Fuel Pump Question - Mustang Evolution
Old 12-12-2010, 10:19 PM   #1
Blustreek's Avatar
Region: Hawaii
Fuel Pump Question
Howzit everyone real quick question of a problem I am having
with my 5.0HO.Okay,One day I started up the engine to run for a while to let battery charge since it's been sitting for some time now.5 minutes in while I was watering my plants
it stalled.When I went back to restart it,Nothing! Just cranked away.I have compression,spark and I figure since
the fuel in the tank is a year or two old it probably is stale and has no flashpoint.I tested fuel pressure but normally when key is first turned on the fuel rail pressures up in a second and I pressed pintle on schrader valve fuel test port and no fuel shot out no pressure what so ever.Pump still pumps fuel but weak,Could pump be functional yet not enough to run engine? Should I Just replace fuel pump motor and rubber hoses in the tank? Mahalo!
Blustreek is offline   Reply With Quote
Old 12-12-2010, 11:23 PM   #2
Re: Fuel Pump Question
Yes sounds like the fuel pump is bad, change it and the fuel filter at the same time. Word of advise go get some fuel stabilizer and put it in the tank if you plan on letting the car sit for more than a month or two. Also 99% of the time when the fuel pump goes out it will still run but It'll be very weak.
Straublittleman is offline   Reply With Quote
Old 12-13-2010, 11:42 AM   #3
Blustreek's Avatar
Region: Hawaii
Hey Right on Straublittleman! That's the answer I was seeking,Now to ebay to order it! Aloha braddahman!
You've been a gynormous help bro! ALOHA OI!
Old 12-13-2010, 08:20 PM   #4
Old 12-14-2010, 06:51 AM   #5
Gster's Avatar
I would change the fuel filter first. Start cheap, the if that does not work change the pump.
Gster is offline   Reply With Quote
Old 12-14-2010, 07:58 AM   #6
cant you use a data logger to check the fuel pump to see how its performing?
Old 12-14-2010, 08:17 AM   #7
maybe on new cars but he is obd1, he would be able to check to see if the fuel pump relay is working but thats it.
Old 12-14-2010, 08:22 AM   #8
what about its output voltage?
Old 12-14-2010, 08:53 AM   #9
It will read the voltage going to the pump, but that won't tell you if its pumping fuel. Been there done that, I have a snap-on scan tool that does data logging and it sucks with older fords, chevy shows more parameters.
Old 12-14-2010, 10:23 AM   #10
hmm good to know
Old 12-14-2010, 01:27 PM   #11
Blustreek's Avatar
Region: Hawaii
Mahalo for all ur postings and mind power! I'll keep ya'all updated when I R&R the fuelpump okay? Changed the FuelFilter already,still
no change in status.Bye!
05 fuel pump NEED HELP! sglide18 2005-2010 Mustang GT 5 12-16-2010 09:09 PM
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
fuel pump?? Xx_1990GT_xX 1979-1995 Mustang GT 7 10-07-2008 06:37 AM
Fuel pump lowflyn Mustang Parts for Sale and Wanted 4 08-01-2006 08:12 AM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
09:48 PM
