Steering Squeak! really annoying help!!!!! - Mustang Evolution
Old 04-21-2011, 06:30 PM   #1
austinknoll's Avatar
whenever i turn my steering wheel with the engine on, it squeaks. it makes my car sound so gay. my friends see this badass mustang come into the parking lot but as soon as i turn into the space to park, they all laugh at the gay squeak. its coming from the right side of the car but squeaks when i turn left or right.
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 04-22-2011, 12:53 AM   #2
Kitt's Avatar
You should check the power steering. My '91 and my '07 both squealed when they turn. I think it is a Ford issue.
Kitt is offline   Reply With Quote
Old 04-22-2011, 01:18 AM   #3
MonteCitan's Avatar
Re: Steering Squeak! really annoying help!!!!!
is it a continuous squeak?
Suspect tie rod end or ball joint..
If not that and its more of a pop/creak.. there's a sleeve that covers the bolt for the steering rack (goes through the rack, then sleeve, then fastener) that sleeve always made noise, our fix at the dealership was remove it, add lithium grease, reinstall and retorque..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-22-2011, 08:20 AM   #4
Titus Wadicus
svtlx's Avatar
so your cars' a homosexual eh?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-22-2011, 08:22 AM   #5
it should only make a noise if its at a full lock (cant turn anymore) which you should not hold it at. If it does it in between bad then you may need to look at changing out some stuff. or the bushings.
Old 04-22-2011, 08:27 AM   #6
Titus Wadicus
svtlx's Avatar
sooo ur sayn... if it squeels while not at full lock.... his car could be gay
Old 04-22-2011, 08:43 AM   #7
I think my steering homosexual I'm just confused about it
65 Mustang coupe
Blacking out games is annoying Brent The Bar 3 06-11-2008 08:10 PM
Annoying little habit. Seph The Bar 15 08-30-2007 11:49 PM
turndowns are annoying me! k8338j Pre-2005 V6 Mustang 8 11-17-2004 06:47 PM
sooo annoying!!! V6STANG007 ME Site Help & Announcements 3 08-25-2004 03:21 PM
05:47 PM
