traction-lok - Mustang Evolution
Old 08-06-2010, 12:00 AM   #1
soccerfreak2143's Avatar
Question traction-lok
maybe this is a dumb question, but what is a traction-lok and what does it do?...iv never heard of it...
soccerfreak2143 is offline   Reply With Quote
Old 08-06-2010, 07:37 AM   #2
Re: traction-lok
Basically think of the differential has the two axles being turned by one gear. If its an open differential you can turn one tire independent of the other (if you turn your tire manually while the car is up in the air and the other tire turns opposite then its an open differential)
A traction loc (has many different names same idea just some do it differently) makes both wheels get equal power, wheels will turn the same direction.
When you do a burn out with an open diff car one tire will spin, maybe the second if you get going good enough, but generally one wheel. A tloc will make both wheels spin, its just a boost in traction.
Old 08-06-2010, 09:23 AM   #3
Re: traction-lok
ok thx
Old 08-06-2010, 04:26 PM   #4
Re: traction-lok
Very well said Spec. A tlok (what most of us Ford guys say) is a good investment. You can get one along with some taller gears. They will improve traction, launches, acceleration (not hp, but better power distribution throughout the powerband), and of course burnouts
A lot of S197 v6 owners have been looking into GT takeoff rear ends. Sometimes you can find a complete unit with tlok already in. The v8 models come with an 8.8" differential compared to the v6's 7.5", so it's much stronger.
Either way you'll need a tune/tuner to adjust the speedometer.
Old 08-06-2010, 04:49 PM   #5
SVTCOBRA's Avatar
Re: traction-lok
Yeah almost everyone calls it POSI which is what GM calls it. You might of heard it by that name. T-LOK is the Ford version or lingo if I may.
SVTCOBRA is offline   Reply With Quote
Old 08-07-2010, 10:12 AM   #6
Re: traction-lok
ok...how much would an 8.8 cost?...i really dont have too much money to spend right now...most of it goes to insurance :/
Old 08-07-2010, 12:48 PM   #7
SVTCOBRA's Avatar
Re: traction-lok
On GT Take Off they sell a complete 8.8 with either the 3.55s, 3.73s, or 4.10s
Here is a link to the 8.8 with 3.73s
2005-2009 Mustang 8.8" Rear Axle Assembly 3.73:1Ratio w/ABS w/Trac-Loc Pinion Flange For Mustang V6
Old 08-07-2010, 04:37 PM   #8
Re: traction-lok
yeah...i dont think i can afford that with the installation...would it be better to wait till i can afford that or could i just buy new gears and a tlok?...im not planning on seriously modding this stang, just enough to have some fun
Old 08-07-2010, 08:55 PM   #9
SVTCOBRA's Avatar
Re: traction-lok
Yeah you could buy gears and T-lok for the 7.5
RING & PINION GEAR SET 7.5 AXLE
DIFFERENTIAL TRACTION-LOK 7.5 28 SPLINE 1979-2010 - CJ Pony Parts, Inc.
its about 500 bucks for the T-lok with different gears. Now that is with out installation, if you dont know how to install it.
Old 08-07-2010, 08:57 PM   #10
SVTCOBRA's Avatar
Re: traction-lok
Oh I forgot you will also need grease and what not if and when you do the swap
Old 08-07-2010, 09:27 PM   #11
Re: traction-lok
i have no idea how to change the gears and install the tlok...i could follow directions if its easy...would u suggest trying to diy?
Old 08-08-2010, 01:28 AM   #12
SVTCOBRA's Avatar
Re: traction-lok
No that is something that (or at least I feel) you shouldn't do if you don't know what your doing. But that is just my opinion.
Old 08-08-2010, 11:40 AM   #13
Re: traction-lok
thats what i figured
Old 08-08-2010, 09:13 PM   #14
Re: traction-lok
If you have never done anything with gears/tlok before, then I would not attempt an install. It is a very detailed, sophisticated install that requires near perfect results to prevent whining and grinding or more severe problems. Professionals can even make mistakes when doing this install.
Now I would say that the 8.8" rear would be much easier and probably something you could do yourself. With the 99-04's you could swap a 8.8" rear directly in place...not sure if the +05's are the same.
Old 08-08-2010, 09:18 PM   #15
Re: traction-lok
hmm choices...
Old 08-08-2010, 09:59 PM   #16
SVTCOBRA's Avatar
Re: traction-lok
Yes they bolt right in the only thing you would need to change is the pinion flange so the drive shaft hooks up correctly. But if you buy the rear from NewTakeOff it comes with the pinion flange attached.
My buddy and I installed it in his stang and the install was painless and took a good day. The only thing we didn't do was the tune for the different gears.
Old 08-08-2010, 10:02 PM   #17
Re: traction-lok
i kinda want to do it myself with the 8.8, but i would probably screw somethin up...
Old 08-08-2010, 10:08 PM   #18
SVTCOBRA's Avatar
Re: traction-lok
It bolts in right were the 7.5 is located.
Old 08-08-2010, 10:10 PM   #19
Re: traction-lok
we'll see. iv never actually worked on a car before, just read a bunch...
Old 08-08-2010, 10:12 PM   #20
SVTCOBRA's Avatar
Re: traction-lok
You got any friends that own or work at a garage?
Old 08-08-2010, 10:14 PM   #21
Re: traction-lok
nope...i live in a relatively small town, and i dont know anybody here that does stang work...there are a couple mustangs in town, but none of them are modded that i kno of...
Old 08-08-2010, 10:22 PM   #22
SVTCOBRA's Avatar
Re: traction-lok
They don't need to know how to do "stang work". For instance my Dads friend owns a garage were they fix cars that were in accidents (Body and Mechanical). They work on everything.
Old 08-08-2010, 10:25 PM   #23
Re: traction-lok
ok. iv only been driving for a few months so i havnt been to any shops yet to know who's any good or not.
Traction at the track help? ME Moderator Pre-2005 V6 Mustang 9 01-27-2008 07:01 PM
Is traction really improved ? Joel5.0 1979-1995 Mustang GT 10 10-04-2005 03:55 PM
10:41 PM
