...Blow it or stroke it, either way im in a good place!!! - Mustang Evolution
Old 01-22-2011, 06:06 PM   #1
Mikes347's Avatar
Get your minds out of the gutter!! I'm referring to my next project. I need advice as to whether doing a 363 stroker or going with a turbo kit on a built 306 would be a better (read: fun to drive ) street cruiser! I have no plans to ever race it. Just take it out on nice weekends and cruise ins. I plan to keep the stock hood that's why I mentioned the 363 vs a 408 or higher stroker engine. HP target around 400-450 RWHP. with great street manners.
Thanks
ID:	22948   Click image for larger version
Mikes347
DSS short block, 70 mm TB, 75 MM Mass air Accufab, TFS twisted wedge heads, street intake, custom Crower Cam from Custom Performance in Concord NC, Kooks long tube headers, Dr. Gas x pipe, Bassani Street series Catback, Eibach progressive rate springs, 5 sp. Trans, 4.10 Ford Racing Gear, FR 500 wheels, Steeda Tri ax shifter, SCT tune,
Mikes347 is offline   Reply With Quote
Old 01-22-2011, 06:14 PM   #2
MC770's Avatar
Re: ...Blow it or stroke it, either way im in a good place!!!
I would say turbo just because I like the sound the BOV makes
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 01-22-2011, 06:17 PM   #3
That thing is f'ing nice!
I would do supercharged, its the only power adder I have never had in a car. But thats just me.
93CobraGuy is offline   Reply With Quote
Old 01-22-2011, 06:19 PM   #4
Titus Wadicus
svtlx's Avatar
well im making 456 at the wheels wit a 7.5 rear on a standard stroke..with 11psi of boost. a stroked combo of wut your talkn bout with boost would have you 600 plus at the wheels.
just boost it, if you break the motor you can drop your boost set-up on another block. if you stroke the motor, then break it...your outa a whole lota money for the kit and your time to build it, if you are the one building it.
you can get 400-450 on standard stroke easy with boost.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-22-2011, 06:23 PM   #5
Titus Wadicus
svtlx's Avatar
lol..my car is supercharged and it has a bov. makes the noise everytime i take my foot out the gas
Old 01-22-2011, 06:26 PM   #6
MC770's Avatar
Is yours a pro charger?
Old 01-22-2011, 06:31 PM   #7
Titus Wadicus
svtlx's Avatar
nope, itsa powerdyne...but all centrifugal s/c pretty much operate the same way. anything over 6psi and it's a real good idea to consider running an aftermarket bov.
and before anyone here says a word...ive been running my powerdyne for 5yrs trouble free...just throw'n it out there. my friend has been running his for 7yrs @12psi trouble free
Old 01-22-2011, 06:35 PM   #8
I love the way the Kenne Bell Cobras sound! Pure bliss to my ears!
Old 01-22-2011, 06:37 PM   #9
MC770's Avatar
I see, the only centrifugal supercharger I know is a procharger. I don't like the whistle they have my only dislike...........
Old 01-22-2011, 06:37 PM   #10
MC770's Avatar
Exactly, I'm gonna have to pick one of those up eventually!
Old 01-22-2011, 06:44 PM   #11
Titus Wadicus
svtlx's Avatar
im sorry to hurt your feelings guys...but no matter wut type of blower you get, rather it be centrifugal or twin screw all make some sort of noise..."constantly". some louder than other others. sometimes it's air..sometimes its mechanical..usaly a variation of both. and if you want to make decent power, anthing over 6-9psi..u will hear a noise of some type
Old 01-22-2011, 06:45 PM   #12
Mikes347's Avatar
I currently have a mild 347 in it. I have plans to do a Boss Block 363 which is a 4 bolt main block so it should be plenty strong for a street car for the stroker option. For the turbo option a dart block with a stock stroke and .30 over bore. The trick is, going the turbo route I want to run a stock cam or damn close to it. I love the sound of the BOV too! Had one on my last project. 97 cobra with a pro charger.
Mikes347
Old 01-22-2011, 06:48 PM   #13
Titus Wadicus
svtlx's Avatar
personaly i would run a supercharger..maybe a stock cam wit sum 1.7rr and really low boost maybe 5-9psi. i think that would have you where u wanna be running it on you current configuration.
Old 01-22-2011, 06:49 PM   #14
Mikes347's Avatar
Thanks man! It was a POS when I bought it! But I got it cheap and it was no rust or collision damage. I've done the SC thing. Had a pro charger, and a Vortech S trim, wanted to try my hand at a big inch small stroker or a turbo set up as a change of pace!
Mikes347
Old 01-22-2011, 06:53 PM   #15
Titus Wadicus
svtlx's Avatar
i would go s/c...turbo with that much displacement would be a ton of heat depending on boost. regardless though, the nature of turbos your gonna be making lots heat even at low boost
Old 01-22-2011, 06:54 PM   #16
Mikes347's Avatar
I like the sound too!!
Mikes347
Old 01-22-2011, 06:58 PM   #17
MC770's Avatar
You ever been to the food lion auto fair?
Old 01-22-2011, 06:59 PM   #18
Mikes347's Avatar
The 363 option is NA the turbo option is a 306. I think you may have convinced me to not go turbo. I totally forgot about the heat they generate. Great call out!! Maybe the KB blowzilla is a better option! Never had a twin screw or roots blower before!
Mikes347
Old 01-22-2011, 07:00 PM   #19
Titus Wadicus
svtlx's Avatar
so how tight did u run your bov spring? i run mine loose so it turns on faster. i love the noise too, but i care more bout my belt and bearings...my powerdyne has an internal belt, not gears.
Old 01-22-2011, 07:01 PM   #20
Mikes347's Avatar
Yep I go every year both times! I work for FL headquarters so I get in free! I get a lot of parts there actually. It's held right around the corner from my house. how about you?
Mikes347
Old 01-22-2011, 07:05 PM   #21
Titus Wadicus
svtlx's Avatar
the twin screws make heat too. not as much as turbo, but more than centrifugal. that's y u see so many twin screw guys running inter cooler setups...you dont see many guys running intercoolers with centrifugals unless they are running 17psi or more. and that's because they are running over a full atmoshphere, not because of mechanical heat like twin screw or turbo guys... dont get me wrong, twin screws rock, and id love to have an o3 cobra on 19psi
Old 01-22-2011, 07:06 PM   #22
Mikes347's Avatar
Same philosophy as you on the BOV. On my last blower i had the gears ( helical cut) replaced with (straight cut) because they were noisier! It sounded like a freakin 747 taking off!!
Mikes347
Old 01-22-2011, 07:07 PM   #23
MC770's Avatar
I went last year. That place is awesome, my dad almost bought an old vette to restore.. Wish he had. It's soooo huge I still don't think that we saw the whole thing lol
Old 01-22-2011, 07:12 PM   #24
Mikes347's Avatar
I don't intend to run over 11 psi, I've seen intercoolers on eBay very cheap. They (twin screws) make great power down low and thats a major factor in my next project. Twin screws are Stock on everything from Cobras, to Saleens and Roushes! So they must be pretty dependable and fun to drive. I likey!! Lol
Mikes347
Old 01-22-2011, 07:16 PM   #25
Mikes347's Avatar
I ride around on my dads golf cart!! Lol That place is freakin huge!! My dad sold his 69 Torino Cobra at auto fair several years ago. A guy from Ohio bought it.
Mikes347
Old 01-22-2011, 07:18 PM   #26
Titus Wadicus
svtlx's Avatar
i wasnt doughting their reliability. i just have a few books on supercharger and turbo theory. the amount of horsepower you get per pound of boost by each device, centrifugal makes more hp per pound cause it generates less heat. however, they all have trade offs because of torque ranges and peak efficiency levels.
Old 01-22-2011, 07:27 PM   #27
Mikes347's Avatar
I know what you mean! I think it's more about the street ability vs raw hp for this project. So the curves are more important IMO. I want to keep the RPMs below 5,800.
Mikes347
Old 01-22-2011, 07:46 PM   #28
MC770's Avatar
Nice, my dad was talking about getting a golf cart the whole time we were there
Definitely going to go every year from now on that place is awesome!
Was going to pick this up for $500 running just needed some exterior work and new fuel lines:
Old 01-22-2011, 08:51 PM   #29
Loc: Austin,TX
I say go NA! I would rather stay NA in a fox just for the old school factor.
Old 01-22-2011, 09:56 PM   #30
ibleedblue65's Avatar
Turbo s don't create heat, they use it. twin screws produce a lot. Just run an intercooler With a turbo. Turbo all way. Great street manners and more power than supercharged.
ibleedblue65 is offline   Reply With Quote
Old 01-22-2011, 10:59 PM   #31
Never known a turbo v8 mustang to last very long. Not for street applications. Under 10 or 12 psi centrifugal just makes life easier. Easy install. No exhaust mods or restrictions. Less heat. I've seen vortec kits on 5.0's hold up for years with no problems.
Alscobra is offline   Reply With Quote
Old 01-23-2011, 10:25 AM   #32
Mikes347's Avatar
Nice! A classic MG!!
Mikes347
Old 01-23-2011, 10:31 AM   #33
Are turbos like voodoo on mustangs or something? Its a centrifugal that is turned by waste instead ofengine power. They aren't overly complicated or harder on a motor. Plus if you make friends with a good exhaust guy you can do it cheaper and make more power. If you remote mount it, you don't need an intercooler. I like turbos, a lot.
Old 01-23-2011, 10:34 AM   #34
Mikes347's Avatar
My wife and Dad agree with you on this statement. I may go this route to keep things simple and tasteful. My dad recommends that I stay as close to Factory appearing as possible with the engine. Like using primarily Ford parts, factory valve covers, hoses, pulleys, fan etc. Been debating on whether the Boss 363 FRPP crate engine, or custom built 363 with the Boss block would be more economical! I don't want to mix and match to many parts nor do I want to spend an arm and a leg either. My engine builder thinks we can build a street 363 with great parts under what Ford is asking for the Boss 363 crate.
Mikes347
Old 01-23-2011, 10:38 AM   #35
I think na will not be as streetable as you hope. You definitely can't build a fast sleeper na car. Its impossible. You will need to get away from that stock cam, which still cost you idle quality and vacuum.
Blow by blow racings 2011 GT DDTCM 2011-2014 Mustang GT 7 11-11-2010 07:59 AM
Good place, good prices? crazeflier07 Pre-2005 V6 Mustang 6 11-09-2006 07:48 PM
good place to sell used books? I_luv_HP&trq The Bar 1 11-18-2005 11:11 PM
Good place to get gears and stuff Sublime782 Pre-2005 V6 Mustang 4 04-08-2005 06:40 PM
To STROKE or not to STROKE: 100th Topic (in ENGINE) RGR Pre-2005 V6 Mustang 10 02-14-2005 09:17 AM
09:26 AM
