HID Headlights - Mustang Evolution
Old 04-19-2011, 08:56 PM   #1
ponyboy94's Avatar
HID Headlights
i was wondering if i have 55w hid headlights and then i put on 35w foglights will it draw to much from my battery?
ponyboy94 is offline   Reply With Quote
Old 04-19-2011, 09:00 PM   #2
ponyboy94's Avatar
Re: HID Headlights
i also have a stereo with 2 amps would this over power it any comments concerns? thanks for the help
Old 04-19-2011, 10:14 PM   #3
Las0mbra's Avatar
Hids use less power anyways, I don't think they would do that... Unless you're running like 2 1000watt amps...
Old 04-19-2011, 10:30 PM   #4
Re: HID Headlights
I think the 55w HID systems are known to produce too much heat for our stock housings. I would recommend sticking with 35w headlight/foglight setup.
Old 04-19-2011, 10:38 PM   #5
Las0mbra's Avatar
+1 to that, and 35w are still 3x brighter than stock anyway.
Old 04-20-2011, 05:54 AM   #6
ponyboy94's Avatar
I have a 300 and 700 watt amps
Old 04-20-2011, 06:22 AM   #7
Las0mbra's Avatar
You should be good, as long as your amps are efficient at all.
Old 04-20-2011, 07:16 AM   #8
Re: HID Headlights
yea you should be fine
Old 04-20-2011, 07:24 AM   #9
Titus Wadicus
svtlx's Avatar
Re: HID Headlights
55 watt hid generate as much heat as 55 watt halogen. also, if the difference between 35w and 55w hid's impacts your charging system with your stereo... then you should consider installing capaciter and a larger alternator.
hid's use a "igniter" to ignite/fire up the gas inside the bulb when you first turn them on which uses alot (a whole lot) of electricity. once the gas is ignited the ballast returns to its rated consumtion 35w/55w
if the car is running with stereo on, and the headlights only flicker.. then you need to consider a larger alternator, battery, and capaciter.
if the headlights come on with the car running and stereo on, then you should be fine.
the consumption between 35 and 55 watts isnt a huge factor.... it's the intial turn on from the ballast cause the igniters drink as much electricity as a fan on high speed setting for the first couple of seconds.
i hope wut i said makes sense.
i have 5 vehicles in my household...all with aftermaket hid's, and ive installed them for lots of friends and family over the years.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-20-2011, 07:26 AM   #10
Titus Wadicus
svtlx's Avatar
Re: HID Headlights
o yea, i got a 1000watt amp in my truck with hid headlight and foglights.... trust me u will be fine.
Old 04-20-2011, 02:57 PM   #11
06mustangmike's Avatar
Re: HID Headlights
i agree
06mustangmike is offline   Reply With Quote
HID Lights. CodySchraad General Mustang Discussion 2 01-28-2011 07:27 AM
HID kit SaturnMan8227 Pre-2005 V6 Mustang 42 03-06-2010 08:19 PM
HID Problems a3705872 Mustang Audio & Video 8 02-28-2010 08:11 PM
HID Headlights 9006 6000K 99MustangGTman Mustang Parts for Sale and Wanted 1 08-17-2008 05:53 PM
HID problem ProjectPunisher 1979-1995 Mustang GT 0 06-28-2008 10:33 AM
01:10 AM
