Rear End! - Mustang Evolution
Old 01-13-2011, 08:58 PM   #1
94 Mustang GT's Avatar
Rear End!
Ok so I have a question for everyone! What are the pros and cons of a 8.8 rear end or a 9 in rear end? I just found out i have 3.27 in the rear with a 8.8 in rear. Idk weather to buy my friends 3.73 from his stock 06 that is the 8.8, or go with a 9in rear end? What shall I get if I plan on making some good power??
94 Mustang GT is offline   Reply With Quote
Old 01-13-2011, 09:40 PM   #2
Re: Rear End!
An 8.8 will hold up pretty darn good, they're as stong as a 9 inch but the 9 is easier to change out gears and such. Also if you snap an axel in a 9 it won't come out on you as easy, unless you get c-clip eleminators for the 8.8. If you aren't planning on full out raceing then i'd go with the 8.8.
Straublittleman is offline   Reply With Quote
Old 01-13-2011, 11:20 PM   #3
The 8.8 is a very strong rear end! I know of a Guy that has one in a Twin Turbo '03 Cobra with 800hp. Said his best time was 9.09 @ 150!
Was actually considering putting mine in for trade on it, but might be too much to cruise in LOL!
93CobraGuy is offline   Reply With Quote
Old 01-13-2011, 11:29 PM   #4
Re: Rear End!
so it almost sounds like 6 of one or half a dozen of the other? Thank you for the input so far
1
Old 01-14-2011, 09:29 AM   #5
Re: Rear End!
8.8 is a strong rear end that most will never have issues with. I would upgrade teh gears but keep the 8.8 (rebuild the tlok as well) only use new gears dont install used gears and get a pro to do the install to keep issues from happening.
Old 01-14-2011, 09:56 AM   #6
Re: Rear End!
Well first, whats wrong with using gears frtom my buddies stang that only has 50k miles on em!? nothing! and Im a tech for Ford in MN, so I hope i can do it! lol
Old 01-14-2011, 10:26 AM   #7
Re: Rear End!
Gears wear in a given pattern, they will work but they may whine, who knows. They will will work its just an annoyance factor. Since you are a tech you can take them out, adjust etc so no big deal. Its just a precaution as gear installs can get expensive. I recommend those that don't have knowledge on all the little things to get someone else to do it, but I am sure you know every detail so you wont have any issues.
Old 01-14-2011, 10:29 AM   #8
Re: Rear End!
Thats right they wear in a pattern which is why you get the ring and pinion in a set which is what my buddy is going to give me! lol. no i never said i know every detail i was just pointing out that im a tech for ford so its not like im a weekend mechanic lol
Old 01-14-2011, 10:43 AM   #9
stampde's Avatar
Re: Rear End!
another plus of the 8.8 is it takes less horsepower to turn it !!!
its lighter etc ......... not as strong as a 9' sorry , but pretty darn close ,
stick with the 8.8
2011 GT Auto
Old 01-14-2011, 10:59 AM   #10
Re: Rear End!
stick with the 8.8
So... I just might as well stick with my 8.8 then!??
Old 01-14-2011, 12:12 PM   #11
stampde's Avatar
Re: Rear End!
i would , i had a 600+ rwhp car and didn't brake mine , it was beefed up, but still never had an issue ................,
2011 GT Auto
Old 01-14-2011, 07:47 PM   #12
Re: Rear End!
Even though you're a ford tech How many rear ends have you taken apart and put back together. Just asking?? Just because your a ford tech doesn't meen you can do it right and I have had many ford techs mess thing up worse than they were because they're "book smart" not "hands on smart".
Old 01-14-2011, 08:24 PM   #13
Re: Rear End!
I never said i can to it right, i guess i was just trying to get at that i work on cars daily so i have experience and that i have any kind of tool, the space to do it and other experienced people for assitance! I also just ment im not a reatard with a wrench! lol. I have only done about 2 MAYBE 3 lol
Old 01-14-2011, 09:42 PM   #14
Re: Rear End!
Ok. I'm sorry if I sounded like a dick, I wasn't trying to be. I just have a hard time putting words into place sometimes.
Old 01-14-2011, 10:07 PM   #15
Re: Rear End!
Oh no worries! I wasnt offended, but eveyones that way once in awhile!
Old 01-15-2011, 10:19 AM   #16
Very true, the last time I brought my Lincoln blackwood to the ford dealer (under warranty) I noticed almost every tech there looked like they were fresh out of a tech school. When they finally finished swapping the heads due to them stripping out several spark plugs, I noticed screws missing and things unplugged too. Now since the warranty ran out I'll do all the repairs since I can't stand others touching my cars.
Cobracoupe5 is offline   Reply With Quote
Old 01-15-2011, 01:06 PM   #17
Re: Rear End!
Im not being defensive or anything, but I know you have made mistakes too! lol, heck its part of human nature! If you havent made mistakes you sure as heck arent human! lol. Im the SAME way, i get very nervious when others are working on my car! lol, even my buddies
Old 01-15-2011, 04:07 PM   #18
Oh I've made plenty, I don't claim to be a ford tech, but I do claim to have over 20 years of hands on experience with 79-93 stangs. I don't know but when I go to the dealer for service I expect to have trained and experienced people working on my car. Otherwise, I would just go to bob's thrifty one stop auto repair for half the money. Lol
I'm not referring to any particular person but if I had to choose between a person with every certification and book smart or John doe who has never been to school but has been doing mechanic work for 20 years , I would go to John doe.
That's just me.
Old 01-15-2011, 11:01 PM   #19
Re: Rear End!
It's not just mating the ring to the pinion gear when you install in a new rear end.
To get the same exact wear patterns you will have to shim the gears exactly the same in order to the same exact backlash and pattern.
Old 01-21-2011, 06:35 PM   #20
Yeah, and If you can manage to accomplish that you need to hope they were installed correctly the first time around.
« Avatar | Avatar »
8.8 rear end tigerfan2771 Pre-2005 V6 Mustang 20 12-12-2008 04:08 PM
Rear End megax29 Pre-2005 V6 Mustang 8 08-27-2007 07:19 PM
95 GT rear end? IFixAircraft 1979-1995 Mustang GT 6 08-31-2006 07:07 AM
99+ GT rear end jimmy_beaner Mustang Parts for Sale and Wanted 2 05-13-2005 01:33 PM
8.8 Rear End ttpancakes Mustang Parts for Sale and Wanted 8 07-20-2004 06:39 PM
08:08 AM
