Washing my engine - Mustang Evolution
Old 04-09-2011, 08:22 AM   #1
Washing my engine
Is it safe to pressure wash my engine and does it have to cool down first before I wash it?
Blackedout is offline   Reply With Quote
Old 04-09-2011, 08:34 AM   #2
Loc: Austin,TX
Re: Washing my engine
Just be careful not to soak it,cover your alternator with aluminum foil or plastic bag. No need to let it cool down,get some simple green or some type of engine cleaner and follow the directions. If you use a engine cleaner do not get it on your paint.
Check YouTube for some engine detail videos there are a ton of those and it will walk you through,some even say stick with the garden hose method as the pressure washer can be to much. Is this your first time detailing a engine bay?
Old 04-09-2011, 08:34 AM   #3
Titus Wadicus
svtlx's Avatar
maybe put a plastic bag round your coil pack... i would recomend leaving the engine runnig while pressure washing it.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-09-2011, 10:03 AM   #4
Some owner's manuals (at least for trucks/SUVs) that I have seen will she you exactly how to wash your engine and not hurt it...or a HANES manual..it shows you what to cover and how to do it...and don't wash it hot...metal expands when it's that hot then shooting it with such cold water is a big shock...just be careful when you do it...mom ended up throwing a plug because of it.
2008Shelby is offline   Reply With Quote
Old 04-09-2011, 10:28 AM   #5
Yeah it is
Old 04-09-2011, 10:29 AM   #6
How is engine bright??? And what is simple green do?
Old 04-10-2011, 04:35 AM   #7
Wolfsbain76's Avatar
I don't bother to "wash" my engine bay, I find it takes away from my detailing it myself. Instead, I get a lot of rags, and I go to town in the engine bay, cleaning everything one at a time by hand, including firewall and the cars chassis.
As for Engine Bright, it's good, but I find that when I did do my engines with engine cleaners, that it left a sticky residue on the engine. And after time driving it, I would look at the engine and it woudl look like sandpaper....everything stuck to it!!
IMO, if you have time, and you find it to be a stress relief therapy, like me, then just do it by hand with some rags.
2007 Mustang GT
Wolfsbain76 is offline   Reply With Quote
Old 04-10-2011, 08:31 AM   #8
Loc: Austin,TX
That's also gonna depend on how dirty it actually is. Sometimes a dirty engine needs a bath just like you and me but after that, all you have to do is stay on top of it.
Old 04-10-2011, 08:33 AM   #9
Washing an engine has it's advantages like my ac runs way cooler now...
Old 04-10-2011, 08:47 AM   #10
Beav's Avatar
I occasionally power wash, but usually just use a hand full of rags. I opened the hood for my cousin the other day, and he was amazed how clean it was, being a daily driver. I only power wash it after road spray makes it's way onto components... I never spray electronics hard...
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 04-10-2011, 09:01 AM   #11
Loc: Austin,TX
Uhhhhhh.......wha........
Old 04-10-2011, 09:33 AM   #12
Just try it. Trust me
Old 04-10-2011, 09:58 AM   #13
Loc: Austin,TX
You mean all these years I've wasted all that coinage on recharging my ac when I could have spent it on whores,booze and cocaine?
Old 04-10-2011, 10:00 AM   #14
Beav's Avatar
I bought a 90 Astro van in 92 and the van had 170,000 highway miles on it. When ever I stopped, the temperature gauge rose. A friend suggested that I check between the condenser and radiator for debris. I did and found a dead bird, small twigs and more bugs than you can imagine. He told me to be careful pressure washing because it can bend the fins over on the condenser and the radiator. Anyway, after cleaning, my van engine ran cooler and my air conditioner blew colder..
Old 04-10-2011, 04:06 PM   #15
gixxer007's Avatar
I recall a kid when I was in highschool doing this to his car and the thing didnt run again for like 2 months and his parents dishing out a few hundered dollars.
Just use caution or do it by hand to be safe.
gixxer007 is offline   Reply With Quote
Old 04-10-2011, 05:16 PM   #16
Yes.
93CobraGuy is offline   Reply With Quote
Old 04-10-2011, 06:10 PM   #17
Idk why but washing ur ac pump works makes it cooler
Old 04-11-2011, 06:53 AM   #18
Tib
Tib's Avatar
like stated above, watch a youtube video so you know what to cover and whatnot to spray.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 04-11-2011, 07:11 AM   #19
Las0mbra's Avatar
Yep, total waste. Lol
Old 04-11-2011, 07:15 AM   #20
I'm not washing my engine. A dirty motor is a happy motor.
Alscobra is offline   Reply With Quote
Old 04-11-2011, 07:29 AM   #21
i would recommend trying simple green first just spray it on stuff and wipe it off, may take a few applications (let it sit a little bit) then wipe it off. Test it on plastics first but for metal it will be ok etc.
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 07:40 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Grenade vs. Washing Machine Brent Pictures and Videos 5 10-23-2006 12:47 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
My Girl Washing my Car *NWS* bluemustang The Bar 9 08-10-2005 03:15 PM
09:46 PM
