5.4 dohc engine swap - Mustang Evolution
Old 07-25-2010, 07:22 PM   #1
upton7's Avatar
I'm in need of help as to what other parts i'm going to need and what will fit. Here is what i've got going so far and what i have planned so I can get some information.
Bought :
Block - 5.4 2v 2002 f-150
Heads - 4.6 4v 1996-1998 cobra
Not bought :
Intake manifold (navigator will work but am looking for something that will make more power)
Mid length headers (must be from 96-98 cobra longs won't fit shorts are probably useless)
Centrifugal supercharger (was thinking vortech v1 but i doubt there is a kit for what i'm doing)
pistons (most likely keith black forged)
timing chains and cover (pretty sure it needs to be from a navigator and I think the 4.6 guides and tensioners will work but don't know on the cam and crank spocket)
Valve covers (hopefully get some cheap used ones)
Head studs ( didn't know what vehicle to tell them I'm not sure it will matter though sence i can cut them if they are too long)
Flywheel ( is an aluminum worth the price?)
clutch (not sure on this one)
MAIN CONCERNS
how much horse the stock 5.4 rods and crank can take
What all you need for a centrifugal supercharger besides brackets head unit and injectors
clearance with strut towers ( can they be removed or can i just beat them in a little)
wiring (was told you just need to extend some wires didn't know the best way to do this)
tune where to go near illinois and if i should have them flash the ecu or put it on a tuner
Old 07-25-2010, 09:04 PM   #2
SVTCOBRA's Avatar
Re: 5.4 dohc engine swap
Do the 4V heads just fit on the 2V block? I thought you needed to have a 4V block? Or do I have the wrong information?
SVTCOBRA is offline   Reply With Quote
Old 07-25-2010, 10:05 PM   #3
upton7's Avatar
all modular heads fit all modular block with the exception of v8 to v10 or v10 to v8 of course.
Old 07-25-2010, 10:22 PM   #4
SVTCOBRA's Avatar
Really so I can get any 2V or 3V mod motor and slap 4V heads on them? I was always told there was a separate block for each configeration.
Old 07-25-2010, 10:41 PM   #5
for your intake manifold take a look at sullivan they make a 5.4L 4v intake its pretty expensive though but about the nicest intake made I wanted to do a 5.4L 4v swap for a while now but ive been starting to rethink its a lot to do and spend when i can just boost the 2v 4.6 and be happy. Whats your power goal?
Oh yea and it will fit tight but it will fit i think you might have to move the master cylinder up a few inches
vparis is offline   Reply With Quote
Old 07-25-2010, 11:27 PM   #6
upton7's Avatar
Yes you can but you will need different manifolds probably chains and redo some wiring
Old 07-26-2010, 10:39 AM   #7
SVTCOBRA's Avatar
The different manifolds made sense, thanks for that information. Sorry for hijacking your thread for a little bit.
Old 07-26-2010, 05:02 PM   #8
upton7's Avatar
no problem lol
If anyone else can give me info i'd appreciate it
Lego DOHC 32-Valve Engine OsirisGuy Pictures and Videos 20 09-10-2009 02:38 PM
Interesting vid on the DOHC engine (with blower) how it works SpectorV General Mustang Discussion 2 08-07-2009 01:42 AM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
04:16 PM
