Help glo gauge problem - Mustang Evolution
Old 10-29-2010, 03:28 PM   #1
tvsr's Avatar
Region: Nevada
Exclamation Help glo gauge problem
OK so installed the aftermarket BEM gauges I bought installed them did all the wiring correct but now they won't turn off. They have these lights on them but they won't turn oFF!!!!! I can put it in low power no problem, but I dont know if it will waste my battery charge.
Mustang White Face Reverse Glow Gauges (99-04 V6) at AmericanMuscle.com - Free Shipping!
these are the one's I got
tvsr is offline   Reply With Quote
Old 10-29-2010, 03:36 PM   #2
Re: Help glo gauge problem
where are you powering them from? The power source you are using is the wrong one probably, you used an all time hot vs a only key hot power source.
Old 10-29-2010, 03:37 PM   #3
SaleenFiend's Avatar
This
Old 10-29-2010, 04:35 PM   #4
tvsr's Avatar
Region: Nevada
I wired the red(positive) to the grey headlight wire which is the one the instructions in Americanmuscle told me to do. theres a button to dim it which i can press to dim it to almost off (very low dim) im not sure if leaving it like this would be ok.
Old 10-29-2010, 05:19 PM   #5
Well not to sound to harsh but AM is WRONG in your case you need to wire the positive to the BROWN wire that is in the switch. If you have a test light test the wire before you hook it up but it should go to the wire that is hot when you turn the headlights on.
Straublittleman is offline   Reply With Quote
Old 10-31-2010, 09:32 PM   #6
tvsr's Avatar
Region: Nevada
wow now the light wont even turn on at all it just stoped working all of a sudden reset the battery chcked the wires... wow waste of 20 bucks. the brown wire? will this make the glo actually work?
Old 10-31-2010, 10:54 PM   #7
Well if it stopped working already than something is wrong with the product. But the brown wire from your light switch is your parking light wire, witch would turn on your gauges when you turn on your parking lights.
Old 11-02-2010, 10:02 PM   #8
tvsr's Avatar
Region: Nevada
well with the red wire connected to the grey wire the light from the dashboard itself turns on but not the glo.
Gauge Wire Routing w/CDC gauge pod tripod_2005 2005-2010 Mustang GT 13 04-30-2010 11:46 AM
1995 convertable 5.0 temp/fuel gauge problem rwb223 1996-2004 Mustang GT 3 03-10-2010 12:55 AM
gauge problem red herring The Bar 5 07-11-2005 01:26 PM
99-02 GT EURO REVERSE GLO GAUGES (3 SETS) mattstang Mustang Parts for Sale and Wanted 4 04-25-2004 11:35 AM
01:09 PM
