Automatic: Shift kit or tuner? - Mustang Evolution
Old 04-02-2011, 07:59 PM   #1
NeedSomeMods's Avatar
Question Automatic: Shift kit or tuner?
I used to hear a lot about how an aftermarket shift kit could do wonders for an automatic transmission, but not so much anymore.
Now all everyone is talking about is how much a tuner can do for automatics.
Does the tuner do the same thing as a shift kit?
Does it help, or hurt, to have both?
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 04-02-2011, 08:20 PM   #2
soccerfreak2143's Avatar
not sure about a shift kit, but i have a tuner for my auto and it feels like a new car
soccerfreak2143 is offline   Reply With Quote
Old 04-02-2011, 08:28 PM   #3
Re: Automatic: Shift kit or tuner?
I personally like the idea of the tuner simply because it's much easier to install and manage. If you no longer want the aggressive shifting, simply load the stock tune back into your car, simple as that.
With a shift kit you have to start upgrading components in the valve body to get those better shift points and eliminate that slippage.
I'd say it's one or the other...if it were me, I'd go with the tuner.
Old 04-02-2011, 09:10 PM   #4
Thanks for the input. Is there anyone out there with a shift kit that would like to chime in?
2000 V6 - RIP
The '94 -
Old 04-02-2011, 09:16 PM   #5
Yea they work but tuner is said to help that
Blackedout is offline   Reply With Quote
Old 04-02-2011, 10:04 PM   #6
Good advice. The tuner also make it so you can adjust the shift points to whatever you choose. And adjust back at will. A shift kit requires the tranny be adjusted from the inside,thereby paying a mechanic. The tuner does so much more than just adjust shift points. And the cost would likely be comparable. Plus 1 on the tuner
PETOM.biz TTT
Old 04-03-2011, 09:51 AM   #7
wereKEV's Avatar
When ibought my car it had a tuner already installed but the main unit used to set it did not come with the car any body know how i can get the main unit (it's a diablo tune I know because thats the modual on my motor.)
wereKEV is offline   Reply With Quote
Old 04-03-2011, 09:35 PM   #8
Blustreek's Avatar
Region: Hawaii
WELL YOU CAN EITHER TYPE DIABLO SPORTS TUNE IN UR SEARCH ENGINE OR GIVE A.M.
A CALL.TRY CHECK EVEN EBAY TOO! GOOD LUCK GUY! THAT'S.....americanmuscle.com
Blustreek is offline   Reply With Quote
Old 04-04-2011, 07:10 AM   #9
My buddy sells unlocked diablosport tuners for under 250 shipped. Pm me for his email if you want one
Old 04-04-2011, 07:28 AM   #10
tune it to shift better dont modify the valve body manually~ no real need for a street car
Old 04-04-2011, 08:53 AM   #11
wereKEV's Avatar
Thanks for the advice on the tuner guys will let you know what happens.
Automatic Shift knob SN95 Pre-2005 V6 Mustang 3 06-30-2007 05:18 PM
Shift Kit coolstang Pre-2005 V6 Mustang 17 02-14-2005 09:42 PM
Different Automatic Shift Knob Brent Mustang Audio & Video 22 11-23-2004 05:28 PM
Automatic Gear Shift Change luckyman Mustang Audio & Video 9 08-20-2003 06:50 PM
Automatic Shift Knobs --- 01 Stang Stang01 The Bar 5 07-28-2003 09:23 AM
07:22 PM
