Hoods - Mustang Evolution
Old 02-06-2011, 10:39 AM   #1
Mustangguy0202's Avatar
Hoods
Has anyone had any experience with cruizinconcepts.com on their hoods? They seem to be a hell of a lot cheaper than Americanmuscle which is unusual
Mustangguy0202 is offline   Reply With Quote
Old 02-06-2011, 12:35 PM   #2
Kpd3014's Avatar
Re: Hoods
I bought my wheels and tires from them. On the allfordmustang.com forum is a Cruizinconcepts rep named Jon. He hooked me up witha forum deal. The wheels and tires came well protected when shipped and the experience was good, no issues. On the hoods I would assume if they are coming from a manufacturer that you can trust to go ahead.
Kpd3014 is offline   Reply With Quote
Old 02-06-2011, 01:17 PM   #3
Wink Re: Hoods
I don't know if this will help, I purchased a hood from Trufiber last year. That came packed perfectly and was installed with NO adjustments to the fit. Was painted and looks fantastic.
onez2many is offline   Reply With Quote
Old 02-06-2011, 01:56 PM   #4
Titus Wadicus
svtlx's Avatar
Re: Hoods
how much did u guys spend on your hoods if you dont mind me asking. im gonna need a tall one for the intake on my 97.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-07-2011, 07:35 AM   #5
Re: Hoods
do research and see how the fit is, sometimes the money saved up front is spend twice over in getting a part to fit IF it can even be made to when its a cheaper part.
Old 02-07-2011, 09:32 AM   #6
Titus Wadicus
svtlx's Avatar
Re: Hoods
ok
Carbon Fiber hoods DDTCM 2005-2010 Mustang GT 21 08-10-2010 12:37 PM
Fiberglass Hoods SVTCOBRA Mustang Audio & Video 2 04-05-2010 09:05 PM
Hoods Matt'sredbeauty Mustang Audio & Video 14 03-24-2005 08:01 PM
04 mustang and Cowl hoods Exit_Music Mustang Audio & Video 22 03-20-2005 04:49 PM
Hoods for Shaker Kit tarheeljujitsu Mustang Audio & Video 6 02-03-2004 09:51 PM
08:25 PM
