what year can i swap out - Mustang Evolution
Old 08-13-2010, 03:28 PM   #1
1996v6stang's Avatar
Im just wondering what years of gt 8.8 rearends i could swap out for my 7.5 in my 1996 v6.
1996v6stang is offline   Reply With Quote
Old 08-13-2010, 09:40 PM   #2
Re: what year can i swap out
For the correct width 94-98. If you want a little wider base 99-04. For a narrower base 93 previous.
I'd recommend a 94-98 which are plentiful at the moment.
Old 08-16-2010, 03:09 AM   #3
SaleenFiend's Avatar
Easy Swap! Go for it! ...Do it yourself also, it's easy and a good way to learn simple things about your car.
Old 08-17-2010, 08:24 AM   #4
Yeah im sure i can do it, i mean i replaced my clutch and flywheel with just a friend there to help me drop the tranny and ****. i have a decent knowlege of cars for being 17.
Old 08-17-2010, 08:51 AM   #5
the one good thing about 94-98 is if you used a 99+ you would get more of the wheel sticking out which isnt a bad thing as its not enough to push it out to bad, most might like the look but that all depends on what the wheel setup is. Overall as said above try to find one out of your year car.
Also FYI the GT has quad shocks you dont need them, you also want to look for ABS if yours has it.
Old 08-17-2010, 11:36 AM   #6
would the 99+ model give me the same look as wheel spacers? i would like my wheels to stick out a bit more because i like that look. how much more would they stick out on each side? and whats the quad shocks? 2 on each side? And mine doesnt have abs, my wheels lock up and skid.
Old 08-17-2010, 12:30 PM   #7
I cant remember but I think 99+ stick out .75 more per side~ but you need to make sure the wheel has that much room to com eout (or what ever wheels you want) so it looks right. If you plan to run wider wheels like a 10 inch rim or so you may want to stick with 94-98 8.8's~ and it might all be in the axle not the rear end itself. I am not sure on that.
quad shocks is a little extra shock that helps with wheel hop, nothing special.
Old 08-17-2010, 12:41 PM   #8
ohh alright thanks spector
15 year old?! 1GT New Member Introductions & Greetings 87 09-04-2010 03:08 PM
Year by Year changes Esco General Mustang Discussion 6 08-07-2008 09:27 AM
ford is sketchy...funny year to year changes tedness The Bar 15 08-14-2005 08:28 PM
The year 2029 sonic04edge The Bar 19 05-09-2005 10:21 PM
K&N < 1 year old njstang97 Mustang Parts for Sale and Wanted 0 09-06-2004 11:17 AM
08:53 AM
