98 to Fox advice - Mustang Evolution
Old 04-10-2011, 07:03 PM   #1
Rosco's Avatar
98 to Fox advice
I got a 98 v6 right now and it's in tip top shape. The engine runs great with no heat, start, and driving issues. Its had the same weight and brand of oil throughtout its life and the original owner babied it and i doubt ever red-lined it .The paint on it is pretty good. The hood has some scratches on it from rocks and the heat it but the rest of the body is good; the paint is also kept up in the sense it shines beautifully with no fade from the So Cal sun. The interior has no tears and stains with an audio upgrade.
Now since I'm getting my own place and can't get my cobra I need an 8 badly. I see these nice lookin foxes on here, and the price of them isn't bad at all. So I'm thinking about trading or selling for one. The crappiest part is that I'm from So Cal and I rarely see a clean fox. I see like 5 foxes a week at the very most and their all beat to ****. Give me some advice on what to look for and do. Any feedback will be greatly appreciated.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 04-11-2011, 10:22 AM   #2
Titus Wadicus
svtlx's Avatar
Re: 98 to Fox advice
chech floor boars all the way up into the fenderwells. also check shock towers for rust as well.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-11-2011, 11:48 AM   #3
Rosco's Avatar
Are those common issues when buying these cars.
Old 04-11-2011, 11:53 AM   #4
Titus Wadicus
svtlx's Avatar
not on all of them obviously. but if u live in the rust belt it's definatley worth your due diligence to at least look. also check out the torque boxes if it was a v8 car that was heavily modified
Old 04-11-2011, 12:01 PM   #5
Rosco's Avatar
Yea any car that has been kept down by the beach will have some rust issues, they always seem to do. Is the trans on the fox a sturdy one. I don't know little to anything on fox strong and weak points. Im wondering if I found one with a some mods done if the trans should be replaced if it hasn't been already
Old 04-11-2011, 12:10 PM   #6
if its a nice super clean fox it will be costly, sometimes saving up front = spending more in the end.
Old 04-11-2011, 12:44 PM   #7
Rosco's Avatar
You get what you pay for type of thing. what is the price range for a clean fox that won't need any fixing up, or won't need more than a few hundred bucks put in for small stuff.
Old 04-11-2011, 05:45 PM   #8
gixxer007's Avatar
I agree with all the above take your time and look them over very good or have them checked out by someone you can trust or knows about them also.
Good Luck
gixxer007 is offline   Reply With Quote
Old 04-11-2011, 06:37 PM   #9
Rosco's Avatar
The fox that catches my eye the most I think is the 87-89 lx notch. What's a good price range on those. I don't know what the production time span for those is so forgive me if I'm wrong.
Old 04-11-2011, 09:54 PM   #10
Titus Wadicus
svtlx's Avatar
i got a disassembled 92 notch in my garage u can have for a hundred bux...lmao!!!! (dont tell alcobra..he'll have me lynched..lol)
Old 04-12-2011, 12:20 AM   #11
Stang.racr's Avatar
The 87-93 where single head lights on each side but have the same body. I paid 1700 for mine with two bald tires and a red hood on a black car. I already had rims, tires, and cowl hood. I only got 2k in my car but it could use a paint job but overall good shape except torque box from big launches with Alot of spray
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 04-12-2011, 04:27 PM   #12
Rosco's Avatar
That sounds great except your to many states away from me haha.
What's up fox Afterhours 1979-1995 Mustang GT 8 01-06-2011 12:22 PM
94 v6 - VS - Fox 5.0 sledgehammer Pre-2005 V6 Mustang 1 03-04-2008 04:44 PM
Someone with a fox.... fast64 Mustang Wheels & Tires 1 12-26-2007 08:00 PM
desire advice... stock investment type advice... dark The Bar 4 04-23-2006 06:07 PM
T-56 for fox? Can'tCatchMe 1979-1995 Mustang GT 13 01-30-2006 09:14 AM
02:39 AM
