Lowering on 17s - Mustang Evolution
Old 03-09-2011, 08:27 PM   #1
Lowering on 17s
I have 17s on my 2000 mustang. If I get the h&r springs from American muscle that drop the car 1.75 front and 1.6 rear will this look good or better if I get 18s
Blackedout is offline   Reply With Quote
Old 03-09-2011, 08:52 PM   #2
Blogger
99ford's Avatar
Re: Lowering on 17s
I honestly think that it would it look fine. It's worth a shot that way you don't have to buy new wheels. But that's just my opinion.
Old 03-09-2011, 08:55 PM   #3
Well I have dual exhaust and the are low it's jus how they have the x pipe why it's low they went too far down. And the exhaust are 5 to 6 inches from hitting ground. Will these lowering springs hurt my car any?
Old 03-09-2011, 09:11 PM   #4
Blogger
99ford's Avatar
Re: Lowering on 17s
Worse case scenario is your pipes are 3 inches from the ground. You have to go lightly over bumps. I see where your going. The 18inch wheels will make it at least 4 inches. It's up to you. I've heard good things about the H&R springs so I don't think you will hurt anything.
Old 03-09-2011, 09:17 PM   #5
17's or 18's. Your only gonna fit so much tire on it. Tire size will make the difference. You can swap around tire sizes to make it work with either.
Alscobra is offline   Reply With Quote
Old 03-09-2011, 10:46 PM   #6
Topless04GT's Avatar
Re: Lowering on 17s
i am dropped 2.5 around and i had my xhaust raised 1.5 inches... now i dont scrape unless i am somewhere new and its just too late.
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Old 03-10-2011, 07:30 AM   #7
Titus Wadicus
svtlx's Avatar
Re: Lowering on 17s
how did you raise your exhaust? also, your got 2.5 drop all the way around?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-10-2011, 08:02 AM   #8
Brett Greene's Avatar
I'm lowered 2 inch all around and scrape my exhaust if I'm careful going over bumps and what not. But not to much of a issue. Just go slow in parking lots
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 03-10-2011, 10:06 AM   #9
Re: Lowering on 17s
any sort of chin spoiler will only make things much worse.
Old 03-10-2011, 02:34 PM   #10
Re: Lowering on 17s
I have a 2005 GT and had to remove my chin spoiler after putting Eibach lowering springs on, it was just too much for the speedbumps here where I live. Sometimes compromise is required. Same problem with my '04 V6 when I lowered it, but fortunately the Mach 1 spoiler wasn't as low.
4.6Guy is offline   Reply With Quote
Old 03-10-2011, 04:06 PM   #11
I have the eiback pro-kit and I'm lowered between 1.5-2 and I have 18s. I also have a chin spoiler. But its the Mach 1 one obviously. I do need to order another one from a stupid curb! Lol.
I live in FL and it's pretty much flat besides the occasional driveway and nasty speedbumps
Sent from my iPhone using Mustang
Old 03-10-2011, 06:41 PM   #12
Re: Lowering on 17s
we aimed the bend from the the first curve after the headers to bend upwards a little more... now the pipes are higher than the driveshaft... and yea a 2.5 drop around
Old 03-10-2011, 10:08 PM   #13
Titus Wadicus
svtlx's Avatar
Re: Lowering on 17s
ill have to come over and see it one day then...
Old 03-11-2011, 12:33 AM   #14
Re: Lowering on 17s
by all means... i might be getting rid of her in th next couple weeks... im gonna put a for sale sign in her and stick her at the local highschool parkin lot and see if i can get any bites.
Old 03-11-2011, 12:47 AM   #15
USAF_stang's Avatar
Re: Lowering on 17s
lucky if you don't get anything wrong with it...i wouldn't trust a bunch of high schoolers when I was in high school much less with an extremely nice car like yours lol
USAF_stang is offline   Reply With Quote
Old 03-11-2011, 03:56 AM   #16
Re: Lowering on 17s
i know what you mean... only on the weekends tho... way ahead of you. I wouldnt trust anyone with my car but i figured hey, gotta put it somewhere... why not on a street that majority of the town drives on.
Old 03-11-2011, 04:04 AM   #17
USAF_stang's Avatar
Re: Lowering on 17s
Yeah I know what you're getting at. Leave it in your car so every time you drive it you can leave it in your window
Old 03-11-2011, 05:20 AM   #18
Re: Lowering on 17s
problem with that... i have 3% window tint... the only place visible is from the front window... and you cant have a sign in your front window while driving...
Old 03-11-2011, 07:03 AM   #19
USAF_stang's Avatar
Re: Lowering on 17s
well good luck w/e you decide to do lol
how much are you asking for it? mileage?
Old 03-11-2011, 07:27 AM   #20
Titus Wadicus
svtlx's Avatar
Re: Lowering on 17s
so are you running a camber/caster kit?
Old 03-11-2011, 07:54 AM   #21
Re: Lowering on 17s
the drop will look the same 17 vs 18 as teh tires are the same height.
Tire size comparison for 17s (sidewall wise) SpectorV 2005-2010 Mustang GT 3 11-10-2009 05:09 PM
Lowering my 04 GT Talon 1996-2004 Mustang GT 13 07-15-2009 08:02 PM
lowering? 96cobra 1996-2004 Mustang GT 17 04-08-2009 11:04 AM
Lowering? 19ClearCobra96 1996-2004 Mustang GT 14 05-16-2005 06:54 PM
275/40/17s now transfered to 17X9 chrome Cobra Rs 95 style Rick0636 Mustang Wheels & Tires 29 01-31-2004 11:07 PM
08:14 AM
