What to get? - Mustang Evolution
Old 02-07-2011, 03:59 AM   #1
What to get?
So i am getting a v8 after building 2 other cars and being not so happy with them..
I am looking for a car i can drive daily but can also throw down a low 13 high 12 1/4 at the track.
Something that can handle other cars on the street you know?
Well i have 2 in mind let me know what you guys think of each one?
The first one is about 1000 more than the bottom one.
87 5.0
E7 heads with almost everything that can be done to them i.e. port polish. And chromoly pushrods by trick flow, 550 lift springs
A/C delete
arp headbolts, new lifters
Typhoon polished intake
pro products 65 mm throttle body
anderson powerpype
pmas 80mm mass air
36 lb injectors
fmu system and 255 fuel pump underdrive pulleys w/ billet ac delete kit, 10 lb pulley
water pump and double r timing chain new
3 core radiator w/ electric fan
worldclass t5 built by southwest gear 3.73 gears, b&m shortshift
Bbk shorty headers and 40 series flowmasters
Guy said he ran a 12.9 ( we are at almost 5000 feet here so thats pretty good for around here i am moving though to san Antonio so it should run a faster time there.)
OR
89 notch with a 93 cobra motor
-GT40P Heads
-MSD Distributor
-Ford Racing Wiring
-24lb injectors
-BBK Longtubes
-Alum Drive shaft
-Trick Flow Stage 1 cam
-Ford Racing 373 gears
-MGW Short Shifter with Adj Handle
-Flow Master 40 Series Full Exhaust
-O/R H Pipe
-Alum Radiator
-Built 8.8 Rear End
-5 lug conversion
benjammcd is offline   Reply With Quote
Old 02-07-2011, 07:33 AM   #2
Re: What to get?
Anyone?
The second one also has suspension all done just found out. Also interior is all new and clean i think im going with that one even though it does not have the supercharger on it i think with the current mods should be close to what i want?
and a little more reliable?
One more thing if i do go with tthat one ill have about 1000 left over whats a good mod to throw on top of what it has?
Old 02-07-2011, 01:08 PM   #3
stampde's Avatar
Re: What to get?
I'd Go with the Notch !!!
2011 GT Auto
Old 02-07-2011, 02:23 PM   #4
The notch. Should be good for low 13's. Possible 12's on slicks. The notchback is just a much cooler body.
Alscobra is offline   Reply With Quote
Old 02-07-2011, 02:39 PM   #5
Re: What to get?
Just got done talking to the guy it has mach 1 wheels with drag radials in the back too.. he also has receipts for the work done and reputable shops did it.
So the notch it is plus extra money left over i can buy a wet kit if its not fast enough haha.
Old 02-07-2011, 07:09 PM   #6
Re: What to get?
Definitely the notch!
93CobraGuy is offline   Reply With Quote
Old 02-07-2011, 07:22 PM   #7
1ijack's Avatar
Send a message via Yahoo to 1ijack
Re: What to get?
I would go with the Notch and throw nos on it to give that extra punch....Sounds like a great set-up
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 02-07-2011, 07:32 PM   #8
Re: What to get?
Notch.
Add some weight reduction and a set of big and littles and be done.
Old 02-07-2011, 07:36 PM   #9
I had that trick flow stage 1 cam in mine. Was very pleased with it and sounded great.
Old 02-08-2011, 03:38 AM   #10
Re: What to get?
Thanks everyone. I'm going to go be picking it up this weekend. Should be getting a camera too so ill be taking some pics.
Old 02-08-2011, 03:59 AM   #11
Re: What to get?
Get some good ones of that engine bay. I'd be curious to know if you could find out any more info on the '93 Cobra that the engine came out of. If it was wrecked or what the story is on it.....
Reason for that is I like to keep some records and inform the Cobra registry of any dead ones out there.
Much appreciated if you can. Congrats on the new Stang when you get it!!
12:56 AM
