1990 5.0 - Mustang Evolution
Old 03-24-2011, 04:09 PM   #1
1990 5.0
http://houston.craigslist.org/cto/2284472340.html
Wat y'all think it has about 150,000 miles on it...
Sent from my iPhone using Mustang
Chris09 is offline   Reply With Quote
Old 03-24-2011, 04:59 PM   #2
MC770's Avatar
Re: 1990 5.0
Check the top for cracks and check if it works. Other than that it sounds decent
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 03-24-2011, 05:46 PM   #3
gixxer007's Avatar
Re: 1990 5.0
I would not worry about the miles as much as the rust and rot condition on the underside and tower area. that seems to always be the typical issues in most cheap fox mustang up my way at least. You can always rebuild that motor easy and not to much cost but a rot box could be bigger issues than you may want to handle.
Good Luck
gixxer007 is offline   Reply With Quote
Old 03-24-2011, 06:16 PM   #4
bbunt302's Avatar
Good Luck
Agreed. Definitely want to check the torque boxes for twisting while your checking out the underside. Also check the window sills, trunk/hatch areas, etc for rust.
Scary stuff.
Old 03-24-2011, 06:20 PM   #5
gixxer007's Avatar
Re: 1990 5.0
When I stared to look for another fox body i went thru about 15 of them and each had rust and rot issues. Every person would say its clean then you drive all the way to them and look under it and just want to kick them.
A friend of mine bought one last year that was a total rot box and ended up having to part it out 3 months later the rot was so bad.
Old 03-24-2011, 06:29 PM   #6
I appreciate all y'alls help....
Old 03-24-2011, 06:31 PM   #7
I jus text the guy he said he only noticed it(rust) on a couple of brackets in the engine bay....
Old 03-24-2011, 06:56 PM   #8
SaleenFiend's Avatar
More than likely rust under the car then too
*From the Android App
Old 03-24-2011, 06:59 PM   #9
gixxer007's Avatar
Re: 1990 5.0
Yea just look really good if you do go to check it out. It may be a clean car just dont want to see a fellow Mustang guy get burned with a rat box.
Good Luck and keep us posted.
Old 03-24-2011, 07:20 PM   #10
Jpstang's Avatar
I'm in the same boat now!!!! Looked at about 10 foxs , all of them rotted underneath . Other than the notorious spots any other spots I should be looking for?
Jpstang is offline   Reply With Quote
Old 03-24-2011, 07:22 PM   #11
MC770's Avatar
Re: 1990 5.0
Top frame rails for cracks/breaks. These are hard to find replacements for
Old 03-24-2011, 07:22 PM   #12
gixxer007's Avatar
Re: 1990 5.0
Yep just take your time you will find the right one for sureis all I can say. You may also have to up what you want to spend it seems the prices on Foxes are slowly going up all of a sudden. Whicj is good for the seller but not so much for us buyers LOL.
Good Luck
Opinion on 1990 5.0 Hatch MC770 1979-1995 Mustang GT 24 01-04-2011 06:54 PM
1990 Owner hawleyRyder New Member Introductions & Greetings 7 08-14-2009 05:34 PM
1990 GSX Thomas91169 Pictures and Videos 10 06-08-2008 11:52 PM
1990 GT Raven90 1979-1995 Mustang GT 2 07-04-2007 10:56 AM
1990 Raven90 1979-1995 Mustang GT 1 07-03-2007 07:16 AM
12:02 AM
