Anyone with SCT tuner experiance - Mustang Evolution
Old 03-21-2011, 05:43 PM   #1
Anyone bought sct tuner from Americanmuscle.com if so I need to know everything there is to know. I know I need my computer number which is a four digit number- letter combination. And I know I need my upgrades. What else do I need to know. Bc I'm getting involved with something I know nothing about this is my first time tuning I have a 2000 v6 mustang...
Blackedout is offline   Reply With Quote
Old 03-21-2011, 05:47 PM   #2
I think you van give them your vin number and your all set. What upgrades are you referring too. A tuner gives you power right off the bat. And increases with the octane. A tuner is a great and necessary part to realize the full potential of any and all mods
PETOM.biz TTT
Old 03-21-2011, 05:52 PM   #3
Bbk cold air intake and pypes true dual off-road exhaust
Old 03-21-2011, 05:56 PM   #4
K...don't waste your money on a cai. On a new edge it's doesn't help. If you really want to get more air into your sixxer go to the scrapyard and find a ford windstar minivan. The intake flows better than your stocker and is good for 10 hp. And it's a bolt on. A buddy of mine did it and was really happy. He is in the petom forum. I suggest asking him. He has one helluva mod list and did the wrench work himself.
PETOM.biz TTT
Old 03-21-2011, 08:27 PM   #5
Project Pony's Avatar
+1
Sent from my iPhone using Mustang
[SIGPIC][/SIGPIC]
Old 03-21-2011, 08:36 PM   #6
I need info on sct tuners like pros and cons. What to look out for.. Advice
Old 03-21-2011, 09:51 PM   #7
There aren't any cons really. Just don't advance the timing.
PETOM.biz TTT
Old 03-22-2011, 06:06 AM   #8
And how do I avoid that?
Old 03-22-2011, 11:29 AM   #9
In the options you can advance timing in 3 rpm ranges. Just don't play with them. Done deal
PETOM.biz TTT
Old 03-22-2011, 01:07 PM   #10
DarkShadows's Avatar
Re: Anyone with SCT tuner experiance
your 4 digit ecm number is located directaly on the ecm. your ecm should be located on the passangerside panel under the glove box right in front of the passanger door. remove the panel to access the ecm. it should be right on top of the ecm. they will need to know this and according to AM they couldnt get it from you vin #. website for reference Your Mustang's Computer Code (1987-2011+) - The Basics at AmericanMuscle.com
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 03-22-2011, 02:56 PM   #11
How much of an impact will a runner have on my car
Old 03-22-2011, 02:58 PM   #12
Tuner*
Old 03-22-2011, 03:01 PM   #13
you mean tunner? well id imagine that since you have very few mods and your 6cyl, i dont imagine that you will have much of a gain. it will help in the fuel econemy department thou.
Old 03-22-2011, 03:04 PM   #14
So what is more mods more hp?
Old 03-22-2011, 03:44 PM   #15
mods are stuff to modify your motor to gain horsepower, all a tuner really does is fine tune the ecm to use those mods to their potental.
Old 03-22-2011, 07:58 PM   #16
Is it true the sct tuner has recalibration for aftermarket wheels
Old 03-22-2011, 09:28 PM   #17
Yes it does.
Old 03-23-2011, 08:35 AM   #18
Dion11197's Avatar
I've had a few of the SCT tuners. An x cal 2 that I used with my supercharged 04 and I've used the x cal3 and the live wire. They're all great tuners. I currently have the live wire and I would've rather gone with the xcal 3. The xcal units just plug and play like a trouble code reader. You plug it in, load the tune, unplug and you're good to go. If you start to do a lot of mods and bolt ons like some of the other member are suggesting, I highly recommend a dyno tune if you can afford it. It will get your air/fuel ratio exactly were you want it and the tune will be custom to your car. If you go with the AM bama tune, you'll need your computer number, list of mods and what octane gas you'll be using, what tire size and gear ratio. You can go in and change just about all the values for timing, fuel, gear ratio, tire size all with the hand held. You can also read and delete data trouble codes.
Dion11197 is offline   Reply With Quote
Old 03-23-2011, 08:39 AM   #19
Dion11197's Avatar
Pro's and con's..... the live wire you can leave hooked up and it will support up to 3 gauges I think, that plug into the unit. However I've talked to a few tuners and they say they've been having problems with some of the earlier units that came out having problems loading and unloading the tunes. Personally I'd go with the xcal2 or 3, they are plug and play, easy to use and once you unplug you're ready to go and the programmer goes in the glove box or wherever you want it to.
SCT tuner Blackedout Pre-2005 V6 Mustang 20 03-18-2011 07:04 AM
SCT Tuner Stang23 2005-2010 Mustang GT 38 01-10-2011 08:46 AM
SCT Tuner Stang23 2005-2010 Mustang GT 13 12-19-2010 11:15 PM
sct tuner dd96stang Pre-2005 V6 Mustang 6 04-09-2010 12:53 PM
SCT Tuner sonicpony03 Pre-2005 V6 Mustang 5 03-08-2008 03:53 AM
05:54 PM
