I smoked a '97 Viper GTS - Mustang Evolution
Old 10-27-2003, 09:20 AM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I **** you not, I beat a viper GTS. And a Vette... and a WRX, all at the same autocross track.
It was cold so none of the people running slicks were getting very good traction. The guy in the viper just couldn't drive the thing, plain and simple. A real waste if you ask me. Anyway I beat him by about 6 seconds I think. It was a LOT, I know that. The Vette I beat by 2 or 3. I was 4th place in the Street tire class and won STX class. Man that was an awesome way to end the autocross season. I'm totally stoked for next season.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 10-27-2003, 10:01 AM   #2
Zim
You want to **** me?
Zim's Avatar
i have a buddy that was there in a green 240SX... said he talked to you a bit. I woulda come out there but i had to drive back to kansas yesterday He told me he did pretty well though...
I like toys
Old 11-12-2003, 08:58 PM   #3
.:DarkEntity:.'s Avatar
Send a message via AIM to .:DarkEntity:.
Nice...
I want to go to AutoX one of these days, and see what my suspension can do
http://www.mustangmods.com/data/13888/legacysig3.jpg
.:DarkEntity:. is offline   Reply With Quote
Old 11-13-2003, 01:05 PM   #4
Rental Mustang racing
This is my first post.
Let me introduce myself, I own a SVO Mustang and I am in the process of finding myself a used 1999 and up V6 Mustang for a daily driver and a weekend autocrosser. I have been racing autocross for 4 years now and this year raced a 97 SS Camaro in the class ESP. I'm a Ford guy but could not turn down the opportunity to race a nationally competitive car. I finished 3rd overall in the SCCA ProSolo and 5th in the Nationals.
The reason I want a V6 Mustang is that it seems to be a great car for everyday use and me in a rental car finished 4th overall in my local club last weekend. What a blast!!
Any thoughts?
Rich
Cone slayer
ConeSVO is offline   Reply With Quote
Old 11-13-2003, 01:12 PM   #5
Welcome to the board!
Thoughts?
Your car > my car.
MaestroSC is offline   Reply With Quote
Old 11-14-2003, 05:49 AM   #6
Danger Dude's Avatar
Re: Rental Mustang racing
Any thoughts?
Rich
Welcome to V6stangs Glad to have you here!!! It is nice to have SVO owners here. When they came out I took one for a test drive. That is a fun car. Do you have alot of suspension improvements on the SVO to be Autocrossing it.
Old 11-14-2003, 07:58 AM   #7
Thanks!
I did just about everything you can do to still be in ESP. It has all poly bushings, springs, new Konis, tower brace, K-member bar. The only thing left to do is a panhard bar. The problem is that it has been race for so long that the body is really flexible. If I could put frame connectors on it that would help but it is not legal in ESP. A roll cage is legal but that would be pretty expensive.
After going to the Solo 2 nationals I reallize that a SVO will never be competitive in ESP and I want to race in a Stock class to not have to spend so much to win. GS seems to be a good class for the V6 Mustang. We will see next year!
Rich
Cone slayer
Old 11-14-2003, 11:41 AM   #8
Region: Iowa
I'm pretty sure only 98 and below are GS, 99 and up are CS and in with the SVT Focus. That's why i'm running STX in mine.
Old 11-14-2003, 11:50 AM   #9
Who would think after all the "Mustang's handle like tanks" type comments that you would be doing autocross so well. Show them they're wrong! Props to you Horse!
Old 11-14-2003, 12:08 PM   #10
http://www.moutons.org/sccasolo/Lists/2003/stockc.html#GS Follow this link for the class listings. It lists all V6 and 4 Cyl turbo Mustangs. Also includes SVO, I think that that would be THE car in GS but it would be hard to find one that was in "NEW" condition. GS also includes V6 Camaros. There was a guy from I think Oklahoma running one nationally a few years back and did well. Camaros are heavier than a Mustang but have better camber loss than Mustangs.
Mustangs do handle like tanks. If you mean that the understeer like pigs. If you do a front alighnment with toe out and as much negative camber as possible this helps. If you look a the other cars in GS you will notice that most are front wheel drive, talk about power understeer!!!!
STX has a .795 PAX index, GS has a .781. If you do the math on a 60 second run you would have to go 1.75 seconds faster in a STX car to get the same points as a GS car. That's huge in autocross. Of course this means no mods in GS.
Rich
Cone slayer
Old 11-15-2003, 01:36 PM   #11
there is SUCH A huge after market for the mustagns and since teh v8 suspension parts work on the v6 adn teh v6 has better weight/handling set up its a good choice for daily driving and for autox, not to hard to make them handle good.
Old 11-19-2003, 04:08 PM   #12
hey, im also new here(not v6s, I leark at 3.8 ), and just went to my first autox event last sunday.
A STOCK v6 stang would be infact GS, I know this becasue I spent forever tryign to figure out what class I would be in. But stock, is so limited.
That means no
-CAI
-only cat-back exhuast(no prob there)
-no adding of a rear sway bar(not 100% casue it is a option on a v8 )
-no bigger rim(unless mabye its a a gt sized rim, again not 100%)
-very limited on tires with stock rim
STX seems to be the way to go for a lite mod v6, but then your up against wrx, impreza, and integras.
Not to bash against the v6, becasue i have one and love it. im not sure its the ideal autox car. stock v6 suspension is well..... I hjave lowered mine and rear sway bar. That helped a lot, but puts me into the STX class.
Horse ur runnin STX not becasue you would be in CS, but becasue your mods take you out of GS.
'98 Cobra Rims, 245/45 Dunlops, Mach1 Chin Spoiler, GT Takeoff Swaybar, Eibach Pro Kit, 20% Tint, eBay Cold Air intake, Kenwood 4022 Headunit, Tri-ax shifter, True Dual Exhuast w/ Spintech Pro Streets
JoeR. is offline   Reply With Quote
Old 11-20-2003, 09:19 AM   #13
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
The Autocross Track is the only track which you could have beaten those cars.
But it must be nice to know that you can beat them if you have/want to
Rellik is offline   Reply With Quote
Old 11-20-2003, 03:46 PM   #14
Region: Iowa
Hmm, I was told that the 99 and up were CS. weird. Acctually my mods take me to ESP, the STX is another option and it way better than runnign against comp T/As Firehawks. and 03 cobras. STX is just fine for me.
Old 01-07-2004, 11:05 PM   #15
Dom
Dom's Avatar
Send a message via AIM to Dom
Old 02-15-2004, 09:47 AM   #16
how can i race in these autocross races?
All pigs are useless!
widowvirgin is offline   Reply With Quote
comparisons between the gt and gts? 1998gt General Mustang Discussion 4 08-26-2009 08:16 AM
GTS Gray Ghost 1979-1995 Mustang GT 49 05-25-2009 09:06 AM
GTS??? 95blackgt 1979-1995 Mustang GT 8 03-24-2008 10:47 AM
What are 94, 95 GTs going for now? Rick0636 The Bar 17 07-30-2005 11:42 AM
'05 GTs are fast! MonteCitan The Bar 7 11-14-2004 07:58 PM
01:16 PM
