Burn smell - Mustang Evolution
Old 04-18-2011, 01:40 PM   #1
Mustang240's Avatar
Burn smell
My new 2011 mustang v6 has a burn smell after I parked it and went out smelled it. It has 300 kms on it now but this happened after I was going like 60 km/h then pressed the gas pedal hard to like 100km/h.
I drove it gently for the first 300 km and this was the first time I try to accelerate with it.
Is this a bad sign? Did I burn something? Or is it because it's a new car?
Mustang240 is offline   Reply With Quote
Old 04-18-2011, 01:46 PM   #2
New engines and exhausts are lightly coated with a Protectant so they don't rust during storage. It will burn off in time. Don't worry about it.
Alscobra is offline   Reply With Quote
Old 04-18-2011, 02:53 PM   #3
gixxer007's Avatar
Re: Burn smell
Same thing I was going to say I think it take a while for the new motor coating they use to burn off. I would think as long as you are not seeing smoke or puddles under it you are safe also.
gixxer007 is offline   Reply With Quote
Old 04-18-2011, 02:53 PM   #4
Re: Burn smell
could be brake line leaking a bit (not 100%) tight? but new cars make smells as said as they wear in. You can run by ford to let a tech smell it and see if its something they know.
Old 04-18-2011, 03:57 PM   #5
Beav's Avatar
Re: Burn smell
Probably nothing, just like the above posts have stated...
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 04-19-2011, 06:14 AM   #6
Mustang240's Avatar
Thank you so much guys u were right I took it to dealer and he told me same thing u guys said
Old 04-19-2011, 09:33 AM   #7
wereKEV's Avatar
Re: Burn smell
That's the other new car smell.
wereKEV is offline   Reply With Quote
Fuel smell while driving Jdaddy42 1996-2004 Mustang GT 9 02-12-2011 05:44 AM
Transmission Fluid Smell Rainman64 1979-1995 Mustang GT 3 07-25-2009 09:08 PM
Gas leak/Smell? runvsofthisbull Pre-2005 V6 Mustang 15 12-27-2008 04:58 PM
Whats that Smell? Kyle The Bar 6 07-12-2005 04:25 PM
Antifreeze smell? steedav6builder Pre-2005 V6 Mustang 6 07-15-2004 10:30 PM
02:26 PM
