cant remove my rotor - Mustang Evolution
Old 08-26-2010, 10:21 AM   #1
tvsr's Avatar
Region: Nevada
Hey im changing my brake pads and my rotors on my 99 v6 but after i took out the caliper and the brake pads there is like a metal thing that goes infront of the rotor, the rotor is loose but i cant take it out because i cant remove the metal thing( IDK the name) the caliper top sets right on it. how do i take it off???
tvsr is offline   Reply With Quote
Old 08-26-2010, 10:26 AM   #2
Re: cant remove my rotor
There are 2 15mm bolts on the back side of that bracket that you need to take out to remove the bracket. They bolt into the spindle to hold the caliper in place.
Old 08-26-2010, 11:47 AM   #3
1ijack's Avatar
Send a message via Yahoo to 1ijack
You are also going to need to tool if you are doing rear brakes to push the caliper back in. You can rent it at the local parts house for nothing. It was worth my trouble. i am working on fronts now.....
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 08-26-2010, 12:23 PM   #4
yea for the rear brakes you need a tool, for the front you do not (just something to compress the piston in like a C Clamp etc) The pistons on the rear caliper screw in.... instead of just slide in so the tool just lets you get a handle on the piston to twist it back in. You can rent it at autozone and just take it back to get 100% of your money back.
Old 08-26-2010, 12:45 PM   #5
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Or do like my dad and use vice grips.
If you've only got 15mm bolts holding the caliper bracket to the hub, feel lucky. My 'vette had two 21mm bolts, torqued to 150 lbs/ft, with red lock-tite on all four corners. I had to get the burnz-o-matic after them, to get them loose.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 08-29-2010, 08:39 AM   #6
Tape's Avatar
I just use a pair of needle nose plyers
Tape is offline   Reply With Quote
Old 08-29-2010, 08:47 PM   #7
SaleenFiend's Avatar
I've done a few Vettes... or Chevy's for that part. The Silverado's were always a beast with the lock-tite!
BTW you can use a C-Clamp and Chanellocks for the rear caliper piston.... keep enough force on the piston and spin it with the chanellocks, then tighten the C-clamp some more... it's easy easy... and takes the pain out of using that tool to twist while you have to push!
Brake Rotor Concern runvsofthisbull Pre-2005 V6 Mustang 20 03-30-2010 08:01 AM
01 GT rear rotor issues Ride1331 1996-2004 Mustang GT 3 04-15-2009 03:59 PM
Rotor talk Zim 1979-1995 Mustang GT 17 02-03-2007 09:39 AM
Brake rotor question colinsv6stang Pre-2005 V6 Mustang 5 03-29-2006 09:33 AM
Brakes and Rotor replacement robert0803 Pre-2005 V6 Mustang 11 08-14-2004 11:56 AM
02:26 PM
