Gauge and Sensor install question - Mustang Evolution
Old 03-20-2011, 10:58 AM   #1
Ok, I have a gauge and a sensor I need to install on the car and they came with no instructions. The gauge has 4 wires....Red, Black, White, and Purple. I was able to figure out what those are:
Red - Power
Black - Ground
White - Sensor
Purple - Dimmer switch
Where my question lies is with the sensor. It is a 2 wire temp sensor with 2 white wires. Do those both feed into the single white wire on the gauge, or does one connect to something else?
Old 03-20-2011, 11:49 AM   #2
I'm not sure spec. What I would do is hook up your power and ground first. Then touch the white wires together. See what happens. Could be set up for a 2 wire sensor. If not. Ground both individually. See what happens. Is this coolant or oil temp? Did it come with a sensor? Usually coolant temp sensors just have resistance to ground as temp changes.
Alscobra is offline   Reply With Quote
Old 03-20-2011, 06:59 PM   #3
This is a coolant temp sensor going into my heat exchanger reservoir tank. It came with the sensor, some wire, and the gauge.
Old 03-20-2011, 07:03 PM   #4
I haven't seen one of those yet. That's good to know. The tank is not grounded I think. The sensor should have 2 wires then that should both lead to the gauge. My best guess. If you touch both wires together it should either peg out or go full cold. The sensor should be just a thermal resistor type.
Old 03-21-2011, 08:29 AM   #5
Re: Gauge and Sensor install question
Yeah, would have been nice to have some directions with it. The directions for the killer chiller kit were detailed as hell....then zero instructions for the included gauge and sensor. Hell, even the two pieces of wire they gave me to run from the sensor to the gauge are different lengths and neither reach the sensor from the gauge...so that must mean one runs through the engine compartment and then joins with the second one in the passenger compartment to run the rest of the way to the gauge.
But, that's my best guess as like I said...zero instructions...just a bunch of splicers and butt connectors.
O2 Sensor Question? SonicBlueV6 Pre-2005 V6 Mustang 2 01-09-2010 05:38 PM
Got ? For Install Of Air/Fuel Gauge TafoyaMNAA Pre-2005 V6 Mustang 26 06-16-2007 10:49 AM
another quick o2 sensor question I_luv_HP&trq Pre-2005 V6 Mustang 1 08-27-2005 05:30 AM
HOW TO - install aluminum gauge trim x77911 Mustang Audio & Video 3 04-18-2004 11:38 AM
help asap air/fuel ratio gauge install Rstang98 Pre-2005 V6 Mustang 8 03-06-2004 01:17 AM
07:23 PM
