Engine restorer - Mustang Evolution
Old 02-27-2011, 06:27 PM   #1
Engine restorer
Theres this stuff at walmart you put in your oil that retires engine power. Anyway I tried it out and I noticed a huge difference anyone else knows about this stuff? They make a 4,6,8 cylinder formula
Blackedout is offline   Reply With Quote
Old 02-27-2011, 06:29 PM   #2
Restores not retires
Old 02-27-2011, 07:02 PM   #3
It's called restore and it leads to sludge and clogged oil baffles. I am using a new product called lubro-moly. I have a thread I will be updating at every fill up. Restore works but only for about 1000 miles before it wears off and the chunks fall out of the grooves it filled up and then clogs your filter
Old 02-27-2011, 10:33 PM   #4
Loc: Austin,TX
Re: Engine restorer
Retire.....
Old 02-28-2011, 12:10 AM   #5
Re: Engine restorer
Yeah it does work but Everett is right it does start to turn to sludge after a little bit. Its good to use like a 1000 miles before you change your oil.
Straublittleman is offline   Reply With Quote
Old 03-02-2011, 07:37 PM   #6
Blustreek's Avatar
Region: Hawaii
Re: Engine restorer
Originally Posted by everett View Post
it's called restore and it leads to sludge and clogged oil baffles. I am using a new product called lubro-moly. I have a thread i will be updating at every fill up. Restore works but only for about 1000 miles before it wears off and the chunks fall out of the grooves it filled up and then clogs your filter
hey ev,just how new is this "lubro-moly"? Who makes it? What's it made of? What properties improve this over "restore" anybody use
"marv's mystery oil?" good stuff? Mahalo for all ur info.
Blustreek is offline   Reply With Quote
Old 03-02-2011, 08:03 PM   #7
Lubro-moly is new to the market however it isn't really new. It's a component of red-line non diesel oil and it's found in royal purple. Lubro-moly is the name brand and you can find it at napa. I haven't seen it anywhere else. I have already gone thru 1 tank of gas and my per tank mileage is up to 520 from 450 kms. So it's doing something because my driving habits haven't changed. Google it. There is a wealth of info. And it's made in Germany. Mmo just cleans,it really doesn't lubricate at all. Mmo is great for sludge engines because it will dissolve the sludge slowly. Seafoam is better for sludge. Dissolves it faster however if the engine is really bad chunks may break loose and plug the filter. I will seafoam about 1000 miles before oil change... I will take a pic of the moly flyer so you can see what it looks like
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 07:40 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Engine to get... crazeflier07 1979-1995 Mustang GT 9 06-26-2006 09:29 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
New Engine!!!! drummerstang98 The Bar 18 01-02-2005 04:38 PM
11:48 PM
