying competition.
Btw, have you even noticed how GM likes to make the engine covers on the LS-series look like it's a DOHC to the uintrained eye? I'm sure GM knows they're fooling no one except those who are clueless -- maybe that's precisely who they want to influence -- there are a lot of GM folk who were miffed when GM abandoned the DOHC Northstar. Perception is a powerfull thing -- would not want those 'puny' LS pushrod valve covers being seen by the intentionally confused, would ya? <lol>
So no one misunderstands, the above is just this writer's take. I'm not in the automoive indistry but I've followed it for decades and one thing I've learned after decades of Fortune-500 company planning, strategy and management work is that what a company does is a function of who they are and what their business demands they do to compete. Their words often offer little insight and tend to be strategically meaningless by design (or even specifically intended to spin/persuade/disuade, etc) and rarely provide the basis to interpret their true intentions.
But what I see developing as Ford trys to dig-out and undo the irresponsible cash-cow milking of Ford's assets by Jacques Nasser (likely for genuine reasons especially to look good to wall street investment) in the '90s, is very encouraging. Ford is one of the truly great Corporations our society has ever known. No company is perfect for sure, just as no individuals are, and Corporations, like individuals, have distinct personalities, e.g. conservative, agressive, predatory, clockwork, benevolent, supportive, etc The book "Built to Last" is an assessment of US business and the 20-30 US corporate jewels -- those that rise above purely a profit motive to become greater than the sum of their parts. Interestingly, you won't find GM, Chrysler, Exxon/Mobil, Pfizer on that list. You will find Ford, IBM, Procter& Gamble, Merck, etc. There are resons for that
So my little new years wish for Ford success is: believe in and never again forget who you are, believe in and trust the talent of your employees, and never underestimate your competition.
-Dan
Old 12-26-2006, 01:27 PM   #10
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
The thing I really like about the OHV motors is their small footprint. An LS7 displaces 427 cubes, and it's dwarfed in size by Ford's 4.6L OHC motors.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 12-26-2006, 04:24 PM   #11
yeah, OHC heads are larger and the additional space for the drive chains more than makes up for the mods smaller bore spacing. Not all good things come in small packages, I guess
Also, the modular blocks have deep skirts for strength and rigidity. Did you notice on the Boss 302/331 crate how massive the 4-bolt nodular-iron main caps are? On the modular they can fit within the deep skirt structure with a shallow pan rather than hanging down half within the oil pan, but deep skirts also make the engine look bigger because it accounts for about half the space occupied by the oil pan on skirtless designs -- visualy deceptive.
An alloy version of the new H/Boss (though I've heard not one rumor on that) should keep the weight in the right range, but, yeah, OHC take some space on top. The deep skirt design just makes sense on any HP motor (as does OHC IMO).
In the '60s as a teen I worked on several 289/302 smallblock Fords and they really are fairly compact (like the LS), but if you look at the packaging tricks incorporated into the 3.5L V6 in the MK and Fusion it's impressively compact for a DOHC deep-skirt motor. I think you'll see a lot of that thinking in the packaging of the new H/Boss, but it will never be as compact as the old fashioned OHV babies we've all grown to love over the decades. <sigh>
Personally, I'm willing to trade off some compactness for strength/HP/potential as long as the weight is right. I hope I still can drive <lol> when the H/Boss alloy 'BigBoss' comes along -- Ford is admirably tight-lipped on all this, but it's driving me nuts
Inquiring minds want to know!
04:02 AM
